I need to create a dynamic array to send a different number of bytes of data using TWI.
Here is how I create an array:
void twi_Eeprom_Write(uint8_t *pBuffer, uint32_t WriteAddr, uint32_t NumBytesWritten)
ret_code_t err_code;
uint8_t SendAddr = 0;
uint8_t *reg;
reg = (uint8_t *)malloc((NumBytesWritten+2) * sizeof(uint8_t));
SendAddr = ((EEPROM_ADDR & 0xFC) | ((uint8_t)(WriteAddr >> 15) & 0x02));//A0 - write
reg[0] = (uint8_t)(((WriteAddr) & 0xFF00) >> 8);
reg[1] = (uint8_t)((WriteAddr) & 0x00FF);
for (uint8_t i = 0; i < NumBytesWritten; i++)
reg[i+2] = pBuffer[i];
err_code = nrf_drv_twi_tx(&m_twi_eeprom, SendAddr, reg, sizeof(reg), false);
free(reg);
TWI_Delay(10);
When using the malloc function, I always get an array with a size of 4, regardless of the value of the X variable. I also tried to use the nrf_malloc function. The result is exactly the same.
Maybe there are ideas why he doesn't want to create an array of the required size.
Thank you in advance
