how to combine hid keyboard and hid mouse
Hi
  I want to combine mouse and keyboard function together,and I had  modify the example of hid mouse,show as below
 but the question I meet is that the PC and phone reaction when send the mouse message and no work when I send the keyboard message
BLE_HIDS_DEF(m_hids,        /**< HID service instance. */
             NRF_SDH_BLE_TOTAL_LINK_COUNT,
             INPUT_REP_BUTTONS_LEN,
             INPUT_REP_MOVEMENT_LEN,
             INPUT_REP_MEDIA_PLAYER_LEN,
             INPUT_REPORT_KEYS_MAX_LEN,
             OUTPUT_REPORT_MAX_LEN,
             FEATURE_REPORT_MAX_LEN);
/**@brief Function for initializing HID Service.
static void hids_init(void)
    ret_code_t                    err_code;
    ble_hids_init_t               hids_init_obj;
    ble_hids_inp_rep_init_t     * p_input_report;
    ble_hids_outp_rep_init_t    * p_output_report;
    ble_hids_feature_rep_init_t * p_feature_report;
    uint8_t                       hid_info_flags;
    static ble_hids_inp_rep_init_t input_report_array[INPUT_REPORT_COUNT];  //INPUT_REPORT_COUNT = 4
    static ble_hids_outp_rep_init_t    output_report_array[1];
    static ble_hids_feature_rep_init_t feature_report_array[1];
    static uint8_t report_map_data[] =
        0x05, 0x01, // Usage Page (Generic Desktop)
        0x09, 0x02, // Usage (Mouse)
        0xA1, 0x01, // Collection (Application)
        // Report ID 1: Mouse buttons + scroll/pan
        0x85, 0x01,       // Report Id 1
        0x09, 0x01,       // Usage (Pointer)
        0xA1, 0x00,       // Collection (Physical)
        0x95, 0x05,       // Report Count (3)
        0x75, 0x01,       // Report Size (1)
        0x05, 0x09,       // Usage Page (Buttons)
        0x19, 0x01,       // Usage Minimum (01)
        0x29, 0x05,       // Usage Maximum (05)
        0x15, 0x00,       // Logical Minimum (0)
        0x25, 0x01,       // Logical Maximum (1)
        0x81, 0x02,       // Input (Data, Variable, Absolute)
        0x95, 0x01,       // Report Count (1)
        0x75, 0x03,       // Report Size (3)
        0x81, 0x01,       // Input (Constant) for padding
        0x75, 0x08,       // Report Size (8)
        0x09, 0x38,       // Usage (Wheel)
        0x15, 0x81,       // Logical Minimum (-127)
        0x25, 0x7F,       // Logical Maximum (127)
        0x81, 0x06,       // Input (Data, Variable, Relative)
        0x05, 0x0C,       // Usage Page (Consumer)
        0x0A, 0x38, 0x02, // Usage (AC Pan)
        0x81, 0x06,       // Input (Data,Value,Relative,Bit Field)
        0xC0,             // End Collection (Physical)
        // Report ID 2: Mouse motion
        0x85, 0x02,       // Report Id 2
        0x75, 0x0C,       // Report Size (12)
        0x95, 0x02,       // Report Count (2)
        0x09, 0x30,       // Usage (X)
        0x09, 0x31,       // Usage (Y)
        0x16, 0x01, 0xF8, // Logical maximum (2047)
        0x26, 0xFF, 0x07, // Logical minimum (-2047)
        0xC0,             // End Collection (Application)
        // Report ID 3: Advanced buttons
        0x09, 0x01,       // Usage (Consumer Control)
        0x85, 0x03,       // Report Id (3)
        0x15, 0x00,       // Logical minimum (0)
        0x25, 0x01,       // Logical maximum (1)
        0x09, 0xCD,       // Usage (Play/Pause)
        0x0A, 0x83, 0x01, // Usage (AL Consumer Control Configuration)
        0x09, 0xB5,       // Usage (Scan Next Track)
        0x09, 0xB6,       // Usage (Scan Previous Track)
        0x09, 0xEA,       // Usage (Volume Down)
        0x09, 0xE9,       // Usage (Volume Up)
        0x0A, 0x25, 0x02, // Usage (AC Forward)
        0x0A, 0x24, 0x02, // Usage (AC Back)
        0x09, 0x06,       // Usage (Keyboard)
		0x85, 0x04,       // Report Id 4
        0x05, 0x07,       // Usage Page (Key Codes)
        0x19, 0xe0,       // Usage Minimum (224)
        0x29, 0xe7,       // Usage Maximum (231)
        0x95, 0x08,       // Report Count (8)
        0x81, 0x01,       // Input (Constant) reserved byte(1)
        0x95, 0x05,       // Report Count (5)
        0x05, 0x08,       // Usage Page (Page# for LEDs)
        0x19, 0x01,       // Usage Minimum (1)
        0x29, 0x05,       // Usage Maximum (5)
        0x91, 0x02,       // Output (Data, Variable, Absolute), Led report
        0x91, 0x01,       // Output (Data, Variable, Absolute), Led report padding
        0x95, 0x06,       // Report Count (6)
        0x25, 0x65,       // Logical Maximum (101)
        0x05, 0x07,       // Usage Page (Key codes)
        0x19, 0x00,       // Usage Minimum (0)
        0x29, 0x65,       // Usage Maximum (101)
        0x81, 0x00,       // Input (Data, Array) Key array(6 bytes)
        0x09, 0x05,       // Usage (Vendor Defined)
        0x26, 0xFF, 0x00, // Logical Maximum (255)
        0x75, 0x08,       // Report Size (8 bit)
        0xB1, 0x02,       // Feature (Data, Variable, Absolute)
        0xC0              // End Collection (Application)
    memset((void *)input_report_array, 0, sizeof(ble_hids_inp_rep_init_t));
    memset((void *)output_report_array, 0, sizeof(ble_hids_outp_rep_init_t));
    memset((void *)feature_report_array, 0, sizeof(ble_hids_feature_rep_init_t));
    // Initialize HID Service
    p_input_report                      = &input_report_array[INPUT_REPORT_KEYS_INDEX];// INPUT_REPORT_KEYS_INDEX = 3
    p_input_report->max_len             = INPUT_REPORT_KEYS_MAX_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_ID;
    p_input_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_INPUT;
    p_input_report->sec.cccd_wr = SEC_JUST_WORKS;
    p_input_report->sec.wr      = SEC_JUST_WORKS;
    p_input_report->sec.rd      = SEC_JUST_WORKS;
    p_output_report                      = &output_report_array[OUTPUT_REPORT_INDEX];
    p_output_report->max_len             = OUTPUT_REPORT_MAX_LEN;
    p_output_report->rep_ref.report_id   = OUTPUT_REP_REF_ID;
    p_output_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_OUTPUT;
    p_output_report->sec.wr = SEC_JUST_WORKS;
    p_output_report->sec.rd = SEC_JUST_WORKS;
    p_feature_report                      = &feature_report_array[FEATURE_REPORT_INDEX];
    p_feature_report->max_len             = FEATURE_REPORT_MAX_LEN;
    p_feature_report->rep_ref.report_id   = FEATURE_REP_REF_ID;
    p_feature_report->rep_ref.report_type = BLE_HIDS_REP_TYPE_FEATURE;
    p_feature_report->sec.rd              = SEC_JUST_WORKS;
    p_feature_report->sec.wr              = SEC_JUST_WORKS;
    // Initialize HID Service.
    p_input_report                      = &input_report_array[INPUT_REP_BUTTONS_INDEX]; // INPUT_REP_BUTTONS_INDEX =0
    p_input_report->max_len             = INPUT_REP_BUTTONS_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_BUTTONS_ID;
    p_input_report                      = &input_report_array[INPUT_REP_MOVEMENT_INDEX]; // INPUT_REP_MOVEMENT_INDEX =1
    p_input_report->max_len             = INPUT_REP_MOVEMENT_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_MOVEMENT_ID;
    p_input_report                      = &input_report_array[INPUT_REP_MPLAYER_INDEX]; // INPUT_REP_MPLAYER_INDEX = 2
    p_input_report->max_len             = INPUT_REP_MEDIA_PLAYER_LEN;
    p_input_report->rep_ref.report_id   = INPUT_REP_REF_MPLAYER_ID;
    hid_info_flags = HID_INFO_FLAG_REMOTE_WAKE_MSK | HID_INFO_FLAG_NORMALLY_CONNECTABLE_MSK;
    memset(&hids_init_obj, 0, sizeof(hids_init_obj));
    hids_init_obj.evt_handler                    = on_hids_evt;
    hids_init_obj.error_handler                  = service_error_handler;
    hids_init_obj.is_kb                          = true;
    hids_init_obj.is_mouse                       = true;
    hids_init_obj.inp_rep_count                  = 4;
    hids_init_obj.p_inp_rep_array                = input_report_array;
    hids_init_obj.outp_rep_count                 = 1;
    hids_init_obj.p_outp_rep_array               = output_report_array;
    hids_init_obj.feature_rep_count              = 1;
    hids_init_obj.p_feature_rep_array            = feature_report_array;
    hids_init_obj.rep_map.data_len               = sizeof(report_map_data);
    hids_init_obj.rep_map.p_data                 = report_map_data;
    hids_init_obj.hid_information.bcd_hid        = BASE_USB_HID_SPEC_VERSION;
    hids_init_obj.hid_information.b_country_code = 0;
    hids_init_obj.hid_information.flags          = hid_info_flags;
    hids_init_obj.included_services_count        = 0;
    hids_init_obj.p_included_services_array      = NULL;
    hids_init_obj.rep_map.rd_sec         = SEC_JUST_WORKS;
    hids_init_obj.hid_information.rd_sec = SEC_JUST_WORKS;
    hids_init_obj.boot_kb_inp_rep_sec.cccd_wr = SEC_JUST_WORKS;
    hids_init_obj.boot_kb_inp_rep_sec.rd      = SEC_JUST_WORKS;
    hids_init_obj.boot_kb_outp_rep_sec.rd = SEC_JUST_WORKS;
    hids_init_obj.boot_kb_outp_rep_sec.wr = SEC_JUST_WORKS;
	hids_init_obj.boot_mouse_inp_rep_sec.cccd_wr = SEC_JUST_WORKS;
    hids_init_obj.boot_mouse_inp_rep_sec.wr      = SEC_JUST_WORKS;
    hids_init_obj.boot_mouse_inp_rep_sec.rd      = SEC_JUST_WORKS;
    hids_init_obj.protocol_mode_rd_sec = SEC_JUST_WORKS;
    hids_init_obj.protocol_mode_wr_sec = SEC_JUST_WORKS;
    hids_init_obj.ctrl_point_wr_sec    = SEC_JUST_WORKS;
    err_code = ble_hids_init(&m_hids, &hids_init_obj);
and below is the service's detail
Is there any thing do wrong?
