I am using Keil and nrf52 dev kit to write some UART over BLE code if I set a break-point in nus_data_handler() it cause a reset to run soon after stepping though some code and the BLE radio starts advertising even though I am stepping through code.
The SoftDevice will hardfault if you halt the CPU, the hardfault handler will reset the MCU.
I suggest you try Monitor Mode Debugging: https://github.com/NordicPlayground/j-link-monitoring-mode-debugging.
Can you do this with nrf52 S112 chip? I may be doing a project based on that as well but still up in the air....
This is great thanks so much!! I will try it within a few days.....
Yeah, it's a debugging feature made by ARM or Segger and it will work on any Cortex-M series CPU.
It relies upon standard features of the ARM Cortex-M architecture but, AFAIK, Segger is the only one to have an implementation that uses it:
https://community.st.com/s/question/0D50X00009nNQQnSAO/monitor-mode-debug-mmd-
Not on Cortex-M0 - so not on nRF51
nrf52 S112 chip
"S112" is the SoftDevice - it has nothing to do with the SoftDevice.
Note that you require at least a J-Link Plus for Monitor Mode Debug:
https://www.segger.com/products/debug-probes/j-link/technology/monitor-mode-debugging/ - see the FAQs
(but the on-board J-Link on the nRF52 DKs gives you an evaluation licence for it)
