Some delay while receiving sensor data using mesh proxy
Hi, I'm using proxy_client and proxy_server from light_switch examples of mesh sdkv2.1.1. The provision process gets successful with android mobile using nRF Mesh App but i face some issue while receiving sensor data, there is some delay(not getting data in flow) with putty.If i use without proxy (provisioner with DK board), i never face that issue.Can you please help me.
  • there is some delay
    There is always going to be some delay!
    So how much delay, exactly, are you getting ?
  • 5 to 10 seconds
  • Could you describe how exactly did you test and found the delay (not getting data in flow with putty) ?
    When you do your test do you have a phone connected to the device ? If you simply disconnect the phone would the issue go away ?
  • I was tested with and without phone connected in both situation i faced same issue. Data not getting in putty as flow continuously it stops for 5 to 10 seconds and starts getting data.. the delay is repeated
  • OK, please explain the data flow. How do you send it via mesh ? Then from that how to get to Putty   ? Please give as much information as possible.
1 2 3 4 5
