Ring buffer or queue for different datatype
I want to sample ADC signals and send data when requested via BLE or UART. I set a timer that triggers every 100 ms and gets ADC data.
To store the data, I would like to use some large buffer that will store incoming data. If the buffer reaches end limit and previous data isn't pulled out, it should overwrite the first data and while reading it should start reading from first data (of course not overwritten one) simple: FIFO with first in data replaceable if size full.
I think Ring buffer should solve my issue but the problem is with its data type. The datatype of ADC values is uint16_t while ring buffer has uint8_t so I have to break values in two 8 bytes and store them.
Ring Buffer
Queue library
I read a post about the difference between ring and queue here but it is a general discussion and states both are the same.
Could you please suggest what mechanism shall I use and do I need to modify nrf ring buffer library to support the required data type?
  • From the queue buffer docs: "The queue library provides interrupt secure implementation of the circular buffer to store predefined objects".
    Whether your data is accessed as uint8 or int16 does not really matter as long as you read and write to the ring buffer in multiples of two bytes, the data is still there.
  • Thank you for your response.
    I am little confused;
    The nrf_ringbuf_cpy_put API accepts data as uint8_t, so I can't put any other datatype like uint16_t or something so how will it work for my application?
    Fullscreen
    1
    2
    3
    ret_code_t nrf_ringbuf_cpy_put(nrf_ringbuf_t const * p_ringbuf,
    uint8_t const * p_data,
    size_t * p_length);
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    Let's say I want to store 5 bytes data so do I deliberately need to store 0 or some other value so that data becomes 6 which is multiple of 2 and ignore while retrieving it?
    Regards
     You store an array of data no matter what type it is. Whether you access the data as uint8 or int16 won't change the data itself.
    I suggest you read up on Type Casting and Pointer Type Casting in C as it is fundamental in understanding your problem and its solution.
    see f.ex. https://stackoverflow.com/questions/17260527/what-are-the-rules-for-casting-pointers-in-c/17260931
     Int16's are exactly two bytes of data. If you want to store 5 uint8's then you will need 5x1 bytes, but if you want to store 5 int16's as uint8's it will require 5x2 bytes.
    Thank you for your help.
    Sure, I will be doing the same.
  • HI ,
    Thank you for your help, I managed to implement it correctly.
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    NRF_RINGBUF_DEF(m_ringbuf, 8);
    ret_code_t err_code;
    nrf_ringbuf_init(&m_ringbuf);
    uint16_t data_in[] = {1024, 1025, 1026, 1027};
    size_t len_in = sizeof(data_in);
    err_code = nrf_ringbuf_cpy_put(&m_ringbuf, (uint8_t*)data_in, &len_in);
    uint16_t data_out[4];
    size_t len_out = sizeof(data_out);
    err_code = nrf_ringbuf_cpy_get(&m_ringbuf, (uint8_t*)data_out, &len_out);
    I am facing another issue.
    Let's say I have got 2 bytes of memory left and would like to copy 4 bytes of data. If I use
    nrf_ringbuf_cpy_put, I will get available length or copied length after copying the data.
    Is there a way I can get available length before copying so that I don't have to remove half written data or copy half data so that I can free (nrf_ringbuf_free) some data and then copy the data.
    e.g.
    ring_bufer(1,2,3,4,5,6)   // Data already present in buffer
    {7,8,9,10}  // New data to write
    Since only two bytes are left, ring buffer will write 7&8 and return available length.
    Regards
1 2
