Sorry to bother you in your holidays.I want to get an conversion every time by calling nrfx_saadc_sample( ) .So I had configure saadc like below.But I found the adc didn't call saadc_callback() sometime by calling nrfx_saadc_sample( ). What do I miss?Thanks for your reply.
* MACROS
#define ADC_DEFAULT_CONFIG \
.resolution = NRF_SAADC_RESOLUTION_12BIT, \
.oversample = NRF_SAADC_OVERSAMPLE_4X, \
.interrupt_priority = NRFX_SAADC_CONFIG_IRQ_PRIORITY, \
.low_power_mode = NRFX_SAADC_CONFIG_LP_MODE \
#define ADC_DEFAULT_LT_CHANNEL_CONFIG_SE(PIN_P) \
.resistor_p = NRF_SAADC_RESISTOR_DISABLED, \
.resistor_n = NRF_SAADC_RESISTOR_DISABLED, \
.gain = NRF_SAADC_GAIN1_4, \
.reference = NRF_SAADC_REFERENCE_VDD4, \
.acq_time = NRF_SAADC_ACQTIME_40US, \
.mode = NRF_SAADC_MODE_SINGLE_ENDED, \
.burst = NRF_SAADC_BURST_ENABLED, \
.pin_p = (nrf_saadc_input_t)(PIN_P), \
.pin_n = NRF_SAADC_INPUT_DISABLED \
#define ADC_DEFAULT_HT_CHANNEL_CONFIG_SE(PIN_P) \
.acq_time = NRF_SAADC_ACQTIME_10US, \
#define C_NOP __ASM volatile ("nop");
* Gobal Variable
bool adcFinishFlag = false;
* Local Variable
static bool adcCalibratedone = false;
static bool adcAbortFlag = false;
static nrf_saadc_value_t adcSampleBuffer[4] = { 0 };
* LOCAL FUNCTIONS
static nrf_saadc_input_t AdcChannelPort( uint8_t inputChannel );
* adc callback
static void saadc_callback(nrf_drv_saadc_evt_t const * p_event)
if ( p_event->type == NRF_DRV_SAADC_EVT_DONE )
if( adcAbortFlag )
adcFinishFlag = true;
else if( p_event->type == NRF_DRV_SAADC_EVT_CALIBRATEDONE )
adcCalibratedone = true;
* @fn InitAdcModule
* @brief initialzing Adc module
* @param none
* @return none
void InitAdcModule( )
ret_code_t err_code;
nrf_drv_saadc_config_t drv_saadc_cfg = ADC_DEFAULT_CONFIG;
err_code = nrf_drv_saadc_init( &drv_saadc_cfg, saadc_callback );
err_code = nrf_drv_saadc_calibrate_offset( );
if( err_code == NRFX_SUCCESS )
err_code = 0;
do{
C_NOP;
C_NOP;
C_NOP;
err_code++;
if( err_code >= 65536 )
}while( !adcCalibratedone );
* @fn InitAdcChannel
* @brief initialzing Adc channel
* @param sdcChannel: adc channel
* resistanceType: big resistance -> Low temperature
* low resistance -> High temperature
* @return none
void InitAdcChannel( uint8_t sdcChannel, check_type_t resistanceType )
nrf_saadc_input_t InputAIN;
InputAIN = AdcChannelPort( sdcChannel );
nrf_saadc_channel_config_t channel_config =
ADC_DEFAULT_LT_CHANNEL_CONFIG_SE(InputAIN);
if( resistanceType == HIGH_TEMPERATURE )
channel_config.acq_time = NRF_SAADC_ACQTIME_10US;
err_code = nrf_drv_saadc_channel_init( sdcChannel, &channel_config );
* @fn StartAdc
* @brief start sampling
* @param none
* @return none
void StartAdc( )
err_code = nrf_drv_saadc_buffer_convert( adcSampleBuffer, 2 );
err_code = nrfx_saadc_sample( );
* @fn StopAdc
* @brief stop sampling
* @param none
* @return none
void StopAdc( )
if( nrfx_saadc_is_busy( ) )
adcAbortFlag = true;
nrfx_saadc_abort( );
* @fn DisableAdcChannel
* @brief disable adc channel
* @param none
* @return none
void DisableAdcChannel( uint8_t channel )
err_code = nrfx_saadc_channel_uninit( channel );
* Logic Function
nrf_saadc_input_t channelAIN;
switch( inputChannel )
case 0:
channelAIN = NRF_SAADC_INPUT_AIN0;
case 1:
channelAIN = NRF_SAADC_INPUT_AIN1;
case 2:
channelAIN = NRF_SAADC_INPUT_AIN2;
case 3:
channelAIN = NRF_SAADC_INPUT_AIN3;
case 4:
channelAIN = NRF_SAADC_INPUT_AIN4;
case 5:
channelAIN = NRF_SAADC_INPUT_AIN5;
case 6:
channelAIN = NRF_SAADC_INPUT_AIN6;
case 7:
channelAIN = NRF_SAADC_INPUT_AIN7;
return channelAIN;
* Main
uint32_t main_code=0;
//bool erase_bonds;
// Initialize.
PortInit( );
log_init( );
timers_init( );
power_management_init( );
ble_stack_init( );
gap_params_init( );
gatt_init( );
services_init( );
advertising_init( );
conn_params_init( );
//peer_manager_init( );
// Start execution.
NRF_LOG_INFO("Application started.");
ApplicationParamterInit( );
application_timers_start( );
InitAdcModule( );
InitAdcChannel( 0, 0 );
StartAdc( );
// Enter main loop.
for (;;)
if( adcFinishFlag )
AdcMeasurePoll();
