nRF52810 saadc didn't work by calling nrfx_saadc_sample( )
 Sorry to bother you in your holidays.I want to get an conversion every time by calling nrfx_saadc_sample( ) .So I had configure saadc like below.But I found the adc didn't call saadc_callback() sometime by calling nrfx_saadc_sample( ). What do I miss?Thanks for your reply.
 * MACROS
#define ADC_DEFAULT_CONFIG                                     \
    .resolution         = NRF_SAADC_RESOLUTION_12BIT, 				 \
    .oversample         = NRF_SAADC_OVERSAMPLE_4X, 			 			 \
    .interrupt_priority = NRFX_SAADC_CONFIG_IRQ_PRIORITY,      \
    .low_power_mode     = NRFX_SAADC_CONFIG_LP_MODE            \
#define ADC_DEFAULT_LT_CHANNEL_CONFIG_SE(PIN_P) 		\
    .resistor_p = NRF_SAADC_RESISTOR_DISABLED,      \
    .resistor_n = NRF_SAADC_RESISTOR_DISABLED,      \
    .gain       = NRF_SAADC_GAIN1_4,                \
    .reference  = NRF_SAADC_REFERENCE_VDD4,     		\
    .acq_time   = NRF_SAADC_ACQTIME_40US,           \
    .mode       = NRF_SAADC_MODE_SINGLE_ENDED,      \
    .burst      = NRF_SAADC_BURST_ENABLED,         \
    .pin_p      = (nrf_saadc_input_t)(PIN_P),       \
    .pin_n      = NRF_SAADC_INPUT_DISABLED          \
#define ADC_DEFAULT_HT_CHANNEL_CONFIG_SE(PIN_P) 		\
    .acq_time   = NRF_SAADC_ACQTIME_10US,           \
#define		C_NOP			__ASM volatile ("nop");
 * 											Gobal Variable
bool adcFinishFlag = false;
 * 											Local Variable
static bool adcCalibratedone = false;
static bool adcAbortFlag = false;
static nrf_saadc_value_t adcSampleBuffer[4] = { 0 };
 * LOCAL FUNCTIONS
static nrf_saadc_input_t AdcChannelPort( uint8_t inputChannel );
 * adc callback
static void saadc_callback(nrf_drv_saadc_evt_t const * p_event)
    if ( p_event->type == NRF_DRV_SAADC_EVT_DONE )
			  if( adcAbortFlag )
						adcFinishFlag = true;
		else if( p_event->type == NRF_DRV_SAADC_EVT_CALIBRATEDONE )
				adcCalibratedone = true;
 * @fn      InitAdcModule
 * @brief   initialzing Adc module
 * @param   none
 * @return  none
void InitAdcModule( )
	  ret_code_t err_code;
		nrf_drv_saadc_config_t drv_saadc_cfg = ADC_DEFAULT_CONFIG;
    err_code = nrf_drv_saadc_init( &drv_saadc_cfg, saadc_callback );
		err_code = nrf_drv_saadc_calibrate_offset( );
		if( err_code == NRFX_SUCCESS )
				err_code = 0;
			  do{
						C_NOP;
						C_NOP;
						C_NOP;
						err_code++;
						if( err_code >= 65536 )
				}while( !adcCalibratedone );
 * @fn      InitAdcChannel
 * @brief   initialzing Adc channel
 * @param   sdcChannel: adc channel
 * 					resistanceType: big resistance -> Low temperature
 * 													low resistance -> High temperature
 * @return  none
void InitAdcChannel( uint8_t sdcChannel, check_type_t resistanceType )
	  nrf_saadc_input_t InputAIN;
	  InputAIN = AdcChannelPort( sdcChannel );
		nrf_saadc_channel_config_t channel_config =
       ADC_DEFAULT_LT_CHANNEL_CONFIG_SE(InputAIN);
		if( resistanceType == HIGH_TEMPERATURE )
				channel_config.acq_time = NRF_SAADC_ACQTIME_10US;
    err_code = nrf_drv_saadc_channel_init( sdcChannel, &channel_config );
 * @fn      StartAdc
 * @brief   start sampling
 * @param   none
 * @return  none
void StartAdc( )
	err_code = nrf_drv_saadc_buffer_convert( adcSampleBuffer, 2 );
	err_code = nrfx_saadc_sample( );
 * @fn      StopAdc
 * @brief   stop sampling
 * @param   none
 * @return  none
void StopAdc( )
	 if( nrfx_saadc_is_busy( ) )
			 adcAbortFlag = true;
			 nrfx_saadc_abort( );
 * @fn      DisableAdcChannel
 * @brief   disable adc channel
 * @param   none
 * @return  none
void DisableAdcChannel( uint8_t channel )
	 err_code = nrfx_saadc_channel_uninit( channel );
 * 										Logic Function
	  nrf_saadc_input_t  channelAIN;
		switch( inputChannel )
				case 0:
					channelAIN = NRF_SAADC_INPUT_AIN0;
				case 1:
					channelAIN = NRF_SAADC_INPUT_AIN1;
				case 2:
					channelAIN = NRF_SAADC_INPUT_AIN2;
				case 3:
					channelAIN = NRF_SAADC_INPUT_AIN3;
				case 4:
					channelAIN = NRF_SAADC_INPUT_AIN4;
				case 5:
					channelAIN = NRF_SAADC_INPUT_AIN5;
				case 6:
					channelAIN = NRF_SAADC_INPUT_AIN6;
				case 7:
					channelAIN = NRF_SAADC_INPUT_AIN7;
	 return channelAIN;
 *                  Main
		uint32_t main_code=0;
    //bool erase_bonds;
    // Initialize.
	  PortInit( );
    log_init( );
    timers_init( );
    power_management_init( );
    ble_stack_init( );
    gap_params_init( );
    gatt_init( );
    services_init( );
		advertising_init( );
    conn_params_init( );
    //peer_manager_init( );
    // Start execution.
    NRF_LOG_INFO("Application started.");
	  ApplicationParamterInit( );
    application_timers_start( );
	InitAdcModule( );
	InitAdcChannel( 0, 0 );
	StartAdc( );
    // Enter main loop.
    for (;;)
		if( adcFinishFlag )
    	    AdcMeasurePoll();
  • You won't get a callback until you've filled your buffer. You initialized your buffer with a size of two, but you only took one sample.
  • Sorry for the late reply. Sorry again.I had posted the test code.There is my code below.
     * MACROS
     * 											Gobal Variable
     * 											Local Variable
     * LOCAL FUNCTIONS
     * adc callback
    			  if( adcAbortFlag )
     * @fn      InitAdcModule
     * @param   none
     * @return  none
    				err_code = 0;
    			  do{
    						C_NOP;
    						C_NOP;
    						C_NOP;
    						err_code++;
     * @return  none
     * @fn      StartAdc
     * @param   none
     * @return  none
    void StartAdc( )
     * @fn      StopAdc
     * @param   none
     * @return  none
    void StopAdc( )
     * @param   none
     * @return  none
     * 										Logic Function
    				case 0:
    				case 1:
    				case 2:
    				case 3:
    				case 4:
    				case 5:
    				case 6:
    				case 7:
    	 return channelAIN;
    void ParamterInit( )
       fristGroupFlag = true;
       secondGroupFlag = false;
       timerOutFlag = false;
       sampleCnt = 0;
     *                  Main
        //bool erase_bonds;
        // Initialize.
    	  PortInit( );
        log_init( );
        timers_init( );
        ble_stack_init( );
        gap_params_init( );
        gatt_init( );
        services_init( );
        // Start execution.
    	InitAdcModule( );
    	InitAdcChannel( 1, 0 );
    	StartAdc( );
        // Enter main loop.
        for (;;)
    		if( adcFinishFlag )
        	    //AdcMeasurePoll();
        	    if( fristGroupFlag )
        	         SampleTransfer( adcSampleBuffer );
        	         sampleCnt++;
        	         if( sampleCnt>= 4 )
        	             sampleCnt = 0;
        	             DisableAdcChannel(0);
        	             DisableAdcChannel(1);
        	             fristGroupFlag = false;
        	             secondGroupFlag = true;
        	             InitAdcChannel( 2, 0 );
    	                 InitAdcChannel( 3, 0 );
    	                 StartAdc( );
        	             StartAdc( );
        	    else if( secondGroupFlag )
        	         sampleCnt++;
        	         if( sampleCnt>= 4 )
        	             sampleCnt = 0;
        	             SimpleFinishHandle( );
        	             startAdcTimer( );              //500ms time out
        	             StartAdc( );
            if( timerOutFlag )  //500ms
                 sampleCnt = 0;
    	         StartAdc( );
  • Try this:
    void StartAdc( )
    	err_code = nrf_drv_saadc_buffer_convert( adcSampleBuffer, 2 ); // Needs two samples to get a callback
    	err_code = nrfx_saadc_sample( ); // Take a second sample
  • Hi haakonsh,
     I had tried.adcSampleBuffer[0] is used to store conversion of saadc channel 0,adcSampleBuffer[1] is used to store conversion of saadc channel 1. At the first time both SampleBuffer[0] and SampleBuffer[1] are correct.But value of SampleBuffer[1]  became the same as  SampleBuffer[0]  after a while.Why?
