App uart error
Hi All
I am working on nrf52832 but not using the SDK. how ever I had created the uart functionality on my nrf but many times I got the communication error.
I had taken the references from the uart example provided in the sdk and using APP uart example I created this uart setup.
I am trying to communicate nrf with esp over uart.
But I am failed in sending and receiving data.
Can I get some help in that.
 * Copyright (c) 2017, CoolR Group Inc
 * All Rights Reserved.
 * File: uart.c
 * Description:  APIs for accessing SoC uart
 * Author: VAIBHAV
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <ctype.h>
#include <string.h>
#include <stdlib.h>
#include "uart.h"
#include "config.h"
#include "nrf_gpio.h"
#include "coolerBoard.h"
#include "debug.h"
#include "nrf_delay.h"
#include "app_uart.h"
#include "esp.h"
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
#define UART_INST 0
//nrf_drv_uart_t  uart_nrf = NRF_DRV_UART_INSTANCE(UART_INST);
 * Initialization of the uart peripheral.
 * @param uart_config_t uartConfig
 * 		  Configuration structure for initialising uart
 * @return error code
    static uint8_t data_array[40];
    static uint8_t index = 0;
    uint32_t err_code;
    switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if(data_array[index -1] == 0x0A && data_array[index -2] == 0x0D)
                    esp_parse_data(data_array,index);
                    index = 0;
                print(LL_PRINT,"COMMUNICATION ERROR\r\n");
            case APP_UART_FIFO_ERROR:
               print(LL_PRINT,"FIFO ERROR\r\n");
ret_code_t uartInit(uart_config_t uartConfig, nrf_uart_event_handler_t uart_event_handler)
 /*   ret_code_t ret = NRF_SUCCESS;
    const nrf_drv_uart_config_t config =
        .pseltxd = uartConfig.tx_pin,
        .pselrxd = uartConfig.rx_pin,
        .baudrate = (nrf_uart_baudrate_t)uartConfig.baudrate,
        .interrupt_priority = uartConfig.intr_priotity,
        .hwfc = uartConfig.hwfc,
        .parity = uartConfig.parity,
        .p_context = NULL,
    ret = nrf_drv_uart_init( &uart_nrf, &config, uart_event_handler );
    return ret;	*/
    uint32_t err_code;
            .rx_pin_no = uartConfig.rx_pin,
            .tx_pin_no = uartConfig.tx_pin,
            .use_parity = false,
            .baud_rate = (nrf_uart_baudrate_t)uartConfig.baudrate,
    APP_UART_FIFO_INIT(&comm_params,UART_RX_BUF_SIZE,UART_TX_BUF_SIZE,uart_event_handle,APP_IRQ_PRIORITY_HIGHEST,err_code);
    return err_code;
ret_code_t uartUnInit()
//    nrf_drv_uart_uninit(&uart_nrf);
    return ret;
 * uart Receive
 * @param p_data - Pointer to the data
 * @param length - Number of bytes to Receive
ret_code_t uartReceive(uint8_t * p_data,uint8_t length)
 /*   ret = nrf_drv_uart_rx(&uart_nrf, p_data, length);
    if(ret != NRF_SUCCESS)
            print(LL_ERROR,"UART RECEIVE ERROR\r\n");
    return ret;
 * uart Transmit
 * @param length - Number of bytes to Send
ret_code_t uartTransmit(uint8_t  const * const  p_data,uint32_t length)
    uint8_t data[200];
    if(p_data == NULL)
		ret = NRF_ERROR_INVALID_PARAM;
		return ret;
	if(length != 0)
        memcpy(&data[0], &p_data[0], length);
    for (uint32_t i = 0; i < length;i++)
        //print(LL_PRINT, "%X ", data[i]);
        ret  = app_uart_put(data[i]);
                print(LL_PRINT,"UART DATA SENDING FAILED\r\n");
    return ret;
Please review and let me know the issue.
  • Then I am tried this setup for my application, but every time I got COMMUNICATION ERROR
     * File: uart.c
     * Author: VAIBHAV
    #include <stdint.h>
    #include <stdio.h>
    #include <ctype.h>
    #include <string.h>
    #include <stdlib.h>
    #include "uart.h"
    #include "config.h"
    #include "debug.h"
    #include "esp.h"
    #define UART_INST 0
    static uint8_t index_esp = 0;
    uint8_t test_buffer[1];
    void uart_event_handle(nrf_drv_uart_event_t * p_event,void *p_context)
        uint32_t err_code;
        switch (p_event->type)
                case NRF_DRV_UART_EVT_RX_DONE:
                    nrf_drv_uart_rx(&uart_nrf,test_buffer,1);
                    print(LL_PRINT,"%x",test_buffer[0]);
                    data_array[index_esp] = test_buffer[0];
                    index_esp++;
                    if(data_array[index_esp -1] == 0x0A && data_array[index_esp -2] == 0x0D)
                        esp_parse_data(data_array,index_esp);
                        index_esp = 0;
                case NRF_DRV_UART_EVT_ERROR:
        nrf_drv_uart_config_t config = NRF_DRV_UART_DEFAULT_CONFIG;
        config.pseltxd = uartConfig.tx_pin;
        config.pselrxd = uartConfig.rx_pin;
        config.baudrate = (nrf_uart_baudrate_t)uartConfig.baudrate;
        config.interrupt_priority = uartConfig.intr_priotity;
        config.hwfc = uartConfig.hwfc;
        config.parity = uartConfig.parity;
        config.p_context = NULL;
        ret = nrf_drv_uart_init( &uart_nrf, &config, uart_event_handle);
        return (nrf_drv_uart_rx(&uart_nrf,test_buffer,1) && ret);
    /*    uint32_t err_code;
        return err_code;*/
        return ret;
     * uart Receive
        return ret;
     * uart Transmit
        uint8_t data[200];
        if(p_data == NULL)
    		return ret;
    	if(length != 0)
        /*for (uint32_t i = 0; i < length;i++)
        while (nrf_drv_uart_tx(&uart_nrf,data, length) != NRF_SUCCESS){;}
        return ret;
  • I verified over oscilloscope that 9600 baudrate I am getting the baudrate of 9466.
    This mis match cause the error in communication between NRF and ESP.
    Can I have any help in this.
