I want to use app(nrf uart 2.0)
so, I try to change UUID,
but I don't know how make custom uuid and use it
and I don't find function(ble_cs_init())
hlep me, please
So you want to use the UART service? Are you using the UART example code (Experimental: UART/Serial Port Emulation over BLE ) ? Have a look at the documentation for that example
Under the section "Adding proprietary service and characteristic" you can see that the Nordic UART Service is added to the SoftDevice as follows in the ble_nus.c file:
// Add custom base UUID.
err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_nus->uuid_type);
if (err_code != NRF_SUCCESS)
return err_code;
ble_uuid.type = p_nus->uuid_type;
ble_uuid.uuid = BLE_UUID_NUS_SERVICE;
// Add service.
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
&ble_uuid,
&p_nus->service_handle);
Here you can see that the base UUID is given in nus_base_uuid which is defined on line 227 in the same file. The UUID for the service and the TX/RX characteristics are defined in the header file. (ble_nus.h)
#define BLE_UUID_NUS_SERVICE 0x0001 /**< The UUID of the Nordic UART Service. */
#define BLE_UUID_NUS_TX_CHARACTERISTIC 0x0002 /**< The UUID of the TX Characteristic. */
#define BLE_UUID_NUS_RX_CHARACTERISTIC 0x0003 /**< The UUID of the RX Characteristic. */
