Regarding setting Tx power to +8dbm
 I am using Nordic nRF52840 SoC with nRF5_SDK_15.2.0_9412b96(SDK) and S140 softdevice. I tried to set Tx power to +8dbm using
rc = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV ,m_adv_handle,+8); after calling advertising_init(); in ble_app_multipepripheral example.But when i see the RSSI signal in mobile using nRF connect for mobile app its showing maximum of -15dbm instead of +8dbm when i place the mobile near the device. The ret_code(rc) of this api sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV ,m_adv_handle,+8); is 0 when i printed which means NRF_SUCCESS.Can anyone please help me why its showing -15dbm instead of +8dbm?
  • when i see the RSSI signal in mobile using nRF connect for mobile app its showing maximum of -15dbm instead of +8dbm
    Of course you won't see +8dBm !
    "RSSI" = Received Signal Strength Indication - it is what your phone is receiving - not what the peripheral is transmitting!
  • Hi awneil,
    When I place the mobile near the device, Mobile should receive almost the same signal strength transmitted by peripheral?
    Is there any way to know whether peripheral is transmitting 8dbm signal or not?
  • Ok awneil. Thank you.
    My application requires Tx and Rx are 100m apart needs to be connected and data transmission should happen. But with current power setting Tx and Rx are not getting connected. So, I am trying to understand whether I am utilizing total Tx power or not.
  • You don't need +8dBm for 100m distance if your device is properly tune and if light of sight, out door. +4dBm should be enough. Make sure you device is properly tuned. We would suggest you to test using our nRF52 DK.
  • Hi Hung,
      If it supports 100m distance with +4dBm, then power requirements also less. Thanks for the suggestion. But my application requires devices may not be in the line of sight and surrounded by metals. So, I am thinking of using +8dBm to meet the requirements. Will +8dBm works for my application?
    I don't have nRF52 DK right now. I will try to get it and test on it.
  • It's not possible to estimate the range without actual measurements and tests. Many factors can affect the actual range.
  • Ok, Hung, I will work on it. Thanks for the support.
