Acknowledged transaction status callback in Mesh SDK
I am using the reliable message communication to measure Round-trip time based on the Light switch example.
I noticed that in high traffics, some packets are not acknowledged and the log on the client side is "Acknowledged transfer cancelled".
However, I am not sure when this situation happens exactly?
Is it possible that the packet is arrived and processed by server but the acknowledgment is lost?
Or can I use this as a metric to show the packet loss percentage?
Thanks in advance!
  • Hi Pegah,
    It's pretty strange to receive "Acknowledged transfer cancelled". This should only happen if access_model_reliable_cancel() is called.
    Could you check in your code where it's called ? In our light switch client example it's called when button 0 or 1 is pressed.
    If there is a timeout due to packet loss (retransmitted 3 times with no ACK), ACCESS_RELIABLE_TRANSFER_TIMEOUT ("Acknowledged transfer timeout") should return instead.
  • Hi Hung,
    Thank you for you reply.
    I am using mesh SDK v2.2 and proxy client and server. I modified the light switch example to setup an application timer in client which starts by pressing the button number 0.
    Then in the handler of the timer in client, I send on off messages the same as it is done in the original client button event handler.  I attached the my timer handler code where I am sending the messages.
    static void repeated_timer_handler(void * p_context)
      bool flag = hal_led_pin_get(BSP_LED_0);
       uint32_t status = NRF_SUCCESS;
       generic_onoff_set_params_t set_params;
       model_transition_t transition_params;
       static uint8_t tid = 0;
       if(flag == false)
           set_params.on_off = APP_STATE_ON;
            set_params.on_off = APP_STATE_OFF;
        set_params.tid = tid++;
        transition_params.delay_ms = APP_CONFIG_ONOFF_DELAY_MS;
        transition_params.transition_time_ms = APP_CONFIG_ONOFF_TRANSITION_TIME_MS;
        NRF_LOG_INFO("Send msg\n");
       (void)access_model_reliable_cancel(m_clients[0].model_handle);
       status = generic_onoff_client_set(&m_clients[0], &set_params, &transition_params);
       hal_led_pin_set(BSP_LED_0, set_params.on_off);
        switch (status)
            case NRF_SUCCESS:
            case NRF_ERROR_NO_MEM:  NRF_LOG_INFO("Client no mem\n");
            case NRF_ERROR_BUSY:  NRF_LOG_INFO("Client busy\n");
            case NRF_ERROR_INVALID_STATE:
            NRF_LOG_INFO("Client cannot send\n");
                hal_led_blink_ms(LEDS_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
            case NRF_ERROR_INVALID_PARAM:
                /* Publication not enabled for this client. One (or more) of the following is wrong:
                 * - An application key is missing, or there is no application key bound to the model
                 * - The client does not have its publication state set
                 * It is the provisioner that adds an application key, binds it to the model and sets
                 * the model's publication state.
                NRF_LOG_INFO("Publication not configured for client \n")
                ERROR_CHECK(status);
    As you said, I checked and I see that
    in the original light switch, access_model_reliable_cancel is called right before calling generic_onoff_client_set(). That's why I did the same thing.
    Could you please let me know what is the use of this method? And what are the impact of removing it?
  • This is only for demonstration that you can cancel a pending transaction to start a new one.
    If you want each transaction to be transmit and retransmited X times before it's timeout, you should not call that function.  In that case generic_onoff_client_set() will return NRF_ERROR_BUSY until either you get an ACK or there is a ACCESS_RELIABLE_TRANSFER_TIMEOUT.
