My UART is going into a NO_MEMORY error after trying to transmit a single byte. When i try and put the second letter on the transmit buffer, it gives err_code = 4. I tried to use the example but when i compiled and uploaded the example project it just doesn't work either. Not sure if because i am working with a custom board. On the debugger i can see it is cycling through the string as it should as i see it transmit 'H' and the next letter i try and transmit is 'e'. but it goes into error mode.
Also as a side note I am trying to update the fds sample file which also has a CLI implementation. I am trying to remove that to see if it works. There really needs to be a document of necessary imports into the sdk_config.h file of what you need for each aspect. Maybe there is and I haven't found it. Like you want to use UART then you need to include these declarations for the libraries to work.
#define RX_BUF_SIZE 128 /**< Size of desired RX buffer, must be a power of 2 or ZERO (No FIFO). */
#define TX_BUF_SIZE 128 /**< Size of desired TX buffer, must be a power of 2 or ZERO (No FIFO) */
const app_uart_comm_params_t comm_params =
.rx_pin_no = RX_PIN, //RX_PIN = P0.06
.tx_pin_no = TX_PIN, //TX_PIN = P0.08
.rts_pin_no = -1,
.cts_pin_no = -1,
//Below values are defined in ser_config.h common for application and connectivity
.use_parity = false,
.baud_rate = UART_BAUDRATE_BAUDRATE_Baud9600
void uart_init(void){
uint32_t err_code;
uid[0] = (char)0;
nrf_gpio_cfg_input(RX_PIN, NRF_GPIO_PIN_PULLUP);
nrf_gpio_cfg_output(TX_PIN);
RX_BUF_SIZE,
TX_BUF_SIZE,
uart_evt_callback,
UART_IRQ_PRIORITY,
err_code);
void uart_putstring(const uint8_t * str)
uint32_t err_code;
uint8_t len = strlen((char *) str);
for (int i = 0; i < len; i++)
err_code = app_uart_put(str[i]);
nrf_delay_us(1250);
void uart_test(void){
uart_putstring("Hello World");
int main(void){
uart_init();
while(true){
uart_test();
nrf_delay_ms(1000);
