How to combine application and bootloader in the same ZIP file
I'm using SDK15.3.0, softdevice S132 v6.1.1 and we would like to know if it is possible to combine the application and the bootloader in the same ZIP file in order to perform only one DFU. We have several boards to update and it could be quite long.
I saw this threah : https://devzone.nordicsemi.com/f/nordic-q-a/24347/combined-bootloader-and-application-update and it seems it wasn't possible with the previous versions.
I tried the following command :
 nrfutil pkg generate --application master_app.hex ^Capplication-version 304 --bootloader master_dfu.hex --bootloader-version 1 --hw-version 1152 --sd-req 0xB7 --key-file ../../../sources/common/cles.pem master_3_04_dfu_1_00.zip
But it returns :
Error: Invalid combination: use two .zip packages instead.
Do i miss something or it is still not possible to combine the application and the bootloader in one ZIP file ?
Aurélien
