Hello there,
I've been following a guide Installing a 6LoWPAN enabled Linux kernel and required modules as a part of setting up a BLE 6LoWPAN border router on Raspberry Pi.
I'm using the cross-compiling option on my virtual machine with Ubuntu. So far, I've successfully managed to compile the kernel and modules (go through parts 1-5 in the Cross-Compilation section of tutorial). As a note, it was also necessary to install several additional packages using apt-get, which is not mentioned in the guide, namely bison, flex and libssl-dev.
However I'm stuck on the next step regarding generation .deb packages. Process execution always stalls indefinitely in the same place and doesn't return. I've tested this on several virtual machines and also on the cloud server.
Testing commands like htop say that at this point, original make-kpkg process is sleeping and there are no other running processes regarding this task.
Here are the logs I get:
root:~/raspbian/kernel/linux# DEB_HOST_ARCH=armhf fakeroot make-kpkg --append-to-version my-raspi-debbie --revision=1.0 --ARCH=arm --cross-compile ${CCPREFIX} kernel_headers -j5
exec make kpkg_version=13.018+nmu1 -f /usr/share/kernel-package/ruleset/minimal.mk debian DEBIAN_REVISION=1.0 APPEND_TO_VERSION=my-raspi-debbie KPKG_ARCH=arm CROSS_COMPILE=/root/raspbian/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf-
dpkg-architecture: warning: specified GNU system type arm-linux-gnu does not match CC system type x86_64-linux-gnu, try setting a correct CC environment variable
====== making target debian/stamp/conf/minimal_debian [new prereqs: ]======
This is kernel package version 13.018+nmu1.
test -d debian || mkdir debian
test ! -e stamp-building || rm -f stamp-building
install -p -m 755 /usr/share/kernel-package/rules debian/rules
for file in ChangeLog Control Control.bin86 config templates.in rules; do \
cp -f /usr/share/kernel-package/$file ./debian/; \
done
cp: cannot stat '/usr/share/kernel-package/ChangeLog': No such file or directory
for dir in Config docs examples ruleset scripts pkg po; do \
cp -af /usr/share/kernel-package/$dir ./debian/; \
done
test -f debian/control || sed -e 's/=V/4.19.59my-raspi-debbie/g' \
-e 's/=D/1.0/g' -e 's/=A/armhf/g' \
-e 's/=SA//g' \
-e 's/=I//g' \
-e 's/=CV/4.19/g' \
-e 's/=M/Unknown Kernel Package Maintainer <[email protected]>/g' \
-e 's/=ST/linux/g' -e 's/=B/arm/g' \
-e 's/=R//g' /usr/share/kernel-package/Control > debian/control
test -f debian/changelog || sed -e 's/=V/4.19.59my-raspi-debbie/g' \
/usr/share/kernel-package/changelog > debian/changelog
chmod 0644 debian/control debian/changelog
test -d ./debian/stamp || mkdir debian/stamp
make -f debian/rules debian/stamp/conf/kernel-conf
make[1]: Entering directory '/root/raspbian/kernel/linux'
====== making target debian/stamp/conf/kernel-conf [new prereqs: ]======
make EXTRAVERSION=my-raspi-debbie CROSS_COMPILE=/root/raspbian/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf- ARCH=arm \
oldconfig;
make[2]: Entering directory '/root/raspbian/kernel/linux'
scripts/kconfig/conf --oldconfig Kconfig
# configuration written to .config
make[2]: Leaving directory '/root/raspbian/kernel/linux'
make EXTRAVERSION=my-raspi-debbie CROSS_COMPILE=/root/raspbian/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf- ARCH=arm prepare
scripts/kconfig/conf --syncconfig Kconfig
CALL scripts/checksyscalls.sh
echo done > debian/stamp/conf/kernel-conf
make[1]: Leaving directory '/root/raspbian/kernel/linux'
make -f debian/rules debian/stamp/conf/full-changelog
====== making target debian/stamp/conf/full-changelog [new prereqs: ]======
done
done
sed -e 's/=V/4.19.59my-raspi-debbie-v7+/g' \
-e 's/=SA//g' \
-e 's/=I//g' \
-e 's/=CV/4.19/g' \
sed -e 's/=V/4.19.59my-raspi-debbie-v7+/g' -e 's/=D/1.0/g' \
-e 's/=A/armhf/g' -e 's/=M/Unknown Kernel Package Maintainer <[email protected]>/g' \
make[2]: 'debian/stamp/conf/kernel-conf' is up to date.
echo done > debian/stamp/conf/minimal_debian
exec debian/rules DEBIAN_REVISION=1.0 APPEND_TO_VERSION=my-raspi-debbie KPKG_ARCH=arm CROSS_COMPILE=/root/raspbian/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf- kernel_headers
root@Tonko:~/raspbian/kernel/linux# # DEB_HOST_ARCH=armhf fakeroot make-kpkg --append-to-version my-raspi-debbie --revision=1.0 --ARCH=arm --cross-compile ${CCPREFIX} --initrd kernel_image kernel_headers -j5
Error: Unknown target k
use --targets to display help on valid targets.
root@Tonko:~/raspbian/kernel/linux# DEB_HOST_ARCH=armhf fakeroot make-kpkg --append-to-version my-raspi-debbie --revision=1.0 --ARCH=arm --cross-compile ${CCPREFIX} --initrd kernel_image kernel_headers -j5
exec make kpkg_version=13.018+nmu1 -f /usr/share/kernel-package/ruleset/minimal.mk debian DEBIAN_REVISION=1.0 APPEND_TO_VERSION=my-raspi-debbie KPKG_ARCH=arm CROSS_COMPILE=/root/raspbian/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf- INITRD=YES
done
done
-e 's/=SA//g' \
-e 's/=I//g' \
-e 's/=CV/4.19/g' \
-e 's/=R/initramfs-tools | linux-initramfs-tool,/g' /usr/share/kernel-package/Control > debian/control
oldconfig;
done
done
-e 's/=SA//g' \
-e 's/=I//g' \
-e 's/=CV/4.19/g' \
exec debian/rules DEBIAN_REVISION=1.0 APPEND_TO_VERSION=my-raspi-debbie KPKG_ARCH=arm CROSS_COMPILE=/root/raspbian/tools/arm-bcm2708/gcc-linaro-arm-linux-gnueabihf-raspbian-x64/bin/arm-linux-gnueabihf- INITRD=YES kernel_image kernel_headers
