Can not make scan_req_notification working...
Hi!
I am trying to get scan_req_notification to fire notifications when central devices issue scan reqs but without success until now. Here is my code:
Env: SDK15, SES, nrf52DK
In a ble template derived project, in the advertising_start() function I added this code before calling ble_advertising_start():
m_advertising.adv_params.scan_req_notification = 1;
m_advertising.adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_SCANNABLE_UNDIRECTED;
ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
Then from the ble_cus_on_ble_evt (observer) handler, I added a new case with:
case BLE_GAP_EVT_SCAN_REQ_REPORT:
            printf("\n SCAN_REQ called ...\n");
            const ble_gap_evt_t   * p_gap_evt = &p_ble_evt->evt.gap_evt;
I also added a breakpoint to the printf line
However, the BLE_GAP_EVT_SCAN_REQ_REPORT notification is never fired when using nRFConnect app or a Linux Bluez C app used for scan BLE devices. This linux C app was configured in order to do scan request:
le_set_scan_parameters_cp scan_params_cp;
memset(&scan_params_cp, 0, sizeof(scan_params_cp));
scan_params_cp.type   = 0x01; //00 Passive 01 Active
What am I doing wrong?
Thanks
Alex
    I tested enabling the scan request notifications, and it works here. What SDK version do you use? SDK15.3.0?
    I tested on both SDK15.3.0 and SDK15.0.0, and it worked in both.
    Where did you insert the line:
    The reason I ask is that in ble_advertising.c where the ble_advertising_start() function is defined, it uses p_advertising, and not m_advertising. Can you try to add it inside the ble_advertising_start() function?
    Also, I don't know how your ble_cus_on_ble_evt() is set up, but can you try to add the case BLE_GAP_EVT_SCAN_REQ_REPORT in ble_evt_handler() in main.c as well? Do you get the event there?
    One last thing: printf() is used in among others the ble_app_uart example, but it is not necessarily set up in the other examples. Do you see the other messages that you print using printf()?
    Edvin
  • Hi!
    The SDK I am using is nRF5_SDK_15.3.0_59ac345 and SD is S132 6.6.1
    m_advertising is a global variable declared like this inside main.c
    BLE_ADVERTISING_DEF(m_advertising);
    I openned ble_advertising.c and inside ble_advertising_start function I added
    p_advertising->adv_params.scan_req_notification = 1;
    right before
    sd_ble_gap_adv_set_configure and sd_ble_gap_adv_start calls
    I moved BLE_GAP_EVT_SCAN_REQ_REPORT to main.c ble_evt_handler()...
    and now it works!
    Then I moved again scan_req_notification = 1;
    into the main.c again like:
    but did not work...
    It seems that m_advertising global variable declared like this:
    does not override the advertising settings when called in main with:
    But it is ok, at least now this can works when adding it directly into ble_advertising.c
    Thanks a lot!
    Alex
