Hi!
I am trying to use serial port library with Free RTOS (SDK 15.3). I created a read task but when I try to read, the function does sometimes receive wrong bytes. I also get "NRF_SERIAL_EVENT_DRV_ERR" events when adding an event handler. Does anybode know why?
Following my code:
static void sleep_handler(void) { __WFE(); __SEV(); __WFE(); } NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte0_drv_config, RX_PIN_NUMBER, ARDUINO_SCL_PIN, RTS_PIN_NUMBER, CTS_PIN_NUMBER, NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED, NRF_UART_BAUDRATE_115200, UART_DEFAULT_CONFIG_IRQ_PRIORITY); NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uarte1_drv_config, ARDUINO_SDA_PIN, TX_PIN_NUMBER, RTS_PIN_NUMBER, CTS_PIN_NUMBER, NRF_UART_HWFC_DISABLED, NRF_UART_PARITY_EXCLUDED, NRF_UART_BAUDRATE_115200, UART_DEFAULT_CONFIG_IRQ_PRIORITY); #define SERIAL_FIFO_TX_SIZE 32 #define SERIAL_FIFO_RX_SIZE 32 NRF_SERIAL_QUEUES_DEF(serial0_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE); NRF_SERIAL_QUEUES_DEF(serial1_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE); #define SERIAL_BUFF_TX_SIZE 1 #define SERIAL_BUFF_RX_SIZE 1 NRF_SERIAL_BUFFERS_DEF(serial0_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE); NRF_SERIAL_BUFFERS_DEF(serial1_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE); NRF_SERIAL_CONFIG_DEF(serial0_config, NRF_SERIAL_MODE_DMA, &serial0_queues, &serial0_buffs, NULL, sleep_handler); NRF_SERIAL_CONFIG_DEF(serial1_config, NRF_SERIAL_MODE_DMA, &serial1_queues, &serial1_buffs, NULL, sleep_handler); NRF_SERIAL_UART_DEF(serial0_uarte, 0); NRF_SERIAL_UART_DEF(serial1_uarte, 1); void UART_Read_Task() { char c; ret_code_t ret; while(true) { ret = nrf_serial_read(&serial0_uarte, &c, sizeof(c), NULL, 0); if (ret == NRF_SUCCESS) { // todo } ret = nrf_serial_read(&serial1_uarte, &c, 1, NULL, 0); if (ret == NRF_SUCCESS) { // todo } } } int main(void) { ret_code_t ret; ret = nrf_drv_clock_init(); APP_ERROR_CHECK(ret); ret = nrf_drv_power_init(NULL); APP_ERROR_CHECK(ret); nrf_drv_clock_lfclk_request(NULL); ret = app_timer_init(); timers_init(); APP_ERROR_CHECK(ret); log_init(); // Initialize LEDs and buttons. bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS); ret = nrf_serial_init(&serial0_uarte, &m_uarte0_drv_config, &serial0_config); APP_ERROR_CHECK(ret); ret = nrf_serial_init(&serial1_uarte, &m_uarte1_drv_config, &serial1_config); APP_ERROR_CHECK(ret); // other stuff here if (pdPASS != xTaskCreate(UART_Read_Task, "UART_Read", USBD_STACK_SIZE, NULL, 1, &m_UART_Read_thread)) { APP_ERROR_HANDLER(NRF_ERROR_NO_MEM); } // Activate deep sleep mode. SCB->SCR |= SCB_SCR_SLEEPDEEP_Msk; // Start FreeRTOS scheduler. vTaskStartScheduler(); for (;;) { APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN); } }
