"app_uart_close()" cannot disable UART
Hi I am now working on a project which I use ble_app_uart_c as a reference. SDK 15.2 and used softdevice s132. In the project I need to disable the UART before it enters into System ON sleep mode. But when I measure the current using the PPK, the current consumption doesn't change after I close the UART using "app_uart_close". In the following snippet, you will see, I just initialize the UART module and close it after 5seconds. But the current consumption is still the same as shown in the figurre.
static void uart_init(void)
		.rx_pin_no    = 8/*RX_PIN_NUMBER*/,
		.tx_pin_no    = 6/*TX_PIN_NUMBER*/,
		.use_parity   = false,
#if defined (UART_PRESENT)
		.baud_rate    = UARTE_BAUDRATE_BAUDRATE_Baud115200
#else
		.baud_rate    = NRF_UARTE_BAUDRATE_115200
	                   UART_RX_BUF_SIZE,
	                   UART_TX_BUF_SIZE,
	                   uart_event_handle,
	                   APP_IRQ_PRIORITY_LOWEST,
	                   err_code);
	uart_init();
	nrf_delay_ms(5000);
	app_uart_close();
	nrf_delay_ms(100);
	for(;;)
		idle_state_handle();
Here is the one in which I just directly goes to system ON sleep and the current consumption is way more reduced.
	//uart_init();
	nrf_delay_ms(5000);
	//app_uart_close();
	nrf_delay_ms(100);
	for(;;)
What's the reason for this. Is there any more else to do to disable UART totally? Really needs your help. Thanks.
