"app_uart_close()" cannot disable UART
Hi I am now working on a project which I use ble_app_uart_c as a reference. SDK 15.2 and used softdevice s132. In the project I need to disable the UART before it enters into System ON sleep mode. But when I measure the current using the PPK, the current consumption doesn't change after I close the UART using "app_uart_close". In the following snippet, you will see, I just initialize the UART module and close it after 5seconds. But the current consumption is still the same as shown in the figurre.
static void uart_init(void)
		.rx_pin_no    = 8/*RX_PIN_NUMBER*/,
		.tx_pin_no    = 6/*TX_PIN_NUMBER*/,
		.use_parity   = false,
#if defined (UART_PRESENT)
		.baud_rate    = UARTE_BAUDRATE_BAUDRATE_Baud115200
#else
		.baud_rate    = NRF_UARTE_BAUDRATE_115200
	                   UART_RX_BUF_SIZE,
	                   UART_TX_BUF_SIZE,
	                   uart_event_handle,
	                   APP_IRQ_PRIORITY_LOWEST,
	                   err_code);
	uart_init();
	nrf_delay_ms(5000);
	app_uart_close();
	nrf_delay_ms(100);
	for(;;)
		idle_state_handle();
Here is the one in which I just directly goes to system ON sleep and the current consumption is way more reduced.
	//uart_init();
	nrf_delay_ms(5000);
	//app_uart_close();
	nrf_delay_ms(100);
	for(;;)
What's the reason for this. Is there any more else to do to disable UART totally? Really needs your help. Thanks.
  • Hi
    Could you try to run the following line of code before calling app_uart_close():
    NRF_UART0->TASKS_STOPRX = 1;
    It is possible that the UART RX is not completely disabled, and that the HF clock is requested in sleep (which increases sleep current significantly).
    Best regards
    Torbjørn
  • Hi ovrebekk, thanks so much for your reply. I have just tried that one but still no change.
    	uart_init();
    	nrf_delay_ms(5000);
    	app_uart_close();
    	nrf_delay_ms(100);
    	for(;;)
  • I even tried this code snippet which I found in this link but still the current consumption is the same.
    void disabled_uart(void) {
      uint32_t err_code = app_uart_close();
    //  APP_ERROR_CHECK(err_code);
      NRF_UARTE0->TASKS_STOPTX = 1;
      NRF_UARTE0->TASKS_STOPRX = 1;
      NRF_UARTE0->ENABLE = 0;
      /* Workaround by disabling the UART peripherals due to Nordic SDK15.0 issue */
      *(volatile uint32_t *)0x40002FFC = 0; /* Power down UARTE0 */
      *(volatile uint32_t *)0x40002FFC;
      *(volatile uint32_t *)0x40002FFC = 1; /* Power on UARTE0 so it is ready for next time */
        uart_init();
    	nrf_delay_ms(5000);
    	//NRF_UART0->TASKS_STOPRX = 1;
    	disable_UART();
    	nrf_delay_ms(100);
    	//NRF_POWER->SYSTEMOFF = 1;
    	for(;;)
  • Hi I found one more thing. I forgot to mention this earlier. The nrf52832 ble chip is connected to ESP32 via UART and most of the time ESP32 will go into deepsleep mode. What I found out is that the UART from nrf52832 can close successfully if the ESP32 is in idle state and cannot close after ESP32 chip goes into deepsleep mode.
    	// Initialize.
    	timer_init();
    	//uart_init();
    	//nrf_gpio_cfg_output(PIN_BLE_INT); // gpio_init
    	buttons_leds_init();
    	db_discovery_init();
    	power_management_init();
    	ble_stack_init();
    	gatt_init();
    	nus_c_init();
    	scan_init();
    	uart_init();
    	nrf_delay_ms(50);
    	for(;;)
    		app_uart_close();
    when app_uart_close() function is used before esp32 goes into deepsleep.
    when app_uart_close() function is used after esp32 goes into deepsleep.
    Please!! need your help quite urgently.
  • I got it. I just added "nrf_gpio_cfg_input(RX_PIN_NUMBER,NRF_GPIO_PIN_PULLUP);" after APP_UART_FIFO_INIT as in this link .
