Unable to open nrf9160 asset tracker application in Segger Embedded Studio
It seems I am unable to open the asset tracker application in SES. I get the following CMake error:
Loading solution asset_tracker.emProject
Executing load commands
cmake -GNinja -DBOARD=nrf9160_pca10090 -DBOARD_DIR=/home/jeremy/nrf9160_src/ncs/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=/opt/gnuarmemb -B/home/jeremy/nrf9160_src/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090 -H/home/jeremy/nrf9160_src/ncs/nrf/applications/asset_tracker -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=/opt/arm_segger_embedded_studio_v418_linux_x64_nordic/html/configure_nordic_project_menuconfig.py
-- Using application from '/home/jeremy/nrf9160_src/ncs/nrf/applications/asset_tracker'
Zephyr version: 1.14.99
-- Selected BOARD nrf9160_pca10090
-- Found west: /home/jeremy/.local/bin/west (found suitable version "0.5.8", minimum required is "0.5.6")
-- Cache files will be written to: /home/jeremy/.cache/zephyr
USING OUT OF TREE BOARD
-- Loading /home/jeremy/nrf9160_src/ncs/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base
-- Overlaying /home/jeremy/nrf9160_src/ncs/zephyr/dts/common/common.dts
Parsing Kconfig tree in /home/jeremy/nrf9160_src/ncs/nrf/applications/asset_tracker/Kconfig
Loading /home/jeremy/nrf9160_src/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090/zephyr/.config as base
warning: the value '' is invalid for FLIP_INPUT (defined at /home/jeremy/nrf9160_src/ncs/nrf/applications/asset_tracker/Kconfig:116), which has type int -- assignment ignored
warning: the value '' is invalid for TEMP_SIM_BUTTON (defined at /home/jeremy/nrf9160_src/ncs/nrf/applications/asset_tracker/Kconfig:264), which has type int -- assignment ignored
warning: BSD_LIBRARY (defined at ../nrf/lib/bsdlib/Kconfig:8) has direct dependencies TRUSTED_EXECUTION_NONSECURE with value n, but is currently being y-selected by the following symbols:
 - MODEM_INFO (defined at ../nrf/lib/modem_info/Kconfig:7), with value y, direct dependencies "y" (value: y)
Error: Aborting due to non-whitelisted Kconfig warning 'warning: the value '' is invalid for
which has type int -- assignment ignored'. Note: If this warning doesn't point to an actual problem,
you can add it to the whitelist at the top of
/home/jeremy/nrf9160_src/ncs/zephyr/scripts/kconfig/kconfig.py.
CMake Error at /home/jeremy/nrf9160_src/ncs/zephyr/cmake/kconfig.cmake:200 (message):
  command failed with return code: 1
  /home/jeremy/nrf9160_src/ncs/zephyr/cmake/app/boilerplate.cmake:529 (include)
  CMakeLists.txt:11 (include)
See also "/home/jeremy/nrf9160_src/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090/CMakeFiles/CMakeOutput.log".
See also "/home/jeremy/nrf9160_src/ncs/nrf/applications/asset_tracker/build_nrf9160_pca10090/CMakeFiles/CMakeError.log".
Project load failed
Reported error: solution load command failed (1)
I've followed the nRF Connect SDK getting started app, and all steps have verified successfully. I've also specifically checked out the v1.0.0 tag:
$ west init -m https://github.com/NordicPlayground/fw-nrfconnect-nrf --mr v1.0.0
Initializing in /home/jeremy/nrf9160_src/ncs
=== Cloning manifest repository from https://github.com/NordicPlayground/fw-nrfconnect-nrf, rev. v1.0.0 into /home/jeremy/nrf9160_src/ncs/.west/tmp
Initialized empty Git repository in /home/jeremy/nrf9160_src/ncs/.west/tmp/.git/
remote: Enumerating objects: 8, done.
remote: Counting objects: 100% (8/8), done.
remote: Compressing objects: 100% (8/8), done.
remote: Total 13401 (delta 0), reused 2 (delta 0), pack-reused 13393
Receiving objects: 100% (13401/13401), 4.88 MiB | 3.25 MiB/s, done.
Resolving deltas: 100% (9031/9031), done.
From https://github.com/NordicPlayground/fw-nrfconnect-nrf
 * tag               v1.0.0      -> FETCH_HEAD
 * [new branch]      master      -> origin/master
 * [new branch]      v1.0-branch -> origin/v1.0-branch
 * [new tag]         v0.1.0      -> v0.1.0
 * [new tag]         v0.1.0-rc1  -> v0.1.0-rc1
 * [new tag]         v0.3.0      -> v0.3.0
 * [new tag]         v0.3.0-rc1  -> v0.3.0-rc1
 * [new tag]         v0.3.0-rc2  -> v0.3.0-rc2
 * [new tag]         v0.4.0      -> v0.4.0
 * [new tag]         v0.4.0-rc1  -> v0.4.0-rc1
 * [new tag]         v0.4.0-rc2  -> v0.4.0-rc2
 * [new tag]         v1.0.0      -> v1.0.0
 * [new tag]         v1.0.0-rc1  -> v1.0.0-rc1
 * [new tag]         v1.0.0-rc2  -> v1.0.0-rc2
 * [new tag]         v1.0.0-rc3  -> v1.0.0-rc3
 * [new tag]         v1.0.0-rc4  -> v1.0.0-rc4
b8533b803c55fff194fe852f4eee6994640816f3 refs/tags/v1.0.0
Note: checking out 'v1.0.0'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
  git checkout -b <new-branch-name>
HEAD is now at 1f3f87d manifest: Updated manifest to use v1.0.0 release tags
cloning https://github.com/zephyrproject-rtos/west at revision v0.5.8
=== Cloning west repository from https://github.com/zephyrproject-rtos/west, rev. v0.5.8 into /home/jeremy/nrf9160_src/ncs/.west/west
Initialized empty Git repository in /home/jeremy/nrf9160_src/ncs/.west/west/.git/
remote: Enumerating objects: 62, done.
remote: Counting objects: 100% (62/62), done.
remote: Compressing objects: 100% (33/33), done.
remote: Total 2456 (delta 25), reused 42 (delta 20), pack-reused 2394
Receiving objects: 100% (2456/2456), 672.63 KiB | 837.00 KiB/s, done.
Resolving deltas: 100% (1415/1415), done.
From https://github.com/zephyrproject-rtos/west
 * tag               v0.5.8     -> FETCH_HEAD
 * [new tag]         v0.2.0     -> v0.2.0
 * [new tag]         v0.2.0rc1  -> v0.2.0rc1
 * [new tag]         v0.2.0rc2  -> v0.2.0rc2
 * [new tag]         v0.2.0rc3  -> v0.2.0rc3
 * [new tag]         v0.3.0rc1  -> v0.3.0rc1
 * [new tag]         v0.4.0rc1  -> v0.4.0rc1
 * [new tag]         v0.5.0     -> v0.5.0
 * [new tag]         v0.5.1     -> v0.5.1
 * [new tag]         v0.5.2     -> v0.5.2
 * [new tag]         v0.5.3     -> v0.5.3
 * [new tag]         v0.5.4     -> v0.5.4
 * [new tag]         v0.5.5     -> v0.5.5
 * [new tag]         v0.5.6     -> v0.5.6
 * [new tag]         v0.5.7     -> v0.5.7
 * [new tag]         v0.5.8     -> v0.5.8
 * [new tag]         v0.6.0rc1  -> v0.6.0rc1
 * [new tag]         v0.6.0rc2  -> v0.6.0rc2
1ad6c948295b8c25f8e3b4ea6750dc85d077cab6 refs/tags/v0.5.8
Note: checking out 'v0.5.8'.
HEAD is now at 1980f70 West v0.5.8
=== West initialized. Now run "west update" in /home/jeremy/nrf9160_src/ncs.
$ west update
=== self-updating west:
--- west: fetching changes
--- west: checked out 1980f707d6cb2b71d3488420e928051cc0a9df13 as detached HEAD
=== updating fw-nrfconnect-zephyr (zephyr):
--- fw-nrfconnect-zephyr: cloning and initializing
Initialized empty Git repository in /home/jeremy/nrf9160_src/ncs/zephyr/.git/
--- fw-nrfconnect-zephyr: fetching changes
remote: Enumerating objects: 339813, done.
remote: Total 339813 (delta 0), reused 0 (delta 0), pack-reused 339813
Receiving objects: 100% (339813/339813), 213.80 MiB | 9.73 MiB/s, done.
Resolving deltas: 100% (256078/256078), done.
From https://github.com/NordicPlayground/fw-nrfconnect-zephyr
 * tag                     v1.14.99-ncs2           -> FETCH_HEAD
 * [new tag]               v1.13.99-ncs1           -> v1.13.99-ncs1
 * [new tag]               v1.13.99-ncs1-rc1       -> v1.13.99-ncs1-rc1
 * [new tag]               v1.13.99-ncs2           -> v1.13.99-ncs2
 * [new tag]               v1.13.99-ncs2-rc1       -> v1.13.99-ncs2-rc1
 * [new tag]               v1.13.99-ncs2-rc2       -> v1.13.99-ncs2-rc2
 * [new tag]               v1.14.99-ncs1           -> v1.14.99-ncs1
 * [new tag]               v1.14.99-ncs1-rc1       -> v1.14.99-ncs1-rc1
 * [new tag]               v1.14.99-ncs1-rc2       -> v1.14.99-ncs1-rc2
 * [new tag]               v1.14.99-ncs2           -> v1.14.99-ncs2
 * [new tag]               v1.14.99-ncs2-rc1       -> v1.14.99-ncs2-rc1
 * [new tag]               v1.14.99-ncs2-rc2       -> v1.14.99-ncs2-rc2
 * [new tag]               v1.14.99-ncs2-rc3       -> v1.14.99-ncs2-rc3
 * [new tag]               v1.14.99-ncs2-rc4       -> v1.14.99-ncs2-rc4
 * [new tag]               v1.14.99-ncs3-snapshot1 -> v1.14.99-ncs3-snapshot1
 * [new tag]               v1.14.99-ncs3-snapshot2 -> v1.14.99-ncs3-snapshot2
Checking out files: 100% (13373/13373), done.
HEAD is now at 7e64ac737d [nrf fromlist] logging: Fix log_strdup detection on nonstandard message
--- fw-nrfconnect-zephyr: checked out 7e64ac737daead12d2dbdda5daec04188243a81c as detached HEAD
=== updating nffs (modules/fs/nffs):
--- nffs: cloning and initializing
Initialized empty Git repository in /home/jeremy/nrf9160_src/ncs/modules/fs/nffs/.git/
--- nffs: fetching changes
remote: Compressing objects: 100% (40/40), done.
remote: Total 62 (delta 19), reused 61 (delta 18), pack-reused 0
Unpacking objects: 100% (62/62), done.
From https://github.com/zephyrproject-rtos/nffs
 * [new branch]      master       -> refs/west/master
 * [new branch]      v1.14-branch -> refs/west/v1.14-branch
HEAD is now at bc62a2f zephyr: add as a zephyr module
--- nffs: checked out bc62a2fa9d98ddb5d633c932ea199bc68e10f194 as detached HEAD
=== updating segger (modules/debug/segger):
--- segger: cloning and initializing
Initialized empty Git repository in /home/jeremy/nrf9160_src/ncs/modules/debug/segger/.git/
--- segger: fetching changes
remote: Enumerating objects: 140, done.
remote: Counting objects: 100% (140/140), done.
remote: Compressing objects: 100% (68/68), done.
remote: Total 140 (delta 69), reused 140 (delta 69), pack-reused 0
Receiving objects: 100% (140/140), 73.45 KiB | 363.00 KiB/s, done.
Resolving deltas: 100% (69/69), done.
From https://github.com/zephyrproject-rtos/segger
HEAD is now at 6fcf616 ext: segger: update to SystemView v2.52h
--- segger: checked out 6fcf61606d6012d2c44129edc033f59331e268bc as detached HEAD
=== updating fw-nrfconnect-mcuboot (mcuboot):
--- fw-nrfconnect-mcuboot: cloning and initializing
Initialized empty Git repository in /home/jeremy/nrf9160_src/ncs/mcuboot/.git/
--- fw-nrfconnect-mcuboot: fetching changes
remote: Enumerating objects: 28, done.
remote: Counting objects: 100% (28/28), done.
remote: Compressing objects: 100% (20/20), done.
remote: Total 6381 (delta 11), reused 18 (delta 8), pack-reused 6353
Receiving objects: 100% (6381/6381), 2.46 MiB | 1.40 MiB/s, done.
Resolving deltas: 100% (3952/3952), done.
From https://github.com/NordicPlayground/fw-nrfconnect-mcuboot
 * tag               v1.3.99-ncs2           -> FETCH_HEAD
 * [new tag]         v1.2.99-ncs1           -> v1.2.99-ncs1
 * [new tag]         v1.2.99-ncs1-rc1       -> v1.2.99-ncs1-rc1
 * [new tag]         v1.2.99-ncs2           -> v1.2.99-ncs2
 * [new tag]         v1.2.99-ncs2-rc1       -> v1.2.99-ncs2-rc1
 * [new tag]         v1.2.99-ncs2-rc2       -> v1.2.99-ncs2-rc2
 * [new tag]         v1.3.99-ncs1           -> v1.3.99-ncs1
 * [new tag]         v1.3.99-ncs1-rc1       -> v1.3.99-ncs1-rc1
 * [new tag]         v1.3.99-ncs1-rc2       -> v1.3.99-ncs1-rc2
 * [new tag]         v1.3.99-ncs2           -> v1.3.99-ncs2
 * [new tag]         v1.3.99-ncs2-rc1       -> v1.3.99-ncs2-rc1
 * [new tag]         v1.3.99-ncs2-rc2       -> v1.3.99-ncs2-rc2
 * [new tag]         v1.3.99-ncs2-rc3       -> v1.3.99-ncs2-rc3
 * [new tag]         v1.3.99-ncs2-rc4       -> v1.3.99-ncs2-rc4
 * [new tag]         v1.3.99-ncs3-snapshot1 -> v1.3.99-ncs3-snapshot1
 * [new tag]         v1.3.99-ncs3-snapshot2 -> v1.3.99-ncs3-snapshot2
HEAD is now at 8b0e50c [nrf noup] zephyr: cmake: Use PM properties with the proper names
--- fw-nrfconnect-mcuboot: checked out 8b0e50cd5898e66e8bf92b5378c5b29fb0838471 as detached HEAD
=== updating fw-nrfconnect-mcumgr (modules/lib/mcumgr):
--- fw-nrfconnect-mcumgr: cloning and initializing
Initialized empty Git repository in /home/jeremy/nrf9160_src/ncs/modules/lib/mcumgr/.git/
--- fw-nrfconnect-mcumgr: fetching changes
remote: Enumerating objects: 284, done.
remote: Counting objects: 100% (284/284), done.
remote: Compressing objects: 100% (94/94), done.
remote: Total 284 (delta 138), reused 283 (delta 137), pack-reused 0
Receiving objects: 100% (284/284), 75.51 KiB | 213.00 KiB/s, done.
Resolving deltas: 100% (138/138), done.
From https://github.com/NordicPlayground/fw-nrfconnect-mcumgr
HEAD is now at c8f675a [nrf noup] Re-apply downstream changes to mcumgr
--- fw-nrfconnect-mcumgr: checked out c8f675a5fa7f62106b9d913844bd5ed6e16ae69e as detached HEAD
=== updating fw-nrfconnect-tinycbor (modules/lib/tinycbor):
--- fw-nrfconnect-tinycbor: cloning and initializing
Initialized empty Git repository in /home/jeremy/nrf9160_src/ncs/modules/lib/tinycbor/.git/
--- fw-nrfconnect-tinycbor: fetching changes
remote: Enumerating objects: 1385, done.
remote: Counting objects: 100% (1385/1385), done.
remote: Compressing objects: 100% (481/481), done.
remote: Total 1385 (delta 892), reused 1380 (delta 887), pack-reused 0
Receiving objects: 100% (1385/1385), 534.80 KiB | 692.00 KiB/s, done.
Resolving deltas: 100% (892/892), done.
From https://github.com/NordicPlayground/fw-nrfconnect-tinycbor
HEAD is now at 543ecb7 [nrf mergeup] Merge upstream up to commit 31ae89e
--- fw-nrfconnect-tinycbor: checked out 543ecb7c8662580ef803d59ceda7bd3b8a84a11b as detached HEAD
=== updating nrfxlib (nrfxlib):
--- nrfxlib: cloning and initializing
Initialized empty Git repository in /home/jeremy/nrf9160_src/ncs/nrfxlib/.git/
--- nrfxlib: fetching changes
remote: Enumerating objects: 1358, done.
remote: Total 1358 (delta 0), reused 0 (delta 0), pack-reused 1358
Receiving objects: 100% (1358/1358), 12.76 MiB | 5.23 MiB/s, done.
Resolving deltas: 100% (657/657), done.
From https://github.com/NordicPlayground/nrfxlib
HEAD is now at efcbc25 nfc: add license
--- nrfxlib: checked out efcbc258d7c869457e5af59f100fe9a7eeb19b62 as detached HEAD
=== updating cmock (test/cmock):
--- cmock: cloning and initializing
Initialized empty Git repository in /home/jeremy/nrf9160_src/ncs/test/cmock/.git/
--- cmock: fetching changes
remote: Enumerating objects: 104, done.
remote: Counting objects: 100% (104/104), done.
remote: Compressing objects: 100% (63/63), done.
remote: Total 4592 (delta 49), reused 67 (delta 40), pack-reused 4488
Receiving objects: 100% (4592/4592), 3.28 MiB | 438.00 KiB/s, done.
Resolving deltas: 100% (3055/3055), done.
From https://github.com/ThrowTheSwitch/cmock
 * [new branch]      future_2_5 -> refs/west/future_2_5
 * [new tag]         v2.4.3     -> v2.4.3
 * [new tag]         v2.4.4     -> v2.4.4
 * [new tag]         v2.4.5     -> v2.4.5
 * [new tag]         v2.4.6     -> v2.4.6
HEAD is now at c243b9a Merge pull request #203 from bmcdonnell/grammar
--- cmock: checked out c243b9a7a7b3c471023193992b46cf1bd1910450 as detached HEAD
=== updating unity (test/cmock/vendor/unity):
--- unity: cloning and initializing
Initialized empty Git repository in /home/jeremy/nrf9160_src/ncs/test/cmock/vendor/unity/.git/
--- unity: fetching changes
remote: Enumerating objects: 53, done.
remote: Counting objects: 100% (53/53), done.
remote: Compressing objects: 100% (44/44), done.
remote: Total 4928 (delta 19), reused 24 (delta 8), pack-reused 4875
Receiving objects: 100% (4928/4928), 6.28 MiB | 3.86 MiB/s, done.
Resolving deltas: 100% (3005/3005), done.
From https://github.com/ThrowTheSwitch/unity
 * [new branch]      stack_traces -> refs/west/stack_traces
 * [new tag]         v2.1.0       -> v2.1.0
 * [new tag]         v2.4.0       -> v2.4.0
 * [new tag]         v2.4.1       -> v2.4.1
 * [new tag]         v2.4.2       -> v2.4.2
HEAD is now at 031f3bb Merge pull request #340 from elliot-gawthrop/unit-test-execution-time
--- unity: checked out 031f3bbe45f8adf504ca3d13e6f093869920b091 as detached HEAD
=== updating mbedtls (mbedtls):
--- mbedtls: cloning and initializing
Initialized empty Git repository in /home/jeremy/nrf9160_src/ncs/mbedtls/.git/
--- mbedtls: fetching changes
remote: Enumerating objects: 15, done.
remote: Counting objects: 100% (15/15), done.
remote: Compressing objects: 100% (6/6), done.
remote: Total 80526 (delta 9), reused 9 (delta 9), pack-reused 80511
Receiving objects: 100% (80526/80526), 35.89 MiB | 8.00 MiB/s, done.
Resolving deltas: 100% (62149/62149), done.
From https://github.com/ARMmbed/mbedtls
 * tag                   mbedtls-2.13.1              -> FETCH_HEAD
 * [new tag]             beta-oob-2                  -> beta-oob-2
 * [new tag]             beta-release                -> beta-release
 * [new tag]             feature-opaque-keys-2.7-rc1 -> feature-opaque-keys-2.7-rc1
 * [new tag]             list                        -> list
 * [new tag]             mbed-alpha3                 -> mbed-alpha3
 * [new tag]             mbed-os-beta                -> mbed-os-beta
 * [new tag]             mbedos-16.01-release        -> mbedos-16.01-release
 * [new tag]             mbedos-16.03-release        -> mbedos-16.03-release
 * [new tag]             mbedos-2016q1-oob1          -> mbedos-2016q1-oob1
 * [new tag]             mbedos-2016q1-oob2          -> mbedos-2016q1-oob2
 * [new tag]             mbedos-2016q1-oob3          -> mbedos-2016q1-oob3
 * [new tag]             mbedos-release-15-11        -> mbedos-release-15-11
 * [new tag]             mbedos-techcon-oob2         -> mbedos-techcon-oob2
 * [new tag]             mbedtls-1.3.10              -> mbedtls-1.3.10
 * [new tag]             mbedtls-1.3.11              -> mbedtls-1.3.11
 * [new tag]             mbedtls-1.3.12              -> mbedtls-1.3.12
 * [new tag]             mbedtls-1.3.13              -> mbedtls-1.3.13
 * [new tag]             mbedtls-1.3.14              -> mbedtls-1.3.14
 * [new tag]             mbedtls-1.3.15              -> mbedtls-1.3.15
 * [new tag]             mbedtls-1.3.16              -> mbedtls-1.3.16
 * [new tag]             mbedtls-1.3.17              -> mbedtls-1.3.17
 * [new tag]             mbedtls-1.3.18              -> mbedtls-1.3.18
 * [new tag]             mbedtls-1.3.19              -> mbedtls-1.3.19
 * [new tag]             mbedtls-1.3.19-rc1          -> mbedtls-1.3.19-rc1
 * [new tag]             mbedtls-1.3.20              -> mbedtls-1.3.20
 * [new tag]             mbedtls-1.3.21              -> mbedtls-1.3.21
 * [new tag]             mbedtls-1.3.21-rc1          -> mbedtls-1.3.21-rc1
 * [new tag]             mbedtls-1.3.22              -> mbedtls-1.3.22
 * [new tag]             mbedtls-1.3.22-rc1          -> mbedtls-1.3.22-rc1
 * [new tag]             mbedtls-1.4-dtls-preview    -> mbedtls-1.4-dtls-preview
 * [new tag]             mbedtls-2.0.0               -> mbedtls-2.0.0
 * [new tag]             mbedtls-2.1.0               -> mbedtls-2.1.0
 * [new tag]             mbedtls-2.1.1               -> mbedtls-2.1.1
 * [new tag]             mbedtls-2.1.10              -> mbedtls-2.1.10
 * [new tag]             mbedtls-2.1.10-rc1          -> mbedtls-2.1.10-rc1
 * [new tag]             mbedtls-2.1.11              -> mbedtls-2.1.11
 * [new tag]             mbedtls-2.1.11-rc1          -> mbedtls-2.1.11-rc1
 * [new tag]             mbedtls-2.1.12              -> mbedtls-2.1.12
 * [new tag]             mbedtls-2.1.13              -> mbedtls-2.1.13
 * [new tag]             mbedtls-2.1.14              -> mbedtls-2.1.14
 * [new tag]             mbedtls-2.1.15              -> mbedtls-2.1.15
 * [new tag]             mbedtls-2.1.16              -> mbedtls-2.1.16
 * [new tag]             mbedtls-2.1.17              -> mbedtls-2.1.17
 * [new tag]             mbedtls-2.1.18              -> mbedtls-2.1.18
 * [new tag]             mbedtls-2.1.2               -> mbedtls-2.1.2
 * [new tag]             mbedtls-2.1.3               -> mbedtls-2.1.3
 * [new tag]             mbedtls-2.1.4               -> mbedtls-2.1.4
 * [new tag]             mbedtls-2.1.5               -> mbedtls-2.1.5
 * [new tag]             mbedtls-2.1.6               -> mbedtls-2.1.6
 * [new tag]             mbedtls-2.1.7               -> mbedtls-2.1.7
 * [new tag]             mbedtls-2.1.7-rc1           -> mbedtls-2.1.7-rc1
 * [new tag]             mbedtls-2.1.8               -> mbedtls-2.1.8
 * [new tag]             mbedtls-2.1.9               -> mbedtls-2.1.9
 * [new tag]             mbedtls-2.1.9-rc1           -> mbedtls-2.1.9-rc1
 * [new tag]             mbedtls-2.10.0              -> mbedtls-2.10.0
 * [new tag]             mbedtls-2.11.0              -> mbedtls-2.11.0
 * [new tag]             mbedtls-2.12.0              -> mbedtls-2.12.0
 * [new tag]             mbedtls-2.13.0              -> mbedtls-2.13.0
 * [new tag]             mbedtls-2.13.1              -> mbedtls-2.13.1
 * [new tag]             mbedtls-2.14.0              -> mbedtls-2.14.0
 * [new tag]             mbedtls-2.14.1              -> mbedtls-2.14.1
 * [new tag]             mbedtls-2.15.0              -> mbedtls-2.15.0
 * [new tag]             mbedtls-2.15.1              -> mbedtls-2.15.1
 * [new tag]             mbedtls-2.16.0              -> mbedtls-2.16.0
 * [new tag]             mbedtls-2.16.1              -> mbedtls-2.16.1
 * [new tag]             mbedtls-2.16.2              -> mbedtls-2.16.2
 * [new tag]             mbedtls-2.17.0              -> mbedtls-2.17.0
 * [new tag]             mbedtls-2.18.0              -> mbedtls-2.18.0
 * [new tag]             mbedtls-2.18.1              -> mbedtls-2.18.1
 * [new tag]             mbedtls-2.2.0               -> mbedtls-2.2.0
 * [new tag]             mbedtls-2.2.1               -> mbedtls-2.2.1
 * [new tag]             mbedtls-2.3.0               -> mbedtls-2.3.0
 * [new tag]             mbedtls-2.4.0               -> mbedtls-2.4.0
 * [new tag]             mbedtls-2.4.1               -> mbedtls-2.4.1
 * [new tag]             mbedtls-2.4.2               -> mbedtls-2.4.2
 * [new tag]             mbedtls-2.4.2-rc1           -> mbedtls-2.4.2-rc1
 * [new tag]             mbedtls-2.5.0               -> mbedtls-2.5.0
 * [new tag]             mbedtls-2.5.0-rc1           -> mbedtls-2.5.0-rc1
 * [new tag]             mbedtls-2.5.1               -> mbedtls-2.5.1
 * [new tag]             mbedtls-2.6.0               -> mbedtls-2.6.0
 * [new tag]             mbedtls-2.6.0-rc1           -> mbedtls-2.6.0-rc1
 * [new tag]             mbedtls-2.6.1               -> mbedtls-2.6.1
 * [new tag]             mbedtls-2.6.1-rc1           -> mbedtls-2.6.1-rc1
 * [new tag]             mbedtls-2.7.0               -> mbedtls-2.7.0
 * [new tag]             mbedtls-2.7.0-rc1           -> mbedtls-2.7.0-rc1
 * [new tag]             mbedtls-2.7.1               -> mbedtls-2.7.1
 * [new tag]             mbedtls-2.7.10              -> mbedtls-2.7.10
 * [new tag]             mbedtls-2.7.11              -> mbedtls-2.7.11
 * [new tag]             mbedtls-2.7.2               -> mbedtls-2.7.2
 * [new tag]             mbedtls-2.7.2-rc1           -> mbedtls-2.7.2-rc1
 * [new tag]             mbedtls-2.7.3               -> mbedtls-2.7.3
 * [new tag]             mbedtls-2.7.4               -> mbedtls-2.7.4
 * [new tag]             mbedtls-2.7.5               -> mbedtls-2.7.5
 * [new tag]             mbedtls-2.7.6               -> mbedtls-2.7.6
 * [new tag]             mbedtls-2.7.7               -> mbedtls-2.7.7
 * [new tag]             mbedtls-2.7.8               -> mbedtls-2.7.8
 * [new tag]             mbedtls-2.7.9               -> mbedtls-2.7.9
 * [new tag]             mbedtls-2.8.0               -> mbedtls-2.8.0
 * [new tag]             mbedtls-2.8.0-rc1           -> mbedtls-2.8.0-rc1
 * [new tag]             mbedtls-2.9.0               -> mbedtls-2.9.0
 * [new tag]             mbedtls-3.0.0p1             -> mbedtls-3.0.0p1
 * [new tag]             polarssl-0.10.0             -> polarssl-0.10.0
 * [new tag]             polarssl-0.10.1             -> polarssl-0.10.1
 * [new tag]             polarssl-0.11.0             -> polarssl-0.11.0
 * [new tag]             polarssl-0.11.1             -> polarssl-0.11.1
 * [new tag]             polarssl-0.12.0             -> polarssl-0.12.0
 * [new tag]             polarssl-0.12.1             -> polarssl-0.12.1
 * [new tag]             polarssl-0.13.0             -> polarssl-0.13.0
 * [new tag]             polarssl-0.13.1             -> polarssl-0.13.1
 * [new tag]             polarssl-0.14.0             -> polarssl-0.14.0
 * [new tag]             polarssl-0.14.1             -> polarssl-0.14.1
 * [new tag]             polarssl-0.14.2             -> polarssl-0.14.2
 * [new tag]             polarssl-0.14.3             -> polarssl-0.14.3
 * [new tag]             polarssl-0.99-pre1          -> polarssl-0.99-pre1
 * [new tag]             polarssl-0.99-pre2          -> polarssl-0.99-pre2
 * [new tag]             polarssl-0.99-pre3          -> polarssl-0.99-pre3
 * [new tag]             polarssl-0.99-pre4          -> polarssl-0.99-pre4
 * [new tag]             polarssl-0.99-pre5          -> polarssl-0.99-pre5
 * [new tag]             polarssl-1.0.0              -> polarssl-1.0.0
 * [new tag]             polarssl-1.1.0              -> polarssl-1.1.0
 * [new tag]             polarssl-1.1.0-rc0          -> polarssl-1.1.0-rc0
 * [new tag]             polarssl-1.1.0-rc1          -> polarssl-1.1.0-rc1
 * [new tag]             polarssl-1.1.1              -> polarssl-1.1.1
 * [new tag]             polarssl-1.1.2              -> polarssl-1.1.2
 * [new tag]             polarssl-1.1.3              -> polarssl-1.1.3
 * [new tag]             polarssl-1.1.4              -> polarssl-1.1.4
 * [new tag]             polarssl-1.1.5              -> polarssl-1.1.5
 * [new tag]             polarssl-1.1.6              -> polarssl-1.1.6
 * [new tag]             polarssl-1.1.7              -> polarssl-1.1.7
 * [new tag]             polarssl-1.1.8              -> polarssl-1.1.8
 * [new tag]             polarssl-1.2.0              -> polarssl-1.2.0
 * [new tag]             polarssl-1.2.0-pre1         -> polarssl-1.2.0-pre1
 * [new tag]             polarssl-1.2.1              -> polarssl-1.2.1
 * [new tag]             polarssl-1.2.10             -> polarssl-1.2.10
 * [new tag]             polarssl-1.2.11             -> polarssl-1.2.11
 * [new tag]             polarssl-1.2.12             -> polarssl-1.2.12
 * [new tag]             polarssl-1.2.13             -> polarssl-1.2.13
 * [new tag]             polarssl-1.2.14             -> polarssl-1.2.14
 * [new tag]             polarssl-1.2.15             -> polarssl-1.2.15
 * [new tag]             polarssl-1.2.16             -> polarssl-1.2.16
 * [new tag]             polarssl-1.2.17             -> polarssl-1.2.17
 * [new tag]             polarssl-1.2.18             -> polarssl-1.2.18
 * [new tag]             polarssl-1.2.19             -> polarssl-1.2.19
 * [new tag]             polarssl-1.2.2              -> polarssl-1.2.2
 * [new tag]             polarssl-1.2.3              -> polarssl-1.2.3
 * [new tag]             polarssl-1.2.4              -> polarssl-1.2.4
 * [new tag]             polarssl-1.2.5              -> polarssl-1.2.5
 * [new tag]             polarssl-1.2.6              -> polarssl-1.2.6
 * [new tag]             polarssl-1.2.7              -> polarssl-1.2.7
 * [new tag]             polarssl-1.2.8              -> polarssl-1.2.8
 * [new tag]             polarssl-1.2.9              -> polarssl-1.2.9
 * [new tag]             polarssl-1.3-alpha1         -> polarssl-1.3-alpha1
 * [new tag]             polarssl-1.3.0              -> polarssl-1.3.0
 * [new tag]             polarssl-1.3.0-rc0          -> polarssl-1.3.0-rc0
 * [new tag]             polarssl-1.3.1              -> polarssl-1.3.1
 * [new tag]             polarssl-1.3.2              -> polarssl-1.3.2
 * [new tag]             polarssl-1.3.3              -> polarssl-1.3.3
 * [new tag]             polarssl-1.3.4              -> polarssl-1.3.4
 * [new tag]             polarssl-1.3.5              -> polarssl-1.3.5
 * [new tag]             polarssl-1.3.6              -> polarssl-1.3.6
 * [new tag]             polarssl-1.3.7              -> polarssl-1.3.7
 * [new tag]             polarssl-1.3.8              -> polarssl-1.3.8
 * [new tag]             polarssl-1.3.9              -> polarssl-1.3.9
 * [new tag]             yotta-2.2.1                 -> yotta-2.2.1
 * [new tag]             yotta-2.2.2                 -> yotta-2.2.2
 * [new tag]             yotta-2.2.3                 -> yotta-2.2.3
 * [new tag]             yotta-2.3.0                 -> yotta-2.3.0
 * [new tag]             yotta-2.3.1                 -> yotta-2.3.1
 * [new tag]             yotta-2.3.2                 -> yotta-2.3.2
HEAD is now at 53546ea09 Update library version number to 2.13.1
--- mbedtls: checked out 53546ea099f6f53d0be653a64accd250e170337f as detached HEAD
I am using Xubuntu 18.04.1 LTS with all of the updates installed as of the 27th of July. Has anyone else come across this problem?
