Set a fixed WiFi connection for the Nordic OTBR
I am trying to set a fixed WiFi connection in the "/etc/wpa_supplicant/wpa_supplicant.conf " file, but it gets lost on every reboot. I assume it is because of the Access Point feature. Could you please tell me what I have to do to disable it and leave my connection unchanged.
Thank you
    Yes. I have struggled a bit with the same.
    It is correct as you say, the Access Point service overwrites the default network configurations which is usually stored in wpa_supplicant/wpa_supplicant.conf.
    The Border Router uses NetworkManager to module to manage it's networks.
    I am not sure if step 1 is required, but at least it works if you include it.
    To disable the AP feature, type the command:
    1:
    $ nmcli connection down BorderRouter-AP
    2:
    $ sudo systemctl disable ap-config.service
    3:
    $ nmcli connection add con-name <ssid> ifname wlan0 type wifi ssid <ssid> ipv6.method ignore wifi-sec.key-mgmt wpa-psk wifi-sec.psk <password>
    where <ssid> is the name of your network, and <password> is your password. So if you have a network named "MyNetwork" with password "MyPassword":
    $ nmcli connection add con-name MyNetwork ifname wlan0 type wifi ssid MyNetwork ipv6.method ignore wifi-sec.key-mgmt wpa-psk wifi-sec.psk MyPassword
    So this will add your network to the network manager. If you restart ($ sudo reboot) it will connect to this network on the next startup.
    Hope that helps.
    Edvin
  • Hi Edvin,
    I disable the BorderRouter-AP as you suggested and it worked. Then, I configured my network manually by writing in the /etc/wpa_supplicant/wpa_supplicant.conf and /etc/network/interfaces file, but it does not work. This is the way I do it since I got my RPi3 and it has always worked.
    network={
      ssid="newcastle-university"
      key_mgmt=WPA-EAP
      eap=TTLS
      identity="your_login_name"
      password="your_password"
      phase2="auth=MSCHAPv2"
    allow-hotplug wlan0
    iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
    As you can see, it is an enterprise network. That is the reason I did not followed your example. You mention that the Border Router uses the NetworkManager module to manage it's networks. Does this means that the only possible way of enable connection is through it? So, would I have to use the NetworkManager for enterprise networks?
    Ronald
  • I tried the example and the result is the same. Here is the new configuration,
    nmcli con add type wifi ifname wlan0 con-name uni-wifi ssid <your_ssid>
    nmcli con edit id uni-wifi
    nmcli> set wifi-sec.key-mgmt wpa-eap
    nmcli> set 802-1x.eap ttls
    nmcli> set 802-1x.identity <your_identity>
    nmcli> set 802-1x.password <your_password>
    nmcli> set 802-1x.phase2-auth mschapv2
    nmcli> verify
    nmcli> save
    nmcli> activate
    My initial intention was to disable the BorderRouter-AP to connect the Nordic OTBR to a WPA2 enterprise network, so as long as I can connect to the network, I do mind disabling the BorderRouter-AP on reboot.
  • So does this mean that you managed to both disable the BorderRouter-AP and connect to the enterprise network automatically on startup?
  • Well, not exactly. Once the board has been powered up, I run manually
    to disable the BorderRouter-AP and then the Nordic OTBR connects to the enterprise network automatically.
    I found that it is possible to remove the BorderRouter-AP instead of just shutting it down by executing
    $ nmcli connection delete BorderRouter-AP
    but I decided not to do it and just disabling it on startup because at some point I may need the access point.
  • Did you try
    In that case, it didn't start up on reboot. You can enable it later if you like using:
    $ sudo systemctl enable ap-config.service
    BR,
    Edvin
  • Yeah, it works know.
    Thank you very much Edvin.
