Having very short range with custom board
Hello everyone,
I got an issue with the custom board nRF52832 (Raytac BLE module) as I only achieve very short distance between the BLE device and Android app without data loss. This distance is about 50 cm. The RSSI I noticed is below -70dBm.
With same code, it perfectly ran on nRF52 DK and the range I tested without data loss is about 5 meters.
I tried to increase TX power as the following code ( using sd_ble_gap_tx_power_set()). However, it didn't improve much. Is there any suggestion in this case?
    ble_advdata_t          advdata;
    ble_advdata_t          scanrsp;
    ble_adv_modes_config_t options;
		int8_t tx_power_level = 4;
    // Build advertising data struct to pass into @ref ble_advertising_init.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = false;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
		advdata.p_tx_power_level   = &tx_power_level;
		sd_ble_gap_tx_power_set(tx_power_level);
    memset(&scanrsp, 0, sizeof(scanrsp));
    scanrsp.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    scanrsp.uuids_complete.p_uuids  = m_adv_uuids;
    memset(&options, 0, sizeof(options));
    options.ble_adv_fast_enabled  = true;
    options.ble_adv_fast_interval = APP_ADV_INTERVAL;
    options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    err_code = ble_advertising_init(&advdata, &scanrsp, &options, on_adv_evt, NULL);
    ble_advertising_conn_cfg_tag_set(CONN_CFG_TAG);
Thanks!
Parents Reply
  • 1) Yes
    2)Yes see the wide no-ground pad area beside the antenna which it tells you to make as wide as possible.
    3) yes
    Honestly you should really mail Raytac about this - they say in that document they will help you to review board design and give you an address to send to. Nordic makes the chip, Raytac makes the module and only they really can tell you the best design to use it.
