PDM start fail
Hi, I'm using the nRF52840 SDK15.2.0
I'd like to get data from a digital microphone via a PDM interface. The teansfer data to speaker via a I2S interface.
Here is my problem:
In the ret_code_t nrf_drv_pdm_start(void)
nrf_pdm_task_trigger(NRF_PDM_TASK_START);
NRF_LOG_INFO("PDM TASKS START\r\n");
I can't see information "PDM TASKS START"
If I use
nrf_pdm_task_trigger(NRF_PDM_TASK_STOP);
NRF_LOG_INFO("PDM TASKS STOP\r\n");
I can see information "PDM TASKS STOP"
Thank you.
  • I try to port PDM part from thingy SDK to SDK_15.2 with nRF52840.
    The process hangs (no further message) after nrf_pdm_task_trigger(NRF_PDM_TASK_START).
    Is there any idea what's wrong in this code?
    	  ASSERT(m_cb.drv_state != NRF_DRV_STATE_UNINITIALIZED);
        ret_code_t err_code;
    	  if (m_cb.status != NRF_PDM_STATE_IDLE)
            if (m_cb.status == NRF_PDM_STATE_RUNNING)
                err_code = NRF_SUCCESS;
                printf("Function: %s, error code: %s.\r\n", (uint32_t)__func__, (uint32_t)NRF_LOG_ERROR_STRING_GET(err_code));
                return err_code;
            err_code = NRF_ERROR_BUSY;
            return err_code;
        m_cb.status = NRF_PDM_STATE_TRANSITION;
        m_cb.drv_state = NRF_DRV_STATE_POWERED_ON;
        nrf_pdm_enable();
        nrf_pdm_event_clear(NRF_PDM_EVENT_STARTED);
    		printf("PDM-START----\r\n");
    		return err_code;
    ret_code_t drv_audio_enable(void)
    #if CONFIG_PDM_MIC_PWR_CTRL_ENABLED
    #if CONFIG_PDM_MIC_PWR_CTRL_ACT_LOW
        nrf_gpio_pin_clear(CONFIG_IO_PDM_MIC_PWR_CTRL);
    #else // !CONFIG_PDM_MIC_PWR_CTRL_ACT_LOW
        nrf_gpio_pin_set(CONFIG_IO_PDM_MIC_PWR_CTRL);
    #endif // CONFIG_PDM_MIC_PWR_CTRL_ACT_LOW
    #endif // CONFIG_PDM_MIC_PWR_CTRL_ENABLED
        // Skip buffers with invalid data.
        m_skip_buffers = MAX(1, ROUNDED_DIV((CONFIG_PDM_TRANSIENT_STATE_LEN * SAMPLING_RATE),
                                            (1000 * CONFIG_AUDIO_FRAME_SIZE_SAMPLES)));
    	  return nrf_drv_pdm_start();
    uint32_t drv_mic_start(void)
        ret_code_t status;
        if(m_audio_enabled == true)
            return NRF_SUCCESS;
        status = drv_audio_enable();
        if (status == NRF_SUCCESS)
            m_audio_enabled = true;
        return status;
    int main()
    	drv_audio_init(m_audio_buffer_handler);
    	drv_mic_start();
  • How do you know the program hangs at nrf_pdm_task_trigger(), and not any of the functions before? Try setting a breakpoint at nrf_pdm_task_trigger() and see if your program reaches it. Here is a guide on how to debug in SES. Usually the program stops due to asserts (like APP_ERROR_CHECK()) or hardfaults, and I guess it is one of them in your case.
    Simon
  • Simon, Thanks your response. The program does not hang at nrf_pdm_task_trigger().
  • Ok. Just to make it clear, did you put a breakpoint on nrf_pdm_task_trigger(), and the program didn't reach the breakpoint?
    If that is the case, then something before that function is causing the error. You should set a breakpoint incrementally upwards to see what line is causing the error.
    Simon
