Custom DFU bootloader
I have a custom board with the nRF52840.
Is it possible to customize the DFU to be able to update the firmware through other interfaces than BLE or USB/UART?
I have a SD-card connected and would like to check for a flash image on the card and then update the firmware if there is an image.
Would that be possible?
  • Hello, did you ever get it to work?
    I have a similar problem for my pca10040/S132 (Laird BL652), and am getting really confused by the cryptic barely documented DFU interface.  I noticed that one example uses pstorage, is that the way to bypass all that?  I suddenly have clients breathing down my neck wanting a firmware update to allow SD-card firmware updates before end customer distribution.  ;-)
    Thank you,
    -Erik
    I did get it to work, but doing some reverse engineering.
    I made use of the Background DFU - that are running inside my application. So I have access to all my peripherals - including my SPI interface to my external sd-card running with FatFS.
    In my program I check the sd-card for a specific bootloader file, and if that exists I go to a state where I read the file 1 byte at a time.
    I added the UART bootloader to my code and commented out the interrupt routines and added my own function to call. Then I can pass the byte I read from the file to the UART bootloader.
    In order to get it to work I had to make a file-converter that actually reads the .zip package, that are normally used by the bootloader, and convert it to a new file that also contains the DFU package info (because this is normally handled by the interface program on the PC).
    Hope this helps a little - if you like I will be happy to share my code for the bootloader and the file-converter with you.
    -Morten
  • Hi Javier,
    Can you check your linker settings in your project.
    I use a nRF52840 with Softdevice 6.1.1 and SDK 15.3 and has the following settings:
    FLASH_PH_START=0x0
    FLASH_PH_SIZE=0x100000
    RAM_PH_START=0x20000000
    RAM_PH_SIZE=0x40000
    FLASH_START=0x26000
    FLASH_SIZE=0xda000
    RAM_START=0x20002b88
    RAM_SIZE=0x3d478
    I believe I had the same problem until I found the correct values.
  • I'm using the same softdevice and SDK as you. I changed the settings according with your specs and when I try to debug the application I get a 'Stopped by vector catch' and doesn't start...
    The linker configuration I'm using is this:
    linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x100000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x40000;FLASH_START=0x26000;FLASH_SIZE=0xda000;RAM_START=0x20002b88;RAM_SIZE=0x3d478"
    linker_section_placements_segments="FLASH RX 0x0 0x100000;RAM RWX 0x20000000 0x40000;uicr_bootloader_start_address RX 0x00000FF8 0x4;uicr_mbr_params_page RX 0x00000FFC 0x4;mbr_params_page RX 0x0007E000 0x1000;bootloader_settings_page RX 0x0007F000 0x1000"
  • I verified that we have the same linker_section_placement_macros values.
    We differ in linker_section_placements_segments:
    FLASH RX 0x0 0x100000;RAM RWX 0x20000000 0x40000;uicr_bootloader_start_address RX 0x00000FF8 0x4 ;uicr_mbr_params_page RX 0x00000FFC 0x4;mbr_params_page RX 0x000FE000 0x1000;bootloader_settings_page RX 0x000FF000 0x1000
    I Also checked the settings from the DFU_bootloader. Here are my settings:
    FLASH RX 0x0 0x100000;RAM RWX 0x20000000 0x40000;uicr_bootloader_start_address RX 0x00000FF8 0x4;bootloader_settings_page RX 0x000FF000 0x1000;uicr_mbr_params_page RX 0x00000FFC 0x4;mbr_params_page RX 0x000FE000 0x1000
    FLASH_PH_START=0x0;FLASH_PH_SIZE=0x100000;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x40000;FLASH_START=0xf8000;FLASH_SIZE=0x6000;RAM_START=0x20004000;RAM_SIZE=0x3bad0
  • Sorry for being a real pain but, could you share the flash_placement.xml file? I think I have a misconfiguration and I don't know where...
  • <!DOCTYPE Linker_Placement_File>
    <Root name="Flash Section Placement">
      <MemorySegment name="FLASH" start="$(FLASH_PH_START)" size="$(FLASH_PH_SIZE)">
        <ProgramSection load="no" name=".reserved_flash" start="$(FLASH_PH_START)" size="$(FLASH_START)-$(FLASH_PH_START)" />
        <ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START)" />
        <ProgramSection alignment="4" load="Yes" name=".init" />
        <ProgramSection alignment="4" load="Yes" name=".init_rodata" />
        <ProgramSection alignment="4" load="Yes" name=".text" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".crypto_data" inputsections="*(SORT(.crypto_data*))" address_symbol="__start_crypto_data" end_symbol="__stop_crypto_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_queue" inputsections="*(.nrf_queue*)" address_symbol="__start_nrf_queue" end_symbol="__stop_nrf_queue" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_backends" inputsections="*(SORT(.log_backends*))" address_symbol="__start_log_backends" end_symbol="__stop_log_backends" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_const_data" inputsections="*(SORT(.log_const_data*))" address_symbol="__start_log_const_data" end_symbol="__stop_log_const_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_balloc" inputsections="*(.nrf_balloc*)" address_symbol="__start_nrf_balloc" end_symbol="__stop_nrf_balloc" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_soc_observers" inputsections="*(SORT(.sdh_soc_observers*))" address_symbol="__start_sdh_soc_observers" end_symbol="__stop_sdh_soc_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_req_observers" inputsections="*(SORT(.sdh_req_observers*))" address_symbol="__start_sdh_req_observers" end_symbol="__stop_sdh_req_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_state_observers" inputsections="*(SORT(.sdh_state_observers*))" address_symbol="__start_sdh_state_observers" end_symbol="__stop_sdh_state_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_stack_observers" inputsections="*(SORT(.sdh_stack_observers*))" address_symbol="__start_sdh_stack_observers" end_symbol="__stop_sdh_stack_observers" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections" address_symbol="__start_nrf_sections" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_dynamic_data"  inputsections="*(SORT(.log_dynamic_data*))" runin=".log_dynamic_data_run"/>
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_filter_data"  inputsections="*(SORT(.log_filter_data*))" runin=".log_filter_data_run"/>
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".fs_data"  inputsections="*(.fs_data*)" runin=".fs_data_run"/>
        <ProgramSection alignment="4" load="Yes" name=".dtors" />
        <ProgramSection alignment="4" load="Yes" name=".ctors" />
        <ProgramSection alignment="4" load="Yes" name=".rodata" />
        <ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
        <ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
        <ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
        <ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
      </MemorySegment>
      <MemorySegment name="RAM" start="$(RAM_PH_START)" size="$(RAM_PH_SIZE)">
        <ProgramSection load="no" name=".reserved_ram" start="$(RAM_PH_START)" size="$(RAM_START)-$(RAM_PH_START)" />
        <ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START)" address_symbol="__app_ram_start__"/>
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run" address_symbol="__start_nrf_sections_run" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".log_dynamic_data_run" address_symbol="__start_log_dynamic_data" end_symbol="__stop_log_dynamic_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".log_filter_data_run" address_symbol="__start_log_filter_data" end_symbol="__stop_log_filter_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run_end" address_symbol="__end_nrf_sections_run" />
        <ProgramSection alignment="4" load="No" name=".fast_run" />
        <ProgramSection alignment="4" load="No" name=".data_run" />
        <ProgramSection alignment="4" load="No" name=".tdata_run" />
        <ProgramSection alignment="4" load="No" name=".bss" />
        <ProgramSection alignment="4" load="No" name=".tbss" />
        <ProgramSection alignment="4" load="No" name=".non_init" />
        <ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
        <ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack"  address_symbol="__StackLimit" end_symbol="__StackTop"/>
        <ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
      </MemorySegment>
      <MemorySegment name="bootloader_settings_page" start="0x000FF000" size="0x1000">
        <ProgramSection alignment="4" keep="Yes" load="No" name=".bootloader_settings_page" address_symbol="__start_bootloader_settings_page" end_symbol="__stop_bootloader_settings_page" start = "0x000FF000" size="0x1000" />
      </MemorySegment>
      <MemorySegment name="mbr_params_page" start="0x000FE000" size="0x1000">
        <ProgramSection alignment="4" keep="Yes" load="No" name=".mbr_params_page" address_symbol="__start_mbr_params_page" end_symbol="__stop_mbr_params_page" start = "0x000FE000" size="0x1000" />
      </MemorySegment>
      <MemorySegment name="uicr_bootloader_start_address" start="0x00000FF8" size="0x4">
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".uicr_bootloader_start_address" address_symbol="__start_uicr_bootloader_start_address" end_symbol="__stop_uicr_bootloader_start_address" start = "0x00000FF8" size="0x4" />
      </MemorySegment>
      <MemorySegment name="uicr_mbr_params_page" start="0x00000FFC" size="0x4">
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".uicr_mbr_params_page" address_symbol="__start_uicr_mbr_params_page" end_symbol="__stop_uicr_mbr_params_page" start = "0x00000FFC" size="0x4" />
      </MemorySegment>
    </Root>
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_ble_observers" inputsections="*(SORT(.sdh_ble_observers*))" address_symbol="__start_sdh_ble_observers" end_symbol="__stop_sdh_ble_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".dfu_trans" inputsections="*(SORT(.dfu_trans*))" address_symbol="__start_dfu_trans" end_symbol="__stop_dfu_trans" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".pwr_mgmt_data" inputsections="*(SORT(.pwr_mgmt_data*))" address_symbol="__start_pwr_mgmt_data" end_symbol="__stop_pwr_mgmt_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_command" inputsections="*(.cli_command*)" address_symbol="__start_cli_command" end_symbol="__stop_cli_command" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_sorted_cmd_ptrs"  inputsections="*(.cli_sorted_cmd_ptrs*)" runin=".cli_sorted_cmd_ptrs_run"/>
      </MemorySegment>
        <ProgramSection alignment="4" keep="Yes" load="No" name=".cli_sorted_cmd_ptrs_run" address_symbol="__start_cli_sorted_cmd_ptrs" end_symbol="__stop_cli_sorted_cmd_ptrs" />
      </MemorySegment>
      </MemorySegment>
      </MemorySegment>
      </MemorySegment>
      </MemorySegment>
    </Root>
      </MemorySegment>
      </MemorySegment>
      </MemorySegment>
      </MemorySegment>
      </MemorySegment>
      </MemorySegment>
    </Root>
      </MemorySegment>
      </MemorySegment>
      </MemorySegment>
      </MemorySegment>
      </MemorySegment>
      </MemorySegment>
    </Root>
