NRF SDK 15.3 UART example is not working. - nRF52840 pca10056
Hi DevZone,
I am developing an application that needs to use UART communication with the nRF52840 pca10056 board.
I am using Segger Embedded Studio V4.16
I checked out the UART example found in the SDK files under \examples\peripheral\uart\pca10056\blank\ses\
I have setup my terminal program PuTTY with 115200 Baudrate, 8 Data bits, 1 Stop bit, No Parity and No Flow Control.
The example compiles fine, but  does not run. I get no echo in the terminal as expected.
When i build and debug, I immediately end up in the app_error_weak.c file at line 100 - NRF_BREAKPOINT_COND;
Are there any know issues with this example? I have searched the DevZone and did not find any related posts.
I hope you can point me in the right direction.
Br. Casper
    Have you added this macro in. It's commented out by default.
    line 66 in the example
    #define ENABLE_LOOPBACK_TEST
    Regards
  • Yes I also tried enabling loopback test, but the same error occurs.
  • Hi.
    You compiled it out of the box?
    It works fine for me:
    The code I'm running:
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup uart_example_main main.c
     * @ingroup uart_example
     * @brief UART Example Application main file.
     * This file contains the source code for a sample application using UART.
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include "app_uart.h"
    #include "app_error.h"
    #include "nrf_delay.h"
    #include "nrf.h"
    #include "bsp.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    //#define ENABLE_LOOPBACK_TEST  /**< if defined, then this example will be a loopback test, which means that TX should be connected to RX to get data loopback. */
    #define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
    #define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 256                         /**< UART RX buffer size. */
    void uart_error_handle(app_uart_evt_t * p_event)
        if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
        else if (p_event->evt_type == APP_UART_FIFO_ERROR)
    #ifdef ENABLE_LOOPBACK_TEST
    /* Use flow control in loopback test. */
    #define UART_HWFC APP_UART_FLOW_CONTROL_ENABLED
    /** @brief Function for setting the @ref ERROR_PIN high, and then enter an infinite loop.
    static void show_error(void)
        bsp_board_leds_on();
        while (true)
            // Do nothing.
    /** @brief Function for testing UART loop back.
     *  @details Transmitts one character at a time to check if the data received from the loopback is same as the transmitted data.
     *  @note  @ref TX_PIN_NUMBER must be connected to @ref RX_PIN_NUMBER)
    static void uart_loopback_test()
        uint8_t * tx_data = (uint8_t *)("\r\nLOOPBACK_TEST\r\n");
        uint8_t   rx_data;
        // Start sending one byte and see if you get the same
        for (uint32_t i = 0; i < MAX_TEST_DATA_BYTES; i++)
            uint32_t err_code;
            while (app_uart_put(tx_data[i]) != NRF_SUCCESS);
            nrf_delay_ms(10);
            err_code = app_uart_get(&rx_data);
            if ((rx_data != tx_data[i]) || (err_code != NRF_SUCCESS))
                show_error();
        return;
    #else
    /* When UART is used for communication with the host do not use flow control.*/
    #define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED
        uint32_t err_code;
        const app_uart_comm_params_t comm_params =
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              UART_HWFC,
              false,
              NRF_UART_BAUDRATE_115200
    #else
              NRF_UARTE_BAUDRATE_115200
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle,
                             APP_IRQ_PRIORITY_LOWEST,
                             err_code);
    #ifndef ENABLE_LOOPBACK_TEST
        printf("\r\nUART example started.\r\n");
        while (true)
            uint8_t cr;
            while (app_uart_get(&cr) != NRF_SUCCESS);
            while (app_uart_put(cr) != NRF_SUCCESS);
            if (cr == 'q' || cr == 'Q')
                printf(" \r\nExit!\r\n");
                while (true)
                    // Do nothing.
    #else
        // This part of the example is just for testing the loopback .
        while (true)
            uart_loopback_test();
    Andreas
    Yes I compiled it straight out of the box. Just tried copying your code in and the error persists I am afraid.
    Br. Casper
    EDIT:
    From what I can see when debugging, then the m_event_handler(&app_uart_event); is called in app_uart_fifo.c
    This then goes directly into the app_error_fault_handler(NRF_FAULT_ID_SDK_ERROR, 0, (uint32_t)(&error_info)); in line 73 in app_error.c
    The error code is 0x00000004
  • Hi.
    Have you modified any source files used by different drivers in the SDK?
    Could you try to compile the example from a clean SDK?
    Andreas
