Slave address read unexpectedly in TWI
Hi, Everyone
I use sdk15.2 & nrf52832
I am doing a test to read the slave address in TWI
There is one slave device on the board and the slave address is 0x68
I used three examples in twi_scanner, twi_sensor, twi_master_using_nrf_twi_mgnr The slave addresses read from each program are read differently
 < nRF5_SDK_15.2.0_9412b96\examples\peripheral\twi_scanner >
 0> <info> app: TWI scanner started.
 0> <info> app: TWI device detected at address 0x68.
 < nRF5_SDK_15.2.0_9412b96\examples\peripheral\twi_sensor >
  0> <info> app:
 0> TWI sensor example started.
 0> <info> app: TWI device detected at address 0x1.
 0> <info> app: TWI device detected at address 0xE.
 0> <info> app: TWI device detected at address 0x1C.
 0> <info> app: TWI device detected at address 0x29.
 0> <info> app: TWI device detected at address 0x36.
 0> <info> app: TWI device detected at address 0x43.
 0> <info> app: TWI device detected at address 0x50.
 0> <info> app: TWI device detected at address 0x5D.
 0> <info> app: TWI device detected at address 0x6A.
 <nRF5_SDK_15.2.0_9412b96\examples\peripheral\twi_master_using_nrf_twi_mngr>
 0>
 0> TWI master example started.
 * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup nrf_twi_master_example main.c
 * @ingroup nrf_twi_example
 * @brief TWI Example Application main file.
 * This file contains the source code for a sample application using TWI.
#include <stdio.h>
#include "boards.h"
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_clock.h"
#include "bsp.h"
#include "app_error.h"
#include "nrf_twi_mngr.h"
#include "lm75b.h"
#include "mma7660.h"
#include "compiler_abstraction.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define TWI_INSTANCE_ID             0
#define MAX_PENDING_TRANSACTIONS    5
NRF_TWI_MNGR_DEF(m_nrf_twi_mngr, MAX_PENDING_TRANSACTIONS, TWI_INSTANCE_ID);
APP_TIMER_DEF(m_timer);
// Pin number for indicating communication with sensors.
#ifdef BSP_LED_3
    #define READ_ALL_INDICATOR  BSP_BOARD_LED_3
#else
    #error "Please choose an output pin"
// Buffer for data read from sensors.
#define BUFFER_SIZE  11
static uint8_t m_buffer[BUFFER_SIZE];
// Data structures needed for averaging of data read from sensors.
// [max 32, otherwise "int16_t" won't be sufficient to hold the sum
//  of temperature samples]
#define NUMBER_OF_SAMPLES  16
typedef struct
    int16_t temp;
    int16_t x;
    int16_t y;
    int16_t z;
} sum_t;
static sum_t m_sum = { 0, 0, 0, 0 };
typedef struct
    // [use bit fields to fit whole structure into one 32-bit word]
    int16_t temp : 11;
    int8_t  x    : 6;
    int8_t  y    : 6;
    int8_t  z    : 6;
} sample_t;
static sample_t m_samples[NUMBER_OF_SAMPLES] = { { 0, 0, 0, 0 } };
static uint8_t m_sample_idx = 0;
// Value previously read from MMA7660's Tilt register - used to detect change
// in orientation, shake signaling etc.
static uint8_t m_prev_tilt = 0;
#if defined( __GNUC__ ) && (__LINT__ == 0)
    // This is required if one wants to use floating-point values in 'printf'
    // (by default this feature is not linked together with newlib-nano).
    // Please note, however, that this adds about 13 kB code footprint...
    __ASM(".global _printf_float");
// Reading of data from sensors - current temperature from LM75B and from
// MMA7660: X, Y, Z and tilt status.
#if (BUFFER_SIZE < 6)
    #error Buffer too small.
#define GET_ACC_VALUE(axis, reg_data) \
    do { \
        if (MMA7660_DATA_IS_VALID(reg_data)) \
            axis = MMA7660_GET_ACC(reg_data); \
    } while (0)
void read_all_cb(ret_code_t result, void * p_user_data)
    if (result != NRF_SUCCESS)
        NRF_LOG_WARNING("read_all_cb - error: %d", (int)result);
        return;
    sample_t * p_sample = &m_samples[m_sample_idx];
    m_sum.temp -= p_sample->temp;
    m_sum.x    -= p_sample->x;
    m_sum.y    -= p_sample->y;
    m_sum.z    -= p_sample->z;
    uint8_t temp_hi = m_buffer[0];
    uint8_t temp_lo = m_buffer[1];
    uint8_t x_out   = m_buffer[2];
    uint8_t y_out   = m_buffer[3];
    uint8_t z_out   = m_buffer[4];
    uint8_t tilt    = m_buffer[5];
    p_sample->temp = LM75B_GET_TEMPERATURE_VALUE(temp_hi, temp_lo);
    GET_ACC_VALUE(p_sample->x, x_out);
    GET_ACC_VALUE(p_sample->y, y_out);
    GET_ACC_VALUE(p_sample->z, z_out);
    if (!MMA7660_DATA_IS_VALID(tilt))
        tilt = m_prev_tilt;
    m_sum.temp += p_sample->temp;
    m_sum.x    += p_sample->x;
    m_sum.y    += p_sample->y;
    m_sum.z    += p_sample->z;
    ++m_sample_idx;
    if (m_sample_idx >= NUMBER_OF_SAMPLES)
        m_sample_idx = 0;
    // Show current average values every time sample index rolls over (for RTC
    // ticking at 32 Hz and 16 samples it will be every 500 ms) or when tilt
    // status changes.
    if (m_sample_idx == 0 || (m_prev_tilt && m_prev_tilt != tilt))
        char const * orientation;
        switch (MMA7660_GET_ORIENTATION(tilt))
            case MMA7660_ORIENTATION_LEFT:  orientation = "LEFT";  break;
            case MMA7660_ORIENTATION_RIGHT: orientation = "RIGHT"; break;
            case MMA7660_ORIENTATION_DOWN:  orientation = "DOWN";  break;
            case MMA7660_ORIENTATION_UP:    orientation = "UP";    break;
            default:                        orientation = "?";     break;
        NRF_LOG_RAW_INFO("Temp: " NRF_LOG_FLOAT_MARKER " | X: %3d, Y: %3d, Z: %3d ",
            NRF_LOG_FLOAT((float)((m_sum.temp * 0.125) / NUMBER_OF_SAMPLES)),
            m_sum.x / NUMBER_OF_SAMPLES,
            m_sum.y / NUMBER_OF_SAMPLES,
            m_sum.z / NUMBER_OF_SAMPLES);
        NRF_LOG_RAW_INFO("| %s%s%s\r\n",
            (uint32_t)orientation,
            (uint32_t)(MMA7660_TAP_DETECTED(tilt)   ? " TAP"   : ""),
            (uint32_t)(MMA7660_SHAKE_DETECTED(tilt) ? " SHAKE" : ""));
        m_prev_tilt = tilt;
static void read_all(void)
    // [these structures have to be "static" - they cannot be placed on stack
    //  since the transaction is scheduled and these structures most likely
    //  will be referred after this function returns]
    static nrf_twi_mngr_transfer_t const transfers[] =
        LM75B_READ_TEMP(&m_buffer[0])
        MMA7660_READ_XYZ_AND_TILT(&m_buffer[2])
    static nrf_twi_mngr_transaction_t NRF_TWI_MNGR_BUFFER_LOC_IND transaction =
        .callback            = read_all_cb,
        .p_user_data         = NULL,
        .p_transfers         = transfers,
        .number_of_transfers = sizeof(transfers) / sizeof(transfers[0])
    APP_ERROR_CHECK(nrf_twi_mngr_schedule(&m_nrf_twi_mngr, &transaction));
    // Signal on LED that something is going on.
    bsp_board_led_invert(READ_ALL_INDICATOR);
#if (BUFFER_SIZE < 7)
static void read_lm75b_registers_cb(ret_code_t result, void * p_user_data)
        NRF_LOG_WARNING("read_lm75b_registers_cb - error: %d", (int)result);
        return;
    NRF_LOG_DEBUG("LM75B:");
    NRF_LOG_HEXDUMP_DEBUG(m_buffer, 7);
static void read_lm75b_registers(void)
        LM75B_READ(&lm75b_conf_reg_addr,  &m_buffer[0], 1),
        LM75B_READ(&lm75b_temp_reg_addr,  &m_buffer[1], 2),
        LM75B_READ(&lm75b_tos_reg_addr,   &m_buffer[3], 2),
        LM75B_READ(&lm75b_thyst_reg_addr, &m_buffer[5], 2)
        .callback            = read_lm75b_registers_cb,
#if (BUFFER_SIZE < MMA7660_NUMBER_OF_REGISTERS)
static void read_mma7660_registers_cb(ret_code_t result, void * p_user_data)
        NRF_LOG_WARNING("read_mma7660_registers_cb - error: %d", (int)result);
        return;
    NRF_LOG_DEBUG("MMA7660:");
    NRF_LOG_HEXDUMP_DEBUG(m_buffer, MMA7660_NUMBER_OF_REGISTERS);
static void read_mma7660_registers(void)
        MMA7660_READ(&mma7660_xout_reg_addr,
        .callback            = read_mma7660_registers_cb,
// Buttons handling (by means of BSP).
static void bsp_event_handler(bsp_event_t event)
    // Each time the button 1 or 4 is pushed we start a transaction reading
    // values of all registers from LM75B or MMA7660 respectively.
    switch (event)
    case BSP_EVENT_KEY_0: // Button 1 pushed.
        read_lm75b_registers();
    case BSP_EVENT_KEY_3: // Button 4 pushed.
        read_mma7660_registers();
static void bsp_config(void)
    uint32_t err_code;
    err_code = app_timer_init();
    err_code = bsp_init(BSP_INIT_BUTTONS, bsp_event_handler);
// TWI (with transaction manager) initialization.
static void twi_config(void)
    uint32_t err_code;
    nrf_drv_twi_config_t const config = {
       .scl                = 16,		//ARDUINO_SCL_PIN,
       .sda                = 17,		//ARDUINO_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_LOWEST,
       .clear_bus_init     = false
    err_code = nrf_twi_mngr_init(&m_nrf_twi_mngr, &config);
static void lfclk_config(void)
    uint32_t err_code;
    err_code = nrf_drv_clock_init();
void timer_handler(void * p_context)
    read_all();
void read_init(void)
    ret_code_t err_code;
    err_code = app_timer_create(&m_timer, APP_TIMER_MODE_REPEATED, timer_handler);
    err_code = app_timer_start(m_timer, APP_TIMER_TICKS(50), NULL);
void log_init(void)
    err_code = NRF_LOG_INIT(NULL);
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    log_init();
    // Start internal LFCLK XTAL oscillator - it is needed by BSP to handle
    // buttons with the use of APP_TIMER and for "read_all" ticks generation
    // (by RTC).
    lfclk_config();
    bsp_config();
    NRF_LOG_RAW_INFO("\r\nTWI master example started. \r\n");
    NRF_LOG_FLUSH();
    twi_config();
	//insert twi_scanner code
    uint8_t address;
    uint8_t sample_data;
    bool detected_device = false;
	#define TWI_ADDRESSES	127
    for (address = 1; address <= TWI_ADDRESSES; address++)
        err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
        if (err_code == NRF_SUCCESS)
            detected_device = true;
            NRF_LOG_INFO("TWI device detected at address 0x%x.", address);
        NRF_LOG_FLUSH();
    while(1) {};
    read_init();
    // Initialize sensors.
    APP_ERROR_CHECK(nrf_twi_mngr_perform(&m_nrf_twi_mngr, NULL, lm75b_init_transfers,
        LM75B_INIT_TRANSFER_COUNT, NULL));
    APP_ERROR_CHECK(nrf_twi_mngr_perform(&m_nrf_twi_mngr, NULL, mma7660_init_transfers,
        MMA7660_INIT_TRANSFER_COUNT, NULL));
    while (true)
        nrf_pwr_mgmt_run();
        NRF_LOG_FLUSH();
 * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
/** @file
 * @defgroup tw_scanner main.c
 * @brief TWI Sensor Example main file.
#include <stdio.h>
#include "boards.h"
#include "nrf_drv_twi.h"
/* TWI instance ID. */
#if TWI0_ENABLED
#elif TWI1_ENABLED
#define TWI_INSTANCE_ID     1
 /* Number of possible TWI addresses. */
/* TWI instance. */
 * @brief TWI initialization.
void twi_init (void)
    const nrf_drv_twi_config_t twi_config = {
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
    nrf_drv_twi_enable(&m_twi);
    uint8_t address;
    NRF_LOG_INFO("TWI scanner started.");
    NRF_LOG_FLUSH();
    twi_init();
        NRF_LOG_FLUSH();
    if (!detected_device)
        NRF_LOG_INFO("No device was found.");
        NRF_LOG_FLUSH();
    while (true)
        /* Empty loop. */
/** @file
 * @defgroup tw_sensor_example main.c
#include <stdio.h>
#include "boards.h"
#include "nrf_delay.h"
/* Common addresses definition for temperature sensor. */
#define LM75B_ADDR          (0x90U >> 1)
#define LM75B_REG_TEMP      0x00U
#define LM75B_REG_CONF      0x01U
#define LM75B_REG_THYST     0x02U
#define LM75B_REG_TOS       0x03U
/* Mode for LM75B. */
#define NORMAL_MODE 0U
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample;
 * @brief Function for setting active mode on MMA7660 accelerometer.
void LM75B_set_mode(void)
    /* Writing to LM75B_REG_CONF "0" set temperature sensor in NORMAL mode. */
    uint8_t reg[2] = {LM75B_REG_CONF, NORMAL_MODE};
    err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, sizeof(reg), false);
    while (m_xfer_done == false);
    /* Writing to pointer byte. */
    reg[0] = LM75B_REG_TEMP;
    err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, 1, false);
 * @brief Function for handling data from temperature sensor.
 * @param[in] temp          Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t temp)
    NRF_LOG_INFO("Temperature: %d Celsius degrees.", temp);
 * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                data_handler(m_sample);
            m_xfer_done = true;
 * @brief UART initialization.
    const nrf_drv_twi_config_t twi_lm75b_config = {
    err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
 * @brief Function for reading data from temperature sensor.
static void read_sensor_data()
    /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
    ret_code_t err_code = nrf_drv_twi_rx(&m_twi, LM75B_ADDR, &m_sample, sizeof(m_sample));
    NRF_LOG_INFO("\r\nTWI sensor example started.");
    NRF_LOG_FLUSH();
    twi_init();
    uint8_t address;
        NRF_LOG_FLUSH();
	while(1) {};
    LM75B_set_mode();
    while (true)
        nrf_delay_ms(500);
        do
            __WFE();
        }while (m_xfer_done == false);
        read_sensor_data();
        NRF_LOG_FLUSH();
I attached the file that printed the output address Also attached main.c I would appreciate your advice on why this is happening.
