Slave address read unexpectedly in TWI
Hi, Everyone
I use sdk15.2 & nrf52832
I am doing a test to read the slave address in TWI
There is one slave device on the board and the slave address is 0x68
I used three examples in twi_scanner, twi_sensor, twi_master_using_nrf_twi_mgnr The slave addresses read from each program are read differently
 < nRF5_SDK_15.2.0_9412b96\examples\peripheral\twi_scanner >
 0> <info> app: TWI scanner started.
 0> <info> app: TWI device detected at address 0x68.
 < nRF5_SDK_15.2.0_9412b96\examples\peripheral\twi_sensor >
  0> <info> app:
 0> TWI sensor example started.
 0> <info> app: TWI device detected at address 0x1.
 0> <info> app: TWI device detected at address 0xE.
 0> <info> app: TWI device detected at address 0x1C.
 0> <info> app: TWI device detected at address 0x29.
 0> <info> app: TWI device detected at address 0x36.
 0> <info> app: TWI device detected at address 0x43.
 0> <info> app: TWI device detected at address 0x50.
 0> <info> app: TWI device detected at address 0x5D.
 0> <info> app: TWI device detected at address 0x6A.
 <nRF5_SDK_15.2.0_9412b96\examples\peripheral\twi_master_using_nrf_twi_mngr>
 0>
 0> TWI master example started.
 * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup nrf_twi_master_example main.c
 * @ingroup nrf_twi_example
 * @brief TWI Example Application main file.
 * This file contains the source code for a sample application using TWI.
#include <stdio.h>
#include "boards.h"
#include "app_timer.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_drv_clock.h"
#include "bsp.h"
#include "app_error.h"
#include "nrf_twi_mngr.h"
#include "lm75b.h"
#include "mma7660.h"
#include "compiler_abstraction.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define TWI_INSTANCE_ID             0
#define MAX_PENDING_TRANSACTIONS    5
NRF_TWI_MNGR_DEF(m_nrf_twi_mngr, MAX_PENDING_TRANSACTIONS, TWI_INSTANCE_ID);
APP_TIMER_DEF(m_timer);
// Pin number for indicating communication with sensors.
#ifdef BSP_LED_3
    #define READ_ALL_INDICATOR  BSP_BOARD_LED_3
#else
    #error "Please choose an output pin"
// Buffer for data read from sensors.
#define BUFFER_SIZE  11
static uint8_t m_buffer[BUFFER_SIZE];
// Data structures needed for averaging of data read from sensors.
// [max 32, otherwise "int16_t" won't be sufficient to hold the sum
//  of temperature samples]
#define NUMBER_OF_SAMPLES  16
typedef struct
    int16_t temp;
    int16_t x;
    int16_t y;
    int16_t z;
} sum_t;
static sum_t m_sum = { 0, 0, 0, 0 };
typedef struct
    // [use bit fields to fit whole structure into one 32-bit word]
    int16_t temp : 11;
    int8_t  x    : 6;
    int8_t  y    : 6;
    int8_t  z    : 6;
} sample_t;
static sample_t m_samples[NUMBER_OF_SAMPLES] = { { 0, 0, 0, 0 } };
static uint8_t m_sample_idx = 0;
// Value previously read from MMA7660's Tilt register - used to detect change
// in orientation, shake signaling etc.
static uint8_t m_prev_tilt = 0;
#if defined( __GNUC__ ) && (__LINT__ == 0)
    // This is required if one wants to use floating-point values in 'printf'
    // (by default this feature is not linked together with newlib-nano).
    // Please note, however, that this adds about 13 kB code footprint...
    __ASM(".global _printf_float");
// Reading of data from sensors - current temperature from LM75B and from
// MMA7660: X, Y, Z and tilt status.
#if (BUFFER_SIZE < 6)
    #error Buffer too small.
#define GET_ACC_VALUE(axis, reg_data) \
    do { \
        if (MMA7660_DATA_IS_VALID(reg_data)) \
            axis = MMA7660_GET_ACC(reg_data); \
    } while (0)
void read_all_cb(ret_code_t result, void * p_user_data)
    if (result != NRF_SUCCESS)
        NRF_LOG_WARNING("read_all_cb - error: %d", (int)result);
        return;
    sample_t * p_sample = &m_samples[m_sample_idx];
    m_sum.temp -= p_sample->temp;
    m_sum.x    -= p_sample->x;
    m_sum.y    -= p_sample->y;
    m_sum.z    -= p_sample->z;
    uint8_t temp_hi = m_buffer[0];
    uint8_t temp_lo = m_buffer[1];
    uint8_t x_out   = m_buffer[2];
    uint8_t y_out   = m_buffer[3];
    uint8_t z_out   = m_buffer[4];
    uint8_t tilt    = m_buffer[5];
    p_sample->temp = LM75B_GET_TEMPERATURE_VALUE(temp_hi, temp_lo);
    GET_ACC_VALUE(p_sample->x, x_out);
    GET_ACC_VALUE(p_sample->y, y_out);
    GET_ACC_VALUE(p_sample->z, z_out);
    if (!MMA7660_DATA_IS_VALID(tilt))
        tilt = m_prev_tilt;
    m_sum.temp += p_sample->temp;
    m_sum.x    += p_sample->x;
    m_sum.y    += p_sample->y;
    m_sum.z    += p_sample->z;
    ++m_sample_idx;
    if (m_sample_idx >= NUMBER_OF_SAMPLES)
        m_sample_idx = 0;
    // Show current average values every time sample index rolls over (for RTC
    // ticking at 32 Hz and 16 samples it will be every 500 ms) or when tilt
    // status changes.
    if (m_sample_idx == 0 || (m_prev_tilt && m_prev_tilt != tilt))
        char const * orientation;
        switch (MMA7660_GET_ORIENTATION(tilt))
            case MMA7660_ORIENTATION_LEFT:  orientation = "LEFT";  break;
            case MMA7660_ORIENTATION_RIGHT: orientation = "RIGHT"; break;
            case MMA7660_ORIENTATION_DOWN:  orientation = "DOWN";  break;
            case MMA7660_ORIENTATION_UP:    orientation = "UP";    break;
            default:                        orientation = "?";     break;
        NRF_LOG_RAW_INFO("Temp: " NRF_LOG_FLOAT_MARKER " | X: %3d, Y: %3d, Z: %3d ",
            NRF_LOG_FLOAT((float)((m_sum.temp * 0.125) / NUMBER_OF_SAMPLES)),
            m_sum.x / NUMBER_OF_SAMPLES,
            m_sum.y / NUMBER_OF_SAMPLES,
            m_sum.z / NUMBER_OF_SAMPLES);
        NRF_LOG_RAW_INFO("| %s%s%s\r\n",
            (uint32_t)orientation,
            (uint32_t)(MMA7660_TAP_DETECTED(tilt)   ? " TAP"   : ""),
            (uint32_t)(MMA7660_SHAKE_DETECTED(tilt) ? " SHAKE" : ""));
        m_prev_tilt = tilt;
static void read_all(void)
    // [these structures have to be "static" - they cannot be placed on stack
    //  since the transaction is scheduled and these structures most likely
    //  will be referred after this function returns]
    static nrf_twi_mngr_transfer_t const transfers[] =
        LM75B_READ_TEMP(&m_buffer[0])
        MMA7660_READ_XYZ_AND_TILT(&m_buffer[2])
    static nrf_twi_mngr_transaction_t NRF_TWI_MNGR_BUFFER_LOC_IND transaction =
        .callback            = read_all_cb,
        .p_user_data         = NULL,
        .p_transfers         = transfers,
        .number_of_transfers = sizeof(transfers) / sizeof(transfers[0])
    APP_ERROR_CHECK(nrf_twi_mngr_schedule(&m_nrf_twi_mngr, &transaction));
    // Signal on LED that something is going on.
    bsp_board_led_invert(READ_ALL_INDICATOR);
#if (BUFFER_SIZE < 7)
static void read_lm75b_registers_cb(ret_code_t result, void * p_user_data)
        NRF_LOG_WARNING("read_lm75b_registers_cb - error: %d", (int)result);
        return;
    NRF_LOG_DEBUG("LM75B:");
    NRF_LOG_HEXDUMP_DEBUG(m_buffer, 7);
static void read_lm75b_registers(void)
        LM75B_READ(&lm75b_conf_reg_addr,  &m_buffer[0], 1),
        LM75B_READ(&lm75b_temp_reg_addr,  &m_buffer[1], 2),
        LM75B_READ(&lm75b_tos_reg_addr,   &m_buffer[3], 2),
        LM75B_READ(&lm75b_thyst_reg_addr, &m_buffer[5], 2)
        .callback            = read_lm75b_registers_cb,
#if (BUFFER_SIZE < MMA7660_NUMBER_OF_REGISTERS)
static void read_mma7660_registers_cb(ret_code_t result, void * p_user_data)
        NRF_LOG_WARNING("read_mma7660_registers_cb - error: %d", (int)result);
        return;
    NRF_LOG_DEBUG("MMA7660:");
    NRF_LOG_HEXDUMP_DEBUG(m_buffer, MMA7660_NUMBER_OF_REGISTERS);
static void read_mma7660_registers(void)
        MMA7660_READ(&mma7660_xout_reg_addr,
        .callback            = read_mma7660_registers_cb,
// Buttons handling (by means of BSP).
static void bsp_event_handler(bsp_event_t event)
    // Each time the button 1 or 4 is pushed we start a transaction reading
    // values of all registers from LM75B or MMA7660 respectively.
    switch (event)
    case BSP_EVENT_KEY_0: // Button 1 pushed.
        read_lm75b_registers();
    case BSP_EVENT_KEY_3: // Button 4 pushed.
        read_mma7660_registers();
static void bsp_config(void)
    uint32_t err_code;
    err_code = app_timer_init();
    err_code = bsp_init(BSP_INIT_BUTTONS, bsp_event_handler);
// TWI (with transaction manager) initialization.
static void twi_config(void)
    uint32_t err_code;
    nrf_drv_twi_config_t const config = {
       .scl                = 16,		//ARDUINO_SCL_PIN,
       .sda                = 17,		//ARDUINO_SDA_PIN,
       .frequency          = NRF_DRV_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_LOWEST,
       .clear_bus_init     = false
    err_code = nrf_twi_mngr_init(&m_nrf_twi_mngr, &config);
static void lfclk_config(void)
    uint32_t err_code;
    err_code = nrf_drv_clock_init();
void timer_handler(void * p_context)
    read_all();
void read_init(void)
    ret_code_t err_code;
    err_code = app_timer_create(&m_timer, APP_TIMER_MODE_REPEATED, timer_handler);
    err_code = app_timer_start(m_timer, APP_TIMER_TICKS(50), NULL);
void log_init(void)
    err_code = NRF_LOG_INIT(NULL);
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    log_init();
    // Start internal LFCLK XTAL oscillator - it is needed by BSP to handle
    // buttons with the use of APP_TIMER and for "read_all" ticks generation
    // (by RTC).
    lfclk_config();
    bsp_config();
    NRF_LOG_RAW_INFO("\r\nTWI master example started. \r\n");
    NRF_LOG_FLUSH();
    twi_config();
	//insert twi_scanner code
    uint8_t address;
    uint8_t sample_data;
    bool detected_device = false;
	#define TWI_ADDRESSES	127
    for (address = 1; address <= TWI_ADDRESSES; address++)
        err_code = nrf_drv_twi_rx(&m_twi, address, &sample_data, sizeof(sample_data));
        if (err_code == NRF_SUCCESS)
            detected_device = true;
            NRF_LOG_INFO("TWI device detected at address 0x%x.", address);
        NRF_LOG_FLUSH();
    while(1) {};
    read_init();
    // Initialize sensors.
    APP_ERROR_CHECK(nrf_twi_mngr_perform(&m_nrf_twi_mngr, NULL, lm75b_init_transfers,
        LM75B_INIT_TRANSFER_COUNT, NULL));
    APP_ERROR_CHECK(nrf_twi_mngr_perform(&m_nrf_twi_mngr, NULL, mma7660_init_transfers,
        MMA7660_INIT_TRANSFER_COUNT, NULL));
    while (true)
        nrf_pwr_mgmt_run();
        NRF_LOG_FLUSH();
 * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
/** @file
 * @defgroup tw_scanner main.c
 * @brief TWI Sensor Example main file.
#include <stdio.h>
#include "boards.h"
#include "nrf_drv_twi.h"
/* TWI instance ID. */
#if TWI0_ENABLED
#elif TWI1_ENABLED
#define TWI_INSTANCE_ID     1
 /* Number of possible TWI addresses. */
/* TWI instance. */
 * @brief TWI initialization.
void twi_init (void)
    const nrf_drv_twi_config_t twi_config = {
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
    err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
    nrf_drv_twi_enable(&m_twi);
    uint8_t address;
    NRF_LOG_INFO("TWI scanner started.");
    NRF_LOG_FLUSH();
    twi_init();
        NRF_LOG_FLUSH();
    if (!detected_device)
        NRF_LOG_INFO("No device was found.");
        NRF_LOG_FLUSH();
    while (true)
        /* Empty loop. */
/** @file
 * @defgroup tw_sensor_example main.c
#include <stdio.h>
#include "boards.h"
#include "nrf_delay.h"
/* Common addresses definition for temperature sensor. */
#define LM75B_ADDR          (0x90U >> 1)
#define LM75B_REG_TEMP      0x00U
#define LM75B_REG_CONF      0x01U
#define LM75B_REG_THYST     0x02U
#define LM75B_REG_TOS       0x03U
/* Mode for LM75B. */
#define NORMAL_MODE 0U
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
/* Buffer for samples read from temperature sensor. */
static uint8_t m_sample;
 * @brief Function for setting active mode on MMA7660 accelerometer.
void LM75B_set_mode(void)
    /* Writing to LM75B_REG_CONF "0" set temperature sensor in NORMAL mode. */
    uint8_t reg[2] = {LM75B_REG_CONF, NORMAL_MODE};
    err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, sizeof(reg), false);
    while (m_xfer_done == false);
    /* Writing to pointer byte. */
    reg[0] = LM75B_REG_TEMP;
    err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, 1, false);
 * @brief Function for handling data from temperature sensor.
 * @param[in] temp          Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(uint8_t temp)
    NRF_LOG_INFO("Temperature: %d Celsius degrees.", temp);
 * @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
    switch (p_event->type)
        case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
                data_handler(m_sample);
            m_xfer_done = true;
 * @brief UART initialization.
    const nrf_drv_twi_config_t twi_lm75b_config = {
    err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
 * @brief Function for reading data from temperature sensor.
static void read_sensor_data()
    /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
    ret_code_t err_code = nrf_drv_twi_rx(&m_twi, LM75B_ADDR, &m_sample, sizeof(m_sample));
    NRF_LOG_INFO("\r\nTWI sensor example started.");
    NRF_LOG_FLUSH();
    twi_init();
    uint8_t address;
        NRF_LOG_FLUSH();
	while(1) {};
    LM75B_set_mode();
    while (true)
        nrf_delay_ms(500);
        do
            __WFE();
        }while (m_xfer_done == false);
        read_sensor_data();
        NRF_LOG_FLUSH();
I attached the file that printed the output address Also attached main.c I would appreciate your advice on why this is happening.
  • read the slave address in TWI
    That doesn't make sense!
    You don't read the Slave Address in I2C (aka TWI).
    You send the Slave address to identify which slave should respond.
    I think you need to review how I2C works:
    Here is the I2C Specification: https://www.nxp.com/docs/en/user-guide/UM10204.pdf
    https://en.wikipedia.org/wiki/I%C2%B2C
    etc, ...
  • Hi, awneil
    1. I used the following code to detect the TWI address of the Slave
       NRF_LOG_FLUSH();
    2. my scl and sda were connected to p16 and p17
    3. twi_init()
    1) ret_code_t ret = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
    The slave address is detected as 0x68. It is normal.
    2) ret_code_t ret = nrf_drv_twi_init(&m_twi, &twi_config, twi_handler, NULL);
           m_xfer_done = true;
    0> <info> app: TWI device detected at address 0x5.
    0> <info> app: TWI device detected at address 0x8.
    0> <info> app: TWI device detected at address 0xB.
    0> <info> app: TWI device detected at address 0x12.
    0> <info> app: TWI device detected at address 0x15.
    0> <info> app: TWI device detected at address 0x18.
    0> <info> app: TWI device detected at address 0x1B.
    0> <info> app: TWI device detected at address 0x1E.
    A strange slave address is detected.
    0x68 is not visible
    Best Regards,
    Alex
  • #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_drv_saadc.h"
    //                data_handler(m_sample);
                m_xfer_done = true;
           .frequency          = NRF_DRV_TWI_FREQ_400K,
    //    err_code = nrf_drv_twi_init(&m_twi, &twi_config, twi_handler, NULL);
        bool erase_bonds;
        // Initialize.
         uart_init();
        log_init();
        timers_init();
    	cat_timers_init();
    	saadc_init();
        twi_init();
    	uint8_t detected_device = 0;
        for (uint8_t address = 1; address <= TWI_ADDRESSES; address++)
            NRF_LOG_FLUSH();
            NRF_LOG_FLUSH();
        ICM20602_whoAmI();
    	ICM20602_init();
    	gpio_led_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        advertising_start();
    	cat_timers_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    I am having a bit of problem seeing how you do things in the second (non-working) case, where you use non-blocking transfers. Where do you print the "TWI device detected at address xx" in that case? The code you have posted is just for the first case (which is working as expected from what I understand).
