SOFTDEVICE: ASSERTION FAILED while running mesh.
Hi, I'm getting regular crashes with my app: SOFTDEVICE: ASSERTION FAILED.
Using and NRF52832, SDK 15.3.0, SD 132 6.1.1, and Mesh SDK 3.1.0.
With DEBUG defined, I don't really get more info: id=1, pc=148742, info=0.
The last mesh log usually is something with TX (mostly net_beacon.c,  265, BEACON TX).
One crash, I also had a log of getting event NRF_EVT_RADIO_SESSION_IDLE.
I use the mesh SDK to communicate via mesh between nodes, to advertise iBeacon (100ms interval), and I use the scan callback. Next to that, I also use the SD to advertise service data.
Parameters:
	nrf_clock_lf_cfg_t lfclksrc;
	lfclksrc.source = NRF_SDH_CLOCK_LF_SRC;
	lfclksrc.rc_ctiv = NRF_SDH_CLOCK_LF_RC_CTIV;
	lfclksrc.rc_temp_ctiv = NRF_SDH_CLOCK_LF_RC_TEMP_CTIV;
	lfclksrc.accuracy = NRF_CLOCK_LF_ACCURACY_20_PPM;
	mesh_stack_init_params_t init_params;
	init_params.core.irq_priority       = NRF_MESH_IRQ_PRIORITY_THREAD;
	init_params.core.lfclksrc           = lfclksrc;
	init_params.core.p_uuid             = NULL;
	init_params.core.relay_cb           = NULL;
Any idea of what causes this crash?
  • Another update: "As I see, they are using FDS. If you see the mesh SDK documentation:
    https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.meshsdk.v3.2.0/md_doc_getting_started_how_to_nordicSDK.html?cp=5_2_1_7
    We mention that:
    nRF5 SDK NVM storage modules
    Using nRF5 SDK modules such as fstorage, pstorage, or ble_flash for writing to flash may be problematic due to long timeslot events occupied by the mesh stack. Use the Flash manager module provided by the mesh stack instead.
    He can either use flash manager or better, mesh_config, as used in various other internal modules.
    Also, for beacon advertising, if possible, use the Mesh advertiser instead of SD advertiser."
  • Ah, I read this as FDS will get in some trouble (write timeouts), not the mesh getting into trouble, and definitely not getting SD asserts. Also, above your quote, the documentation mentions:
    To allow safe coexistence of the flash storage module Flash manager in the mesh stack and the flash storage module fstorage in the Nordic nRF5 SDK, add the following code block to nrf_mesh_config_app.h
    So that makes one think it's fine to use FDS next to flash manager. Can you maybe explain why FDS would lead to SD asserts?
    Regarding the advertising, doesn't the mesh use the timeslot API for that? If so, why would it matter that I also use SD advertiser? Seeing how mesh messages are also just advertisements, you'd expect it doesn't matter for the mesh whether it's advertising mesh messages or iBeacon messages. How would SD advertising result in SD asserts?
    Also, how come setting TIMESLOT_END_SAFETY_MARGIN_US to 1000 makes these asserts vanish?
  • Very sorry for the delayed response. Received an update: "Using the FDS shouldn't normally cause the mesh to kill the Softdevice, neither should the SD advertiser. Since increasing the safety margin helps, it sounds like there's either some IRQ locking going on in the application or some excessive clock drift that is causing this problem. My bet is on the former.
    To rule out any clock drift issues, they can try running the application on a DK if they're on a custom HW platform. They can also try running the normal examples on the same HW with proxy enabled. If this is a xtal HW problem, any softdevice activity on an unedited example application should invoke the same crash.
    Next, I'd profile any and all IRQ locking (including SDK modules). A full IRQ lock preferably shouldn't last for more than 20us, and definitely not for more than 50us. Both the softdevice API for locking (sd_nvic_critical_region_enter) and the hardware API (_DISABLE_IRQS(), __disable_irq()) could be causing issues here. Also make sure that no application interrupts are executing in any of the Softdevice IRQ levels.
    If none of this explains it, I think we'd need more details to determine the cause. What happens right before the crash? Is it possible to get a logic analyzer trace of the crash with mesh debug pins enabled and initialized for timeslot? What's the XTAL accuracy passed to mesh_stack_init? Does it fit with the XTAL HW?"
