Thingy:91
Dear,
I received THINGY:91 from NordicSemi. I use 10pins cable to connect to nRF9160 DK to program for THINGY:91.
and, I am using ncs_v1.0.0
I am trying to run asset_tracker application,
and I am confusing about:
1. which board should I select? I tried to use    ncs_v1.0.0/zephyr/boards/arm/nrf9160_pca10090
but after programming, the LED on THINGY:91 changed to RED color, and I couldnt connect it from nrfcloud
I couldn't find pca20035 on ncs_v1.0.0. Do I need to use another version of ncs ?
2. How can I debug the output from THINGY:91
The terminal still shows the output from nRF9160 DK, nothing from THINGY:91
Mvh
Hoang Nguyen
  • 1 lucky time, I got a fix:
    Scanning [-] [1B][1;1H[1B][2JTracking: 6 Using: 6 Unhealthy: 0
    Seconds since last fix 224
    Scanning [\] [1B][1;1H[1B][2JTracking: 6 Using: 6 Unhealthy: 0
    Scanning [|] [1B][1;1H[1B][2JTracking: 6 Using: 6 Unhealthy: 0
    Seconds since last fix 225
    Scanning [/] [1B][1;1H[1B][2JTracking: 6 Using: 6 Unhealthy: 0
    Seconds since last fix 0
    Longitude:  10.485387
    Latitude:   59.407918
    Altitude:   19.649757
    Speed:      0.296371
    Heading:    0.000000
    Date:       01-08-2019
    Time (UTC): 11:41:26
    NMEA strings:
    $GPGGA,114126.68,5924.47509,N,01029.12322,E,1,07,3.86,19.64,M,0,,*13
    Here, the log file of asset_tracker:
    Asset tracker started
    [00:00:01.824,707] [1B][0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656100245946[1B][0m
    [00:00:01.833,770] [1B][0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/nrf-352656100245946/shadow[1B][0m
    [00:00:01.845,184] [1B][0m<dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: $aws/things/nrf-352656100245946/shadow/get/accepted[1B][0m
    [00:00:01.857,452] [1B][0m<dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656100245946/shadow/get/rejected[1B][0m
    [00:00:01.869,720] [1B][0m<dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656100245946/shadow/update/delta[1B][0m
    [00:00:01.882,324] [1B][0m<dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/nrf-352656100245946/shadow/update[1B][0m
    [00:00:01.893,920] [1B][0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/nrf-352656100245946/shadow/get[1B][0m
    Connecting to LTE network. This may take several minutes.
    [00:00:06.075,500] [1B][0m<dbg> lte_lc.at_handler: recv: +CEREG: 2,"765D","0110C303",7
    [1B][0m
    [00:00:08.213,195] [1B][0m<dbg> lte_lc.at_handler: recv: +CEREG: 5,"765D","0110C303",7
    [1B][0m
    Connected to LTE network
    [00:00:08.388,793] [1B][0m<dbg> nrf_cloud_transport.nct_connect: IPv4 Address 0x1043ad36[1B][0m
    [00:00:13.937,042] [1B][0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_CONNACK[1B][0m
    [00:00:13.945,007] [1B][0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 2[1B][0m
    [00:00:13.952,606] [1B][0m<dbg> nrf_cloud.event_handler: NRF_CLOUD_EVT_TRANSPORT_CONNECTED[1B][0m
    CLOUD_EVT_CONNECTED
    [00:00:13.962,402] [1B][0m<dbg> nrf_cloud_transport.nct_cc_connect: nct_cc_connect[1B][0m
    [00:00:13.970,764] [1B][0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 3[1B][0m
    [00:00:14.209,075] [1B][0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id=1234 result=0[1B][0m
    [00:00:14.218,536] [1B][0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 4[1B][0m
    [00:00:14.226,104] [1B][0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id=5678 opcode=0 len=0[1B][0m
    [00:00:14.235,961] [1B][0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5[1B][0m
    [00:00:14.577,087] [1B][0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id=5678 result=0[1B][0m
    [00:00:14.586,547] [1B][0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 5[1B][0m
    [00:00:14.858,551] [1B][0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBLISH: id=1 len=1748 [1B][0m
    [00:00:14.875,244] [1B][0m<dbg> nrf_cloud_transport.nct_dc_endpoint_set: nct_dc_endpoint_set[1B][0m
    [00:00:14.883,453] [1B][0m<dbg> nrf_cloud_transport.nct_dc_endpoint_get: nct_dc_endpoint_get[1B][0m
    [00:00:14.891,723] [1B][0m<dbg> nrf_cloud_transport.nct_dc_endpoint_get: nct_dc_endpoint_get[1B][0m
    [00:00:14.901,062] [1B][0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id=7890 opcode=1 len=329[1B][0m
    [00:00:14.911,193] [1B][0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 7[1B][0m
    [00:00:14.918,762] [1B][0m<dbg> nrf_cloud.event_handler: NRF_CLOUD_EVT_USER_ASSOCIATED[1B][0m
    CLOUD_EVT_PAIR_DONE
    [00:00:15.533,081] [1B][0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id=7890 result=0[1B][0m
    [00:00:15.542,541] [1B][0m<dbg> nrf_cloud_transport.nct_dc_connect: nct_dc_connect[1B][0m
    [00:00:15.551,116] [1B][0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 13[1B][0m
    [00:00:15.825,134] [1B][0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_SUBACK: id=8765 result=0[1B][0m
    [00:00:15.834,716] [1B][0m<dbg> nrf_cloud.nfsm_set_current_state_and_notify: state: 14[1B][0m
    [00:00:15.842,376] [1B][0m<dbg> nrf_cloud.event_handler: NRF_CLOUD_EVT_READY[1B][0m
    CLOUD_EVT_READY
    Setting trigger
    GPS initialized
    [00:00:15.872,436] [1B][0m<dbg> nrf_cloud_transport.nct_cc_send: mqtt_publish: id=1 opcode=1 len=496[1B][0m
    [00:00:16.173,126] [1B][0m<dbg> nrf_cloud_transport.nct_mqtt_evt_handler: MQTT_EVT_PUBACK: id=1 result=0[1B][0m
    Starting GPS
    Enabling PSM
    PSM enabled
    [00:00:34.860,168] [1B][0m<dbg> nrf9160_gps.enable_gps: GPS mode is enabled[1B][0m
    [00:00:34.867,279] [1B][0m<dbg> nrf9160_gps.enable_gps: Functional mode: 1[1B][0m
    [00:00:34.874,145] [1B][0m<dbg> nrf9160_gps.start: GPS socket created[1B][0m
    [00:00:34.884,368] [1B][0m<dbg> nrf9160_gps.start: GPS operational[1B][0m
    GPS started successfully.
    Searching for satellites to get position fix. This may take several minutes.
    The device will attempt to get a fix for 360 seconds, before the GPS is stopped.
    GPS operation started
    [00:06:34.914,093] [1B][0m<dbg> nrf9160_gps.stop: Stopping GPS[1B][0m
    GPS operation was stopped
    The device will try to get fix again in 30 seconds
    Socket error: POLLHUP
    Reboot
    ***** Booting Zephyr OS build v1.14.99-ncs2-495-ga8933a2ead01 *****
    [00:00:00.005,615] [1B][0m<inf> mcuboot: Starting bootloader[1B][0m
    [00:00:00.011,901] [1B][0m<inf> mcuboot: Primary image: magic=unset, copy_done=0x3, image_ok=0x3[1B][0m
    [00:00:00.020,416] [1B][0m<inf> mcuboot: Scratch: magic=unset, copy_done=0x50, image_ok=0x3[1B][0m
    [00:00:00.028,503] [1B][0m<inf> mcuboot: Boot source: primary slot[1B][0m
    [00:00:00.036,926] [1B][0m<inf> mcuboot: Swap type: none[1B][0m
    [00:00:00.390,411] [1B][0m<inf> mcuboot: Bootloader chainload address offset: 0xc000[1B][0m
    [00:00:00.397,888] [1B][0m<inf> mcuboot: Jumping to the first image slot[1B][0m
    Flash region		Domain		Permissions
    00 0x00000 0x08000 	Secure		rwxl
    01 0x08000 0x10000 	Secure		rwxl
    02 0x10000 0x18000 	Secure		rwxl
    03 0x18000 0x20000 	Non-Secure	rwxl
    04 0x20000 0x28000 	Non-Secure	rwxl
    05 0x28000 0x30000 	Non-Secure	rwxl
    06 0x30000 0x38000 	Non-Secure	rwxl
    07 0x38000 0x40000 	Non-Secure	rwxl
  • Ok, 225 seconds is a long time for a fix but 6 satellites is very encouraging, I recieve 7 satellites from my location and that's using a Molex 206640 external patch antenna. That usually takes more than 2 minutes but i'm inside a building. You were outside correct?
  • Woh... ok that's not good. So from that log, the device tried to get a GPS lock, timed out after 360 seconds then encountered a socket error when I assume the 30 second GPS sleep timer expired. So is there an issue in the code for restarting the modem into GPS mode? I know from my own application that having a GPS timeout loop should work as I have one set to 3mins on and 5mins off if no first fix.
  • 225s is the best case, many others times couldnt fix
