Thingy:91
Dear,
I received THINGY:91 from NordicSemi. I use 10pins cable to connect to nRF9160 DK to program for THINGY:91.
and, I am using ncs_v1.0.0
I am trying to run asset_tracker application,
and I am confusing about:
1. which board should I select? I tried to use    ncs_v1.0.0/zephyr/boards/arm/nrf9160_pca10090
but after programming, the LED on THINGY:91 changed to RED color, and I couldnt connect it from nrfcloud
I couldn't find pca20035 on ncs_v1.0.0. Do I need to use another version of ncs ?
2. How can I debug the output from THINGY:91
The terminal still shows the output from nRF9160 DK, nothing from THINGY:91
Mvh
Hoang Nguyen
  • But you are outside correct? That's pretty poor for a device outside. Are you in an open location, a good 10-20 metres clear of any structure with line of sight to the open sky?
  • , do I need to use the external GPS antenna for THINGY:91 ?
  • , I am running the same example for thingy:91 and nrf9160dk, and I put THINGY:91 and nRF9160DK on the roof of my office, and nRF9160 DK got the fix location, but thingy:91 no.
  • Ok so you have or haven't gotten the Thingy:91 to acquire a lock? Little confused here Sweat smile
    I got the problem when I run asset_tracker on nRF9160 DK: ( It worked yesterday)
    SPM: NS image at 0x18200
    SPM: NS MSP at 0x2002b4f8
    SPM: NS reset vector at 0x20d09
    SPM: prepare to jump to Non-Secure image.
    ***** Booting Zephyr OS build v1.14.99-ncs2-rc4-495-ga8933a2ead01 *****
    [00:00:00.245,544] [1B][0m<dbg> nrf9160_gps.init: MAGPIO set: AT%XMAGPIO=1,0,0,1,1,1574,1577[1B][0m
    Asset tracker started
    [00:00:00.256,652] [1B][0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656100264319[1B][0m
    [00:00:00.265,930] [1B][0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/nrf-352656100264319/shadow[1B][0m
    [00:00:00.277,618] [1B][0m<dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: $aws/things/nrf-352656100264319/shadow/get/accepted[1B][0m
    [00:00:00.290,222] [1B][0m<dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656100264319/shadow/get/rejected[1B][0m
    [00:00:00.302,795] [1B][0m<dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656100264319/shadow/update/delta[1B][0m
    [00:00:00.315,734] [1B][0m<dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/nrf-352656100264319/shadow/update[1B][0m
    [00:00:00.327,606] [1B][0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/nrf-352656100264319/shadow/get[1B][0m
    Connecting to LTE network. This may take several minutes.
    [00:00:02.424,591] [1B][0m<dbg> lte_lc.at_handler: recv: +CEREG: 2,"765D","0110C303",7
    [1B][0m
    [00:00:03.684,783] [1B][0m<dbg> lte_lc.at_handler: recv: +CEREG: 5,"765D","0110C303",7
    [1B][0m
    Connected to LTE network
    [00:00:03.968,078] [1B][0m<dbg> nrf_cloud_transport.nct_connect: IPv4 Address 0x82492d34[1B][0m
    cloud_connect failed: -111
    LTE link disconnect
    Shutdown modem
