Thingy:91
Dear,
I received THINGY:91 from NordicSemi. I use 10pins cable to connect to nRF9160 DK to program for THINGY:91.
and, I am using ncs_v1.0.0
I am trying to run asset_tracker application,
and I am confusing about:
1. which board should I select? I tried to use    ncs_v1.0.0/zephyr/boards/arm/nrf9160_pca10090
but after programming, the LED on THINGY:91 changed to RED color, and I couldnt connect it from nrfcloud
I couldn't find pca20035 on ncs_v1.0.0. Do I need to use another version of ncs ?
2. How can I debug the output from THINGY:91
The terminal still shows the output from nRF9160 DK, nothing from THINGY:91
Mvh
Hoang Nguyen
  • Hi
    I tried to test with: ncs_v1.0.0_joakim\nrf\samples\nrf9160\gps for both nRF9160 DK and THINGY:91.
    (put 2 of them in the same place, outside)
    nRF9160 DK got fix
    but THINGY:91 NO ( it got fix only 1time/10times testing)
    and here are the logfiles:
    for nRF9160 DK:
    [1B][1;1H[1B][2JTracking: 2 Using: 2 Unhealthy: 0
    Seconds since last fix 11
    Scanning [|] [1B][1;1H[1B][2JTracking: 2 Using: 2 Unhealthy: 0
    Seconds since last fix 12
    Scanning [/] [1B][1;1H[1B][2JTracking: 2 Using: 2 Unhealthy: 0
    Seconds since last fix 13
    Scanning [-] [1B][1;1H[1B][2JTracking: 2 Using: 2 Unhealthy: 0
    Scanning [\] [1B][1;1H[1B][2JTracking: 2 Using: 2 Unhealthy: 0
    Seconds since last fix 14
    Seconds since last fix 15
    Seconds since last fix 16
    Seconds since last fix 17
    Seconds since last fix 18
    Seconds since last fix 19
    Seconds since last fix 20
    Seconds since last fix 21
    Seconds since last fix 22
    Seconds since last fix 23
    Seconds since last fix 24
    Seconds since last fix 25
    Seconds since last fix 26
    Seconds since last fix 27
    Seconds since last fix 28
    Seconds since last fix 29
    Seconds since last fix 30
    Seconds since last fix 31
    Seconds since last fix 32
    Scanning [|] [1B][1;1H[1B][2JTracking: 2 Using: 2 Unhealthy: 1
    Seconds since last fix 33
    Scanning [/] [1B][1;1H[1B][2JTracking: 2 Using: 2 Unhealthy: 1
    Scanning [-] [1B][1;1H[1B][2JTracking: 2 Using: 2 Unhealthy: 1
    Seconds since last fix 34
    Scanning [\] [1B][1;1H[1B][2JTracking: 2 Using: 2 Unhealthy: 1
    Seconds since last fix 35
    Seconds since last fix 36
    Seconds since last fix 37
    Seconds since last fix 38
    Seconds since last fix 39
    Seconds since last fix 40
    Seconds since last fix 41
    Seconds since last fix 42
    Seconds since last fix 43
    Seconds since last fix 44
    Seconds since last fix 45
    Seconds since last fix 46
    Seconds since last fix 47
    Seconds since last fix 48
    Seconds since last fix 49
    Seconds since last fix 50
    Seconds since last fix 51
    Seconds since last fix 52
    Scanning [\] [1B][1;1H[1B][2JTracking: 3 Using: 3 Unhealthy: 1
    Seconds since last fix 53
    Scanning [|] [1B][1;1H[1B][2JTracking: 3 Using: 3 Unhealthy: 1
    Scanning [/] [1B][1;1H[1B][2JTracking: 3 Using: 3 Unhealthy: 1
    Seconds since last fix 54
    Scanning [-] [1B][1;1H[1B][2JTracking: 3 Using: 3 Unhealthy: 1
    Seconds since last fix 55
    Seconds since last fix 56
    Seconds since last fix 57
    Seconds since last fix 58
    Seconds since last fix 59
    Seconds since last fix 60
    Seconds since last fix 61
    Seconds since last fix 62
    Seconds since last fix 63
    Seconds since last fix 64
    Seconds since last fix 65
    Seconds since last fix 66
    Seconds since last fix 67
    Seconds since last fix 68
    Seconds since last fix 69
    Seconds since last fix 70
    Seconds since last fix 71
    Seconds since last fix 72
    Seconds since last fix 73
    Seconds since last fix 74
    Seconds since last fix 75
    Seconds since last fix 76
    Seconds since last fix 77
    Seconds since last fix 78
    Seconds since last fix 79
    Seconds since last fix 80
    Seconds since last fix 81
    Seconds since last fix 82
    Seconds since last fix 83
    Seconds since last fix 84
    Seconds since last fix 85
    Seconds since last fix 86
    Seconds since last fix 87
    Seconds since last fix 88
    Seconds since last fix 89
    Seconds since last fix 90
    Seconds since last fix 91
    Seconds since last fix 92
    Seconds since last fix 93
    Seconds since last fix 94
    Seconds since last fix 95
    Seconds since last fix 96
    Seconds since last fix 97
    Seconds since last fix 98
    Seconds since last fix 99
    Seconds since last fix 100
    Seconds since last fix 101
    Seconds since last fix 102
    Seconds since last fix 103
    Seconds since last fix 104
    Seconds since last fix 105
    Seconds since last fix 106
    Seconds since last fix 107
    Seconds since last fix 108
    Seconds since last fix 109
    Seconds since last fix 110
    Seconds since last fix 111
    Seconds since last fix 112
    Seconds since last fix 113
    Seconds since last fix 114
    Seconds since last fix 115
    Seconds since last fix 116
    Seconds since last fix 117
    Seconds since last fix 118
    Seconds since last fix 119
    Seconds since last fix 120
    Seconds since last fix 121
    Seconds since last fix 122
    Seconds since last fix 123
    Seconds since last fix 124
    Seconds since last fix 125
    Seconds since last fix 126
    Seconds since last fix 127
    Seconds since last fix 128
    Seconds since last fix 129
    Seconds since last fix 130
    Seconds since last fix 131
    Seconds since last fix 132
    Seconds since last fix 133
    Seconds since last fix 134
    Seconds since last fix 135
    Seconds since last fix 136
    Seconds since last fix 137
    Seconds since last fix 138
    Seconds since last fix 139
    Seconds since last fix 140
    Seconds since last fix 141
    Seconds since last fix 142
    Seconds since last fix 143
    Seconds since last fix 144
    Seconds since last fix 145
    Seconds since last fix 146
    Seconds since last fix 147
    Seconds since last fix 148
    Seconds since last fix 149
    Seconds since last fix 150
    Seconds since last fix 151
    Seconds since last fix 152
    Seconds since last fix 153
    Seconds since last fix 154
    Seconds since last fix 155
    Seconds since last fix 156
    Seconds since last fix 157
    Seconds since last fix 158
    Seconds since last fix 159
    Seconds since last fix 160
    Seconds since last fix 161
    Seconds since last fix 162
    Seconds since last fix 163
    Seconds since last fix 164
    Seconds since last fix 165
    Scanning [-] [1B][1;1H[1B][2JTracking: 4 Using: 4 Unhealthy: 1
    Seconds since last fix 166
    Scanning [\] [1B][1;1H[1B][2JTracking: 4 Using: 4 Unhealthy: 1
    Scanning [|] [1B][1;1H[1B][2JTracking: 4 Using: 4 Unhealthy: 1
    Seconds since last fix 167
    Scanning [/] [1B][1;1H[1B][2JTracking: 4 Using: 4 Unhealthy: 1
    Seconds since last fix 168
    Seconds since last fix 169
    Seconds since last fix 170
    Seconds since last fix 171
    Seconds since last fix 172
    Seconds since last fix 173
    Seconds since last fix 174
    Seconds since last fix 175
    Seconds since last fix 176
    Seconds since last fix 177
    Seconds since last fix 178
    Seconds since last fix 179
    Seconds since last fix 180
    Seconds since last fix 181
    Seconds since last fix 182
    Seconds since last fix 183
    Seconds since last fix 184
    Seconds since last fix 185
    Seconds since last fix 186
    Seconds since last fix 187
    Seconds since last fix 188
    Seconds since last fix 189
    Seconds since last fix 190
    Seconds since last fix 191
    Seconds since last fix 192
    Seconds since last fix 193
    Seconds since last fix 194
    Scanning [-] [1B][1;1H[1B][2JTracking: 5 Using: 5 Unhealthy: 1
    Seconds since last fix 195
    Scanning [\] [1B][1;1H[1B][2JTracking: 5 Using: 5 Unhealthy: 1
    Scanning [|] [1B][1;1H[1B][2JTracking: 5 Using: 5 Unhealthy: 1
    Seconds since last fix 196
    Scanning [/] [1B][1;1H[1B][2JTracking: 5 Using: 5 Unhealthy: 1
    Seconds since last fix 197
    Seconds since last fix 198
    Seconds since last fix 199
    Seconds since last fix 200
    Seconds since last fix 201
    Seconds since last fix 202
    Seconds since last fix 203
    Seconds since last fix 204
    Seconds since last fix 205
    Seconds since last fix 206
    Seconds since last fix 207
    Seconds since last fix 208
    Seconds since last fix 209
    Seconds since last fix 210
    Seconds since last fix 211
    Seconds since last fix 212
    Seconds since last fix 213
    Seconds since last fix 214
    Seconds since last fix 215
    Seconds since last fix 216
    Seconds since last fix 217
    Seconds since last fix 218
    Seconds since last fix 219
    Seconds since last fix 220
    Seconds since last fix 221
    Seconds since last fix 222
    Seconds since last fix 223
    Seconds since last fix 224
    Seconds since last fix 225
    Seconds since last fix 226
    Seconds since last fix 227
    Seconds since last fix 228
    Scanning [|] [1B][1;1H[1B][2JTracking: 4 Using: 4 Unhealthy: 0
    Seconds since last fix 229
    Scanning [/] [1B][1;1H[1B][2JTracking: 4 Using: 4 Unhealthy: 0
    Scanning [-] [1B][1;1H[1B][2JTracking: 4 Using: 4 Unhealthy: 0
    Seconds since last fix 230
    Scanning [\] [1B][1;1H[1B][2JTracking: 4 Using: 4 Unhealthy: 0
    Seconds since last fix 231
    Seconds since last fix 232
    Seconds since last fix 233
    Seconds since last fix 234
    Seconds since last fix 235
    Seconds since last fix 236
    Seconds since last fix 237
    Seconds since last fix 238
    Seconds since last fix 239
    Seconds since last fix 240
    Seconds since last fix 241
    Seconds since last fix 0
    Longitude:  10.484941
    Latitude:   59.407865
    Altitude:   47.081505
    Speed:      0.616701
    Heading:    0.000000
    Date:       05-08-2019
    Time (UTC): 09:45:13
    for thingy:91
    thingy91.txt
    I hope I can have time to help me
    Thanks
    Regards
    Mhv
    Hoang Nguyen
  • Ok, i think the issue isn't the SiP but GPS reception strength. That is an incredibliy long time to get a fix with 4-5 satellites in view.
    The Thingy is a smaller PCB size so stands to reason that with less ground area, the receptivity of GPS antenna is also going to suffer some what. It will be less effective than the pca10090 which has a larger ground plane and more likely to fit correctly to the reference design of the Molex antenna.
    The GPS receiver clearly works on the Thingy:91 as it does see satellites but it can't make that all important fix. This is either an issue with the GPS sensistivity or the conditions on the ground that are hampering GPS fixes.
    Have you looked at the antenna circuit to see if there is a U.FL connector on it? If there is, try an external antenna and see if the results change.
  • Hi
    Ja, THINGY:91 has the U:FL connect, I will try to test with an external antenna
  • I got nothing now, even with and without an external antenna, maybe the weather is so bad now :(
    Scanning [|] [1B][1;1H[1B][2JTracking: 0 Using: 0 Unhealthy: 0
    Seconds since last fix 508
