Thingy:91
Dear,
I received THINGY:91 from NordicSemi. I use 10pins cable to connect to nRF9160 DK to program for THINGY:91.
and, I am using ncs_v1.0.0
I am trying to run asset_tracker application,
and I am confusing about:
1. which board should I select? I tried to use    ncs_v1.0.0/zephyr/boards/arm/nrf9160_pca10090
but after programming, the LED on THINGY:91 changed to RED color, and I couldnt connect it from nrfcloud
I couldn't find pca20035 on ncs_v1.0.0. Do I need to use another version of ncs ?
2. How can I debug the output from THINGY:91
The terminal still shows the output from nRF9160 DK, nothing from THINGY:91
Mvh
Hoang Nguyen
  • and, sometimes, I got results look like that:
    SPM: NS image at 0xc000
    SPM: NS MSP at 0x200247a0
    SPM: NS reset vector at 0x14431
    SPM: prepare to jump to Non-Secure image.
    ***** Booting Zephyr OS build v1.14.99-ncs2-495-ga8933a2ead01 *****
    Staring GPS application
    Socket created
    Getting GPS data...
    [1B][1;1H[1B][2JTracking: 3 Using: 0 Unhealthy: 1
    Seconds since last fix 0
    Scanning [|] [1B][1;1H[1B][2JTracking: 3 Using: 0 Unhealthy: 1
    Scanning [/] [1B][1;1H[1B][2JTracking: 0 Using: 0 Unhealthy: 0
    Seconds since last fix 1
    Scanning [-] [1B][1;1H[1B][2JTracking: 0 Using: 0 Unhealthy: 0
    Scanning [\] [1B][1;1H[1B][2JTracking: 0 Using: 0 Unhealthy: 0
    Seconds since last fix 2
    Scanning [|] [1B][1;1H[1B][2JTracking: 0 Using: 0 Unhealthy: 0
    Seconds since last fix 3
    or:
    Scanning [/] [1B][1;1H[1B][2JTracking: 4 Using: 0 Unhealthy: 0
    Seconds since last fix 476
    Scanning [-] [1B][1;1H[1B][2JTracking: 4 Using: 0 Unhealthy: 0
    Seconds since last fix 477
    Scanning [\] [1B][1;1H[1B][2JTracking: 4 Using: 0 Unhealthy: 0
    Scanning [|] [1B][1;1H[1B][2JTracking: 4 Using: 0 Unhealthy: 0
    Seconds since last fix 478
    Seconds since last fix 479
    Seconds since last fix 480
    Seconds since last fix 481
    Tracking: 4 but Using: 0 !!??
    I cant understand it
  • Ignore the first result, its a ghost response and isn't accurate, the results after the first scan are accurate to the state of the GPS modem.
    Not all satellites will be used, detecting satellites is not the same using them to get a fix.
  • If you view the NMEA sentences, it will show you all the information GPS uses.
    https://www.gpsinformation.org/dale/nmea.htm
    I believe the value in question is under sentence GSA which handles Satellite status. It can return a value of 1, 2 or 3 with regards to fix type. So you can detect the satellites but it can still return a value of 1 for no fix. GSA specifies how many satellites are used in the fix solution which will be reflected in the printk information.
