System OFF mode(0.3uA) in nrf52832
Hello everyone,
I trying my nrf52832 getting ultra low power current conception mode using System OFF mode(0.3uA). I using SDK 15.2 ble_app_beacon example I change 32KHZ internal RC configuration this link and sd_power_system_off();  this command for low power conception but my module(PCA10040) take 5mA current for advertising. I need get ultra low power conception for sleep and advertising both side please share any example code or refer link to achieve this concept.
DK:PCA10040
SDK:15.2
  • sorry for the late replay Simonr,
    I using fresh example code of ble_app_hrs without any modification just compile on my pca10040 module when i press the button 1 device return fatal error from sleep_mode_enter() as below
    Fullscreen
    1
    2
    3
    4
    5
    6
    7
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    ret_code_t err_code;
    NRF_LOG_INFO("Sleep Mode Fun");
    NRF_LOG_INFO("BSP error: %d",err_code);
    // Prepare wakeup buttons.
    NRF_LOG_INFO("sleep mode pre: %d",err_code);
    NRF_LOG_INFO("sys off error: %d",err_code);
    XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
    <00> info> app: Heart Rate Sensor example started.
    <00> info> app: Fast advertising.
    <00> info> app: Sleep Mode Fun
    <00> info> app: BSP error: 0
    <00> info> app: sleep mode pre: 0
    <00> info> app: sys off error: 8198
    <00> error> app: Fatal error
  • Hi
    Can you upload your sdk_config.h file? I'm not able to reproduce this error on my side using a DK. I think there must be a define in your config file that is set incorrectly.
    Simon
  • This is my sdk_config.h file I used fresh sdk_config file without any modification
    6177.sdk_config.h
  • Hi
    Since you're using a module without the external LF crystal, you'll have to modify the LF clock configs in the sdk_config.h file to use the internal RC oscillator as described here.
    Simon
  • Hi
    I change LF clock configs in the sdk_config.h but still i faced same issue fatal error come from sd_power_system_off()
    38843.sdk_config.h
1 2 3
