Hi i have tried with uart example and need to change baudrate after the some string is transmmited over UARTS TX. Is it possible to somehow that to check that all bytes from FIFO are transmmited?
i have found it and solved my problem
yes that event and condition when corresponding string occurs it after it is transmmited then baudrate i have succes to change.
for solving this in ble_app_uart example in uart_event_handle function add case APP_UART_TX_EMPTY: and you can do everything what you want later if you must to do something when this event happens.
P.S. when you start app this evens happens you must add some condition :) that you handle later
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
// data_array[index] = data_array[index] & 0x7f;
index++;
if ((data_array[index - 1] == '\n') ||
(data_array[index - 1] == '\r') ||
(index >= m_ble_nus_max_data_len))
if (index > 1)
bsp_board_led_invert(2);
do
} while (err_code == NRF_ERROR_RESOURCES);
index = 0;
case APP_UART_FIFO_ERROR:
if(data[0] == 'q' && data[1] == 'r'){
bsp_board_led_invert(3);
