Hello! I'm trying to build a program for nrf51822 via QT Creator. I'm using QBS for build. I have a makefile from SDK examples for nrf51822. Someone can help me, how to setup qbs-project to build (and debug) nrf51822 program? Thanks.
I use QT creator under Linux and Mac for nRF51822 software development. Below an example qbs file using the heartrate example. I you have other questions just ask.
import qbs import qbs.FileInfo…
import qbs import qbs.FileInfo Product { Depends { name:"cpp" } type: ["application", "hex", "bin", "size"] name: "example" property string sdk: "../nrf51-sdk/" property string vendor: "Nordic" property string softDevice: "s110" property string device: "nrf51822" property string deviceVariant: "xxac" // xxaa=256kB Flash,16kB RAM | xxab=128kB Flash,16kB RAM | xxac=256kB Flash,32kB RAM cpp.defines: [ "NRF51", "BLE_STACK_SUPPORT_REQD", "S110", "SOFTDEVICE_PRESENT", "BOARD_PCA10028" ] cpp.warningLevel: "default" //"all" // or "none", "default" cpp.treatWarningsAsErrors: true cpp.executableSuffix: ".out" cpp.positionIndependentCode: false Properties { condition: qbs.buildVariant === "debug" cpp.commonCompilerFlags: [ "-mcpu=cortex-m0", "-mthumb", "-mabi=aapcs", "-mfloat-abi=soft", "-std=gnu99", "-flto", "-fno-builtin", "-fdata-sections","-ffunction-sections","-fno-strict-aliasing", "-Wall", ] cpp.debugInformation: true cpp.optimization: "none" // "none" or "fast" } Properties { condition: qbs.buildVariant === "release" cpp.commonCompilerFlags: [ "-mcpu=cortex-m0", "-mthumb", "-mabi=aapcs", "-mfloat-abi=soft", "-std=gnu99", "-flto", "-fno-builtin", "-fdata-sections","-ffunction-sections","-fno-strict-aliasing", "-Wall", ] cpp.debugInformation: false cpp.optimization: "small" } cpp.linkerFlags:[ "-Xlinker", "-Map="+buildDirectory+"/"+name+".map", "-mthumb", "-mabi=aapcs", "-L"+path+"/"+sdk+"components/toolchain/gcc/", "-T"+path+"/"+sdk+"components/toolchain/gcc/gcc_nrf51_"+softDevice+"_"+deviceVariant+".ld", "-mcpu=cortex-m0", "-Wl,--gc-sections","--specs=nano.specs","-lc","-lnosys", ] cpp.includePaths: [ "../inc", sdk+"examples/bsp", sdk+"components/ble/common", sdk+"components/ble/ble_services/ble_bas", sdk+"components/ble/ble_services/ble_hrs", sdk+"components/ble/ble_services/ble_dis", sdk+"components/ble/device_manager", sdk+"components/drivers_nrf/hal", sdk+"components/drivers_nrf/uart", sdk+"components/drivers_nrf/pstorage", sdk+"components/drivers_nrf/pstorage/config", sdk+"components/libraries/fifo", sdk+"components/libraries/sensorsim", sdk+"components/libraries/scheduler", sdk+"components/libraries/timer", sdk+"components/libraries/button", sdk+"components/libraries/trace", sdk+"components/libraries/gpiote", sdk+"components/libraries/util", sdk+"components/softdevice/"+softDevice+"/headers/", sdk+"components/softdevice/common/softdevice_handler", sdk+"components/toolchain/gcc", sdk+"components/toolchain", ] files: [ "../src/*.c", sdk+"examples/bsp/bsp.c", sdk+"components/libraries/button/app_button.c", sdk+"components/libraries/sensorsim/ble_sensorsim.c", sdk+"components/libraries/util/app_error.c", sdk+"components/libraries/timer/app_timer.c", sdk+"components/libraries/gpiote/app_gpiote.c", sdk+"components/libraries/scheduler/app_scheduler.c", sdk+"components/libraries/util/nrf_assert.c", sdk+"components/libraries/trace/app_trace.c", sdk+"components/libraries/uart/retarget.c", sdk+"components/libraries/fifo/app_fifo.c", sdk+"components/drivers_nrf/hal/nrf_delay.c", sdk+"components/drivers_nrf/pstorage/pstorage.c", sdk+"components/drivers_nrf/uart/app_uart_fifo.c", sdk+"components/softdevice/common/softdevice_handler/softdevice_handler.c", sdk+"components/toolchain/system_nrf51.c", sdk+"components/ble/ble_services/ble_hrs/ble_hrs.c", sdk+"components/ble/ble_services/ble_dis/ble_dis.c", sdk+"components/ble/ble_services/ble_bas/ble_bas.c", sdk+"components/ble/common/ble_conn_params.c", sdk+"components/ble/common/ble_advdata.c", sdk+"components/ble/common/ble_srv_common.c", sdk+"components/ble/device_manager/device_manager_peripheral.c", sdk+"components/toolchain/gcc/gcc_startup_nrf51.s", ] Rule { id: hex inputs: "application" Artifact { fileTags: ["hex"] filePath: FileInfo.baseName(input.filePath) + ".hex" } prepare: { var args = ["-O", "ihex", input.filePath, output.filePath]; var cmd = new Command("arm-none-eabi-objcopy", args); cmd.description = "converting to hex: "+FileInfo.fileName(input.filePath); cmd.highlight = "linker"; return cmd; } } Rule { id: bin inputs: "application" Artifact { fileTags: ["bin"] filePath: FileInfo.baseName(input.filePath) + ".bin" } prepare: { var args = ["-O", "binary", input.filePath, output.filePath]; var cmd = new Command("arm-none-eabi-objcopy", args); cmd.description = "converting to bin: "+FileInfo.fileName(input.filePath); cmd.highlight = "linker"; return cmd; } } Rule { id: size inputs: ["application"] Artifact { fileTags: ["size"] filePath: "-" } prepare: { var args = [input.filePath]; var cmd = new Command("arm-none-eabi-size", args); cmd.description = "File size: " + FileInfo.fileName(input.filePath); cmd.highlight = "linker"; return cmd; } } }
Thank you! This is good example! I' already resolved my problem, but your answer helped me to upgrade my project! Thank you one more time!
Any example for Ant/S210?
This is great information, it really helped me out a lot. I created a template project based on this:
devzone.nordicsemi.com/.../
