old data gets overwritten in fds when i read the data after setting a new one.
I have written a flash code using fds in which i am trying to save the data 7pages(1024 each). I have defined array of record key and fie ID for it.The problem it saves for first time  but then due to some pointer problem or something, it gets old data and overwrites in it. Here is the flash file.
    Could you explain a little bit more how you test this ?
    You need to store 7kB ?
    We have a simple example here  that you can try. If you can modify the example to show the issue you have, it would be nice.
  • i am testing it on nrf52832. So when i do the update(set_flash_data), it invalidates the old data, but then when i read it's the old one always.Can you pls tell how is this happening in my code?
  • Please post your full source on how you test it. It looks fine in the posted code.
    Have you tried testing using our flash_fds example in the nRF5 SDK ?
  • I tried your example and it worked properly.As you have seen my code, I declared an array of record & file id to save different records at different pages.The data that i am saving is -
    1.Array of structs[100](pg 0-4).
    2.One separate struct(pg 5)
    So whenever i get and set the data, i provide the index also for record,file ID.If there is no record, it creates a new one.When i updates any file, it invalidates the old one.But when i reads it, i gets one step back and  gives the old data.If i keep reading, it goes one step back everytime.
  • I suspect that instead of updating the record, the code actually creating new record with same File id and key. Note that, fds allow to have multiple record having same file ID and key. Each time you use fds_record_find() with the previous token, it will try to find the next record that matches File ID and key.
    Please add some debug log especially inside get_flash_data()
    I would suggest instead of using
     if (err_code == FDS_SUCCESS)
    if (err_code == FDS_ERR_NOT_FOUND)
    You use :
    else {if (err_code == FDS_ERR_NOT_FOUND)
    And then check if there is any other err_code.
    And on each of the return code of any other API call, you need to check if it's success or not.
1 2
