Watch dog and while statement
Based on nRF5_SDK_15.3.0_59ac345 at NRF52810 development board,
1. Enable the watchdog with reload value = 2000, and feed it per 1000ms by app_timer
2. Initialize the FDS and wait its ready
static void _on_fds_event(fds_evt_t const* evt)
switch(evt->id){
case FDS_EVT_INIT:
if(evt->result == FDS_SUCCESS){
_fds_ready = true;
case FDS_EVT_WRITE:
case FDS_EVT_UPDATE:
_fds_ready = false;
fds_register(_on_fds_event);
if(fds_init() == NRF_SUCCESS){
while(!_fds_ready){};
Each time the power is turned on, a watchdog reset is triggered. The reason is while(!_fds_ready){};
It looks like the while statement affecting the watchdog app_timer.
How can I solve this problem? Thanks!
  • Hi  ,
    It sounds like the app_timer interrupt is not allowed to access the CPU until you are done with your FDS events. They are probably running on the same interrupt priority.
    I don't know whether you are using the softdevice, but you can take a look at the interrupt priority levels for the nRF52810 here.
    Try to increase the interrupt priority (lower number = higher priority) on the app_timer.
    Look for APP_TIMER_CONFIG_IRQ_PRIORITY in sdk_config.h. Try to set it to 3, and see if that helps.
    Edvin
  • // <o> APP_TIMER_CONFIG_IRQ_PRIORITY  - Interrupt priority
    // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef APP_TIMER_CONFIG_IRQ_PRIORITY
    #define APP_TIMER_CONFIG_IRQ_PRIORITY 0
    There has been no improvement with the value=0 or value=1 or value=5.
  • Only setting APP_TIMER_CONFIG_IRQ_PRIORITY to 2 can works, why?
  • I don't know if you actually opened the link from my previous reply.
    levels 0, 1 and 4 are reserved for the softdevice.
     Do you use the softdevice?
     so you tried 0, 1 and 5. Did you try 3?
    Check out the link, and pick a value that is higher than the softdevice's "none-time-critical processing" and "SoftDevice memory protection" So you can choose either 2 or 3. If 2 works, then it is fine.
  • Hi ,
    I gave this some more thought after consulting with my colleague who handles this ticket.
    Maybe you shouldn't set the app_timer's priority so high. It may result in some unexpected behavior because other threads that possibly needs access faster can't get it.
    I suggest that you bump the priority on app_timer back to the default value (6?) and then rather skip the while(!fds_ready){}.
    I agree that sometimes you need to wait for _fds_ready, but I suggest that you do this update in your main context instead of in the FDS interrupt.
