I need to measure with SAADC two channels in the same time (NRF_SAADC_INPUT_AIN6 and NRF_SAADC_INPUT_AIN4).
Is possible ?
Have you an code example?
Thanks
Marco
Is possible ?
Thanks
Marco
Then ? how to set it ?. I don't understand.
static nrf_saadc_value_t m_buffer_pool_scann[2][2]; This is NOT correct ?
I use 2 channels. Could you tell me how ?
Sorry. I meant the SAMPLES_IN_BUFFER define should be N * the numbers of channels you use.
I don't know what chip or SDK version you use, but this is written in SDK15.3.0, and tested with nRF52832:
* Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup nrf_adc_example main.c
* @ingroup nrf_adc_example
* @brief ADC Example Application main file.
* This file contains the source code for a sample application using ADC.
* @image html example_board_setup_a.jpg "Use board setup A for this example."
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "nrf_drv_saadc.h"
#include "nrf_drv_ppi.h"
#include "nrf_drv_timer.h"
#include "boards.h"
#include "app_error.h"
#include "nrf_delay.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SAMPLES_IN_BUFFER 2
volatile uint8_t state = 1;
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
static nrf_saadc_value_t m_buffer_pool[2][SAMPLES_IN_BUFFER];
static nrf_ppi_channel_t m_ppi_channel;
static uint32_t m_adc_evt_counter;
void timer_handler(nrf_timer_event_t event_type, void * p_context)
ret_code_t err_code;
/* setup m_timer for compare event every 400ms */
uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
NRF_TIMER_CC_CHANNEL0,
ticks,
NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
false);
uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
NRF_TIMER_CC_CHANNEL0);
uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
timer_compare_event_addr,
saadc_sample_task_addr);
err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
int i;
NRF_LOG_INFO("ADC event number: %d", (int)m_adc_evt_counter);
for (i = 0; i < SAMPLES_IN_BUFFER; i++)
NRF_LOG_INFO("%d", p_event->data.done.p_buffer[i]);
m_adc_evt_counter++;
void saadc_init(void)
nrf_saadc_channel_config_t channel_config0 =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN0);
nrf_saadc_channel_config_t channel_config1 =
NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
err_code = nrf_drv_saadc_init(NULL, saadc_callback);
err_code = nrf_drv_saadc_channel_init(0, &channel_config0);
err_code = nrf_drv_saadc_channel_init(1, &channel_config1);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
uint32_t err_code = NRF_LOG_INIT(NULL);
ret_code_t ret_code = nrf_pwr_mgmt_init();
APP_ERROR_CHECK(ret_code);
saadc_init();
saadc_sampling_event_init();
NRF_LOG_INFO("SAADC HAL simple example started.");
while (1)
nrf_pwr_mgmt_run();
NRF_LOG_FLUSH();
Thank, but your file is exatly same at my code.
I ask a conversion each 1 mS but sometime the vale are swapped.
Marco
Can you test this one?
/** @file
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf.h"
#include "boards.h"
uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 1);
ticks,
false);
if(m_adc_evt_counter%100 == 0)
int i;
NRF_LOG_RAW_INFO("%d, ", (int)m_adc_evt_counter);
NRF_LOG_RAW_INFO("%d,", p_event->data.done.p_buffer[i]);
NRF_LOG_RAW_INFO("\r\n");
saadc_init();
while (1)
nrf_pwr_mgmt_run();
NRF_LOG_FLUSH();
I can't see that the values are swapped. Are they if you run the project with this main.c file?
In your case, how do you determine that the values/channels are swapped?
No, is impossible for me now.
static void lpcomp_event_handler(nrf_lpcomp_event_t event)
if (event == NRF_LPCOMP_EVENT_DOWN)
nrf_gpio_pin_set(PIN_P0_20_TP6);
u_STATO10.STATO10_bit.mm_EOC = 0;
nrf_drv_saadc_sample();
while(!u_STATO10.STATO10_bit.mm_EOC);
buff_I[puntIP]=adc_value_inex;
buff_P[puntIP]=adc_value_pulse;
puntIP++;
if (puntIP>99)puntIP=0;
nrf_gpio_pin_clear(PIN_P0_20_TP6);
I working on my target and I don' start a conversion with a timer but when a pulse arrive on AIN5.
I trigger this event with a LPCOMP event DOWN on AIN5.
I have tested it with the PO_20 test point and this event is perfectly synchronized with the AIN5.
I have discovered that if the time between 2 conversion is more then 10 mS the error do not appear
I have send you my situation.
In the report the signal RED is connected to AIN5 in order to generate an event on LPCOMP
In BLU one of the 2 signal that I need to measure with the SAADC
In yellow the signal PO_20 (test point) this signal go up when the evend LPCOMP down arrive and go down after the conversion (see my code above).
In the buffer buff_I and buff_P I store my conversion and sometime I read a zero value instead the correct value. see file in attach.
Note that on the oscilloscope the signal BLU is always UP when the YELLOW signal arrive.
