Error!!! Got an error "no bootloader found" in nRF52832.
Greetings!!!
I am working on nRF52832 having SDK 15.3.0, Windows 7 and Segger Studio IDE.
Right now I am implement OTA in my custom application.
I upload bootloader code in nRF52832 chip successfully upload program then connect with nRF connect and using boot-loader update .zip .
After successfully upload .zip fill device not start advertise.
I got error in ble_dfu_buttonless_async_svci_init() this function as shown below,
<error> app: No bootloader was found
<error> app: ERROR 4 [NRF_ERROR_NO_MEM] at D:\nRF5_SDK_15.3.0_59ac345\nRF5_SDK_15.3.0_59ac345\examples\ble_peripheral\ble_app_full_application\main.c:1304 PC at: 0x0002BE77
<error> app: End of error report
RAM and Flash adrees is as shown below,
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x80000
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x10000
FLASH_START=0x26000
FLASH_SIZE=0x5a000
RAM_START=0x20002230
RAM_SIZE=0xddd0
So please give me solution as soon as possible.
Thanks & regards,
Urvisha Andani
  • You need to modify the FLASH settings to free up space for the bootloader. The default settings reserves the entire flash from 0x26000 (end of SD) to 0x80000 ( end of flash). You are basically erasing the bootloader when you're flashing the application
    You need to change FLASH_SIZE to 0x52000 to free up space for the bootloader, which starts at 0x78000. Hence, the FLASH_SIZE must be 0x78000-0x26000= 0x52000
    Best regards
    Bjørn
    Thank you for Replying I changed starting flash and size of flash as you told as like shown below,
    FLASH_PH_START=0x0
    RAM_PH_SIZE=0x10000
    FLASH_START=0x78000
    FLASH_SIZE=0x52000
    RAM_SIZE=0xddd0
    In this I got 24 error as shown below,
    .text is too large to fit in FLASH memory segment
    .sdh_soc_observers is too large to fit in FLASH memory segment
    .sdh_ble_observers is too large to fit in FLASH memory segment
    .sdh_req_observers is too large to fit in FLASH memory segment
    .sdh_state_observers is too large to fit in FLASH memory segment
    .sdh_stack_observers is too large to fit in FLASH memory segment
    .nrf_balloc is too large to fit in FLASH memory segment
    .log_const_data is too large to fit in FLASH memory segment
    .log_backends is too large to fit in FLASH memory segment
    .fs_data is too large to fit in FLASH memory segment
    .rodata is too large to fit in FLASH memory segment
    .data is too large to fit in FLASH memory segment
    In bootloader code RAM and Flash adrees is as shown below,
    FLASH_PH_START=0x0
    RAM_PH_SIZE=0x10000
    FLASH_START=0x78000
    FLASH_SIZE=0x6000
    RAM_START=0x200057b8
    RAM_SIZE=0xa848
    So please give me some suggestion as soon as possible.
  • Urvisha Andani said:
    FLASH_PH_START=0x0
    RAM_PH_SIZE=0x10000
    FLASH_START=0x26000
    FLASH_SIZE=0x52000
    RAM_SIZE=0xddd0
    Are these the settings for the application or the bootloader. You need to modify the application settings to the following
    FLASH_PH_START=0x0
    RAM_PH_SIZE=0x10000
    FLASH_START=0x26000
    FLASH_SIZE=0x52000
    RAM_SIZE=0xddd0
    The settings for the bootloader should be left as they are.
    Bjørn
  • Are these the settings for the application or the bootloader. You need to modify the application settings to the following
    Thanks for reply, I think you are misunderstanding my settings for bootloader and application.
    in boot-loader setting I have not changed any things.
    These are my application settings,
    FLASH_PH_START=0x0
    RAM_PH_SIZE=0x10000
    FLASH_START=0x78000
    FLASH_SIZE=0x6000
    RAM_SIZE=0xa848
    After this setting I got error the below error,
  • If you are using the following settings
    FLASH_START=0x78000
    FLASH_SIZE=0x6000
    for the application then that is incorrect. It should be
    FLASH_START=0x26000
    FLASH_SIZE=0x52000
