I find this function. tx
void ble_send(uint8_t * data, uint8_t length) { ble_nus_send_string(&m_nus, data,length);
ble_send(&data_array[0],10);
but I don't find Rx Function
Rx Function defined ble_nus.c
I don't know how do I use Rx Function.....
From what I can see, you are using the experimental_ble_app_uart example?
The data will be received in a BLE event. Data written to the RX characteristic will be handled in ble_nus_on_ble_evt -> BLE_GATTS_EVT_WRITE -> on_write(..) -> p_nus->data_handler.
p_nus->data_handler is set in services_init(..): nus_init.data_handler = nus_data_handler;
nus_data_handler(..) will transfer the received data over UART (to a terminal):
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
/**@snippet [Handling the data received over BLE] */
void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
for (int i = 0; i < length; i++)
simple_uart_put(p_data[i]);
simple_uart_put('\n');
That was very helpful, thank you.
what's the usage of * p_nus? thank you!
