I want to turn on /off LED by advertising TX of BLE
peripheral : nrf52810
central : nrf52840
Specifically, peripheral performs advertising TX,
The central processes LED blinkly when the filter of ADDR is matched by scan_evnt_handler.
Sending of advertising of peripheral is sent only when I want to turn on/off the LED.
In the code of Example 1, the operation worked as code and worked well.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
ret_code_t err_code;
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_FILTER_MATCH:
nrf_gpio_pin_set(LED1_PIN);
nrf_delay_ms(2000);
nrf_gpio_pin_clear(LED1_PIN);
}break;
In the code of Example 2, sending advertising only turned on first,and then sending advertising could not turn it off.
Where is the problem?
if(nrf_gpio_pin_out_read(LED1_PIN)){
else{
}break;
Expected behavior of the code in Example 2.
Advertising transmission →Turn on the LED and hold its state.
Advertising transmission →Turn off the LED and hold its state.
Please let me know solution method.
