I am developing zigbee sensor systems with security "install codes".
I encountered strange thing.
SDK version : v3.0.0
problem : physical address and install code can not saved into NVRAM
a) Calling zb_secur_ic_add function return OK.
b) when tracing program, zb_secur_ic_add function call zb_osif_nvram_do_write with flash address 0xf4000, len 0x2c.
c) But that area are filled with something by zboss_start function as below sequence.
zboss_start:
zdo_dev_start -> zb_zdo_dev_init ->nrf_fstorage_write (zb_nrf52840_nvram.c)
I attached two image file.
One is zboss_that start function fill the 0xf4000 area and
The other is that zb_secur_ic_add will fill 0xf4000 with "install codes".
I cannot find how to solve this problem.
Currently "install codes" feature is not working.
1) zboss_start:
2) zb_secur_ic_add calls zb_osif_nvram_do_write
