I have the following setup:
- IDE: SES
- SDK: nRF5_SDK_15.3.0_59ac345
- SD: s140_nrf52_6.1.1_softdevice.hex
Issue description:
I have modified "ble_app_uart_c" and "ble_app_uart" examples to support CODED_PHY (i.e. long range) communication coding, but with mixed results.
1. Testing with two PCA10056 (v0.9.2) development kits, central doesn't receive advertisement packets even,
2. Testing peripheral code (based on "ble_app_uart" example) with our custom board, central finds advertisement packets and tries to connect to peripheral, but connection is dropped with code 62.
Couple options for support requests:
1. Please point me to right directions to find an example for modified "ble_app_uart" with long range coding, or
2. Check the attached projects and src to give me hints and guidance what I am missing in the code? (Pls. see the attachments at the end of the message)
Any help would be highly appreciated!
-Tommi Parkkila
Attachements:
1. SRC: ble_uart_peripheral_main.c
* Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup ble_sdk_uart_over_ble_main main.c
* @ingroup ble_sdk_app_nus_eval
* @brief UART over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service.
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "BLE5_UART" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(500, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
//#define BLE_LONG_RANGE_ENABLE
// LED pins
#define PIN_GREEN_LED (NRF_GPIO_PIN_MAP(1,13))
#define PIN_RED_LED (NRF_GPIO_PIN_MAP(1,15))
#define PIN_BLUE_LED (NRF_GPIO_PIN_MAP(1,10))
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
// UART pins
#define UART_RX_PIN_NUMBER 8 //20 // 8
#define UART_TX_PIN_NUMBER 6// 17 // 6
#define UART_CTS_PIN_NUMBER (0xFFFFFFFFUL)
#define UART_RTS_PIN_NUMBER (0xFFFFFFFFUL)
static void led_on(uint32_t lednumber){
nrf_gpio_cfg_output(lednumber);
nrf_gpio_pin_clear(lednumber);
static void led_toggle(uint32_t lednumber){
nrf_gpio_pin_toggle(lednumber);
static void led_off(uint32_t lednumber){
nrf_gpio_pin_set(lednumber);
static void led_off_all(void){
nrf_gpio_cfg_output(PIN_RED_LED);
nrf_gpio_pin_set(PIN_RED_LED);
nrf_gpio_cfg_output(PIN_GREEN_LED);
nrf_gpio_pin_set(PIN_GREEN_LED);
nrf_gpio_cfg_output(PIN_BLUE_LED);
nrf_gpio_pin_set(PIN_BLUE_LED);
/**@brief Function for assert macro callback.
* @warning This handler is an example only and does not fit a final product. You need to analyse
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for initializing the timer module.
static void timers_init(void)
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* application about an error.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the data from the Nordic UART Service.
* @details This function will process the data received from the Nordic UART BLE Service and send
* it to the UART module.
* @param[in] p_evt Nordic UART Service event.
/**@snippet [Handling the data received over BLE] */
uint32_t err_code;
for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
do
err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
} while (err_code == NRF_ERROR_BUSY);
if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
while (app_uart_put('\n') == NRF_ERROR_BUSY);
uint32_t err_code;
ble_nus_init_t nus_init;
// Initialize NUS.
/**@brief Function for handling an event from the Connection Parameters Module.
* @details This function will be called for all events in the Connection Parameters Module
* which are passed to the application.
* @note All this function does is to disconnect. This could have been done by simply setting
* the disconnect_on_fail config parameter, but instead we use the event handler
* mechanism to demonstrate its use.
* @param[in] p_evt Event received from the Connection Parameters Module.
uint32_t err_code;
/**@brief Function for handling errors from the Connection Parameters module.
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = false;
cp_init.evt_handler = on_conn_params_evt;
cp_init.error_handler = conn_params_error_handler;
// Prepare wakeup buttons.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
sleep_mode_enter();
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
led_on(PIN_BLUE_LED);
NRF_LOG_INFO("Disconnected %d", p_ble_evt->evt.gap_evt.params.disconnected.reason);
led_off_all();
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
// Pairing not supported
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
// No implementation needed.
/**@brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
ret_code_t err_code;
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/**@brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
* @param[in] event Event generated by button press.
uint32_t err_code;
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
/**@brief Function for handling app_uart events.
* a string. The string will be be sent over BLE when the last character received was a
* 'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
static uint8_t index = 0;
uint32_t err_code;
switch (p_event->evt_type)
case APP_UART_DATA_READY:
index++;
if ((data_array[index - 1] == '\n') ||
(data_array[index - 1] == '\r') ||
(index >= m_ble_nus_max_data_len))
if (index > 1)
do
} while (err_code == NRF_ERROR_RESOURCES);
index = 0;
case APP_UART_FIFO_ERROR:
/**@brief Function for initializing the UART module.
/**@snippet [UART Initialization] */
static void uart_init(void)
uint32_t err_code;
.rx_pin_no = UART_RX_PIN_NUMBER,
.tx_pin_no = UART_TX_PIN_NUMBER,
.rts_pin_no = UART_RTS_PIN_NUMBER,
.cts_pin_no = UART_CTS_PIN_NUMBER,
.use_parity = false,
.baud_rate = NRF_UART_BAUDRATE_115200
#else
.baud_rate = NRF_UARTE_BAUDRATE_115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
APP_IRQ_PRIORITY_LOWEST,
err_code);
//TRY2
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
#ifdef BLE_LONG_RANGE
init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
init.advdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
init.config.ble_adv_primary_phy = BLE_GAP_PHY_CODED;
init.config.ble_adv_secondary_phy = BLE_GAP_PHY_CODED;
init.config.ble_adv_extended_enabled = true;
#else
init.config.ble_adv_primary_phy = BLE_GAP_PHY_1MBPS;
init.config.ble_adv_secondary_phy = BLE_GAP_PHY_1MBPS;
init.config.ble_adv_extended_enabled = false;
#endif //BLE_LONG_RANGE
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
bsp_event_t startup_event;
uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
static void log_init(void)
nrf_pwr_mgmt_run();
/**@brief Application main function.
bool erase_bonds;
// Initialize.
uart_init();
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// Start execution.
printf("\r\n~~~UART started.~~~~\r\n");
advertising_start();
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, 0, 8);
led_off(PIN_BLUE_LED);
led_on(PIN_GREEN_LED);
// Enter main loop.
for (;;)
idle_state_handle();
2. SRC: ble_uart_central_main.c:
* Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "app_error.h"
#include "ble_db_discovery.h"
#include "app_util.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_nus_c.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shoulnd't need to modify this value. */
#define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION 0x0000 /**< Timout when scanning. 0x0000 disables timeout. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in millisecond. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(500, UNIT_1_25_MS) /**< Determines maximum connection interval in millisecond. */
#define SLAVE_LATENCY 0 /**< Determines slave latency in counts of connection events. */
#define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 millisecond. */
#define ECHOBACK_BLE_UART_DATA 1 /**< Echo the UART data that is received over the Nordic UART Service back to the sender. */
BLE_NUS_C_DEF(m_ble_nus_c); /**< BLE NUS service client instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB discovery module instance. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param =
(uint16_t)MIN_CONNECTION_INTERVAL, // Minimum connection
(uint16_t)MAX_CONNECTION_INTERVAL, // Maximum connection
(uint16_t)SLAVE_LATENCY, // Slave latency
(uint16_t)SUPERVISION_TIMEOUT // Supervision time-out
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_EXTENDED_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
/**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
m_scan_buffer_data,
/** @brief Parameters used when scanning. */
static ble_gap_scan_params_t const m_scan_params =
.active = 1,
.extended = 1,
.interval = SCAN_INTERVAL,
.window = SCAN_WINDOW,
.timeout = SCAN_DURATION,
.scan_phys = BLE_GAP_PHY_CODED,
.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
#else
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
m_scan_buffer_data,
.active = 1,
//.extended = 1,
.scan_phys = BLE_GAP_PHY_1MBPS,
/**@brief NUS uuid. */
static ble_uuid_t const m_nus_uuid =
.uuid = BLE_UUID_NUS_SERVICE,
.type = NUS_SERVICE_UUID_TYPE
/**@brief Function for asserts in the SoftDevice.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function to start scanning. */
static void scan_start(void)
ret_code_t ret;
ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
APP_ERROR_CHECK(ret);
ret = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for handling database discovery events.
* @details This function is callback function to handle events from the database discovery module.
* Depending on the UUIDs that are discovered, this function should forward the events
* to their respective services.
* @param[in] p_event Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
/**@brief Function for handling characters received by the Nordic UART Service.
* @details This function takes a list of characters of length data_len and prints the characters out on UART.
* If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
ret_code_t ret_val;
NRF_LOG_INFO("Receiving data.");
NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
for (uint32_t i = 0; i < data_len; i++)
do
ret_val = app_uart_put(p_data[i]);
if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
APP_ERROR_CHECK(ret_val);
} while (ret_val == NRF_ERROR_BUSY);
if (p_data[data_len-1] == '\r')
if (ECHOBACK_BLE_UART_DATA)
// Send data back to peripheral.
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
static uint16_t index = 0;
uint32_t ret_val;
/**@snippet [Handling data from UART] */
index++;
if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
do
ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_BUSY) )
index = 0;
NRF_LOG_ERROR("Communication error occurred while handling UART.");
NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
/**@brief Callback handling NUS Client events.
* @details This function is called to notify the application of NUS client events.
* @param[in] p_ble_nus_c NUS Client Handle. This identifies the NUS client
* @param[in] p_ble_nus_evt Pointer to the NUS Client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
switch (p_ble_nus_evt->evt_type)
case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
NRF_LOG_INFO("Discovery complete.");
err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
NRF_LOG_INFO("Connected to device with Nordic UART Service.");
case BLE_NUS_C_EVT_NUS_TX_EVT:
ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
case BLE_NUS_C_EVT_DISCONNECTED:
NRF_LOG_INFO("Disconnected.");
scan_start();
* @brief Function for shutdown events.
* @param[in] event Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
switch (event)
case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
/**@brief Function for handling the advertising report BLE event.
* @param[in] p_adv_report Advertising report from the SoftDevice.
static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
NRF_LOG_INFO("ADV. report");
if (ble_advdata_uuid_find(p_adv_report->data.p_data, p_adv_report->data.len, &m_nus_uuid))
err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
&m_scan_params,
&m_connection_param,
APP_BLE_CONN_CFG_TAG);
if (err_code == NRF_SUCCESS)
// scan is automatically stopped by the connect
NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
p_adv_report->peer_addr.addr[0],
p_adv_report->peer_addr.addr[1],
p_adv_report->peer_addr.addr[2],
p_adv_report->peer_addr.addr[3],
p_adv_report->peer_addr.addr[4],
p_adv_report->peer_addr.addr[5]
err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
case BLE_GAP_EVT_ADV_REPORT:
on_adv_report(&p_gap_evt->params.adv_report);
break; // BLE_GAP_EVT_ADV_REPORT
NRF_LOG_INFO("Connected to target");
err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
err_code = sd_ble_gap_rssi_start(p_ble_evt->evt.gap_evt.conn_handle, 10, 0);
// start discovery of services. The NUS Client waits for a discovery result
err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
case BLE_GAP_EVT_RSSI_CHANGED:
NRF_LOG_INFO("RSSI : %d dBm", p_gap_evt->params.rssi_changed.rssi);
case BLE_GAP_EVT_TIMEOUT:
NRF_LOG_DEBUG("EVT timeout.");
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
NRF_LOG_INFO("Scan timed out.");
scan_start();
else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_INFO("Connection Request timed out.");
NRF_LOG_DEBUG("PAIRING update request.");
err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
NRF_LOG_DEBUG("CONN update request.");
// Accepting parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
} break;
if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
NRF_LOG_INFO("ATT MTU exchange completed.");
NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
switch (event)
nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,
/**@brief Function for initializing the UART. */
.rx_pin_no = RX_PIN_NUMBER,
.tx_pin_no = TX_PIN_NUMBER,
.rts_pin_no = RTS_PIN_NUMBER,
.cts_pin_no = CTS_PIN_NUMBER,
.baud_rate = UART_BAUDRATE_BAUDRATE_Baud115200
UART_RX_BUF_SIZE,
UART_TX_BUF_SIZE,
uart_event_handle,
err_code);
/**@brief Function for initializing the NUS Client. */
static void nus_c_init(void)
ble_nus_c_init_t init;
init.evt_handler = ble_nus_c_evt_handler;
err_code = ble_nus_c_init(&m_ble_nus_c, &init);
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/**@brief Function for initializing the timer. */
static void timer_init(void)
/**@brief Function for initializing the nrf log module. */
/** @brief Function for initializing the Database Discovery Module. */
static void db_discovery_init(void)
ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
* @details Handle any pending log operation(s), then sleep until the next event occurs.
nrf_pwr_mgmt_run();
// Initialize.
log_init();
timer_init();
uart_init();
buttons_leds_init();
db_discovery_init();
ble_stack_init();
gatt_init();
nus_c_init();
// Start execution.
printf("BLE UART central example started.\r\n");
NRF_LOG_INFO("BLE UART central example started.");
scan_start();
// Enter main loop.
for (;;)
