Using PDM Mic on nRF9160DK
I was wondering if there were any good examples of how to get a PDM device (in this case a microphone) working on the nRF9160DK. I've read parts of the datasheet and I've been able to find the nrfx_pdm driver in the SDK but am unaware what pins to use to get it to read data and how to use the easy-dma feature.
Any pointers in the right direction are appreciated. Thank you
    There is no PDM example that I am aware of. However, the nrfx PDM driver has decent API documentation, so you can use it to get a pointer on how to use it.
    Regarding pin configuration, any two of the GPIO pins can be used. EasyDMA is the only way to get data, so it is handled for you. You just have to provide a buffer (pointer and size) using the nrfx_pdm_buffer_set() function.
  • I guess my question should have initially also stated, how do I set which pins I want to use in regards to PDM? I've seen example config files for i2c/twi and some overlay files, but I don't really know how to set the pins for PDM
  • I tried using nrfx_pdm.h however it does not seem to be configured to the nrf9160 as the nrf9160.h does not have NRF_PDM define but DOES have NRF_PDM_NS and NRF_PDM_S defined.
    I did a search and replace to replace NRF_PDM w/ NRF_PDM_NS in the nrf_pdm.h and saved it as nrf_pdm_ns.h
    That seems to be all well and good until I tried to build and gives me some errors
    #include <nrf9160.h>
    #include <zephyr.h>
    #include <misc/printk.h>
    #include <string.h>
    #include <stdlib.h>
    #include <nrfx_pdm_ns.h>
    #include <gpio.h>
    #define PDM_BUF_ADDRESS 0x20000000 // buffer address in RAM
    #define PDM_BUF_SIZE 256 //size in 32 bit words --> 40 bytes
    int16_t pdm_buf[PDM_BUF_SIZE];
    void nrfx_pdm_event_handler(nrfx_pdm_evt_t const *const p_evt)
    	if (p_evt->buffer_requested) {
    		nrfx_pdm_buffer_set(pdm_buf, PDM_BUF_SIZE);						<-----HERE!!!
    	if (p_evt->buffer_released != 0) {
    		printk("Out: %.2x %2x\r\n", (uint16_t)pdm_buf[0],
    		       (uint16_t)pdm_buf[1]);
    static void pdm_init(void)
    	nrfx_pdm_config_t pdm_config = NRFX_PDM_DEFAULT_CONFIG(10, 11); /*configures CLK to pin 10 and Din to pin 11*/
    	nrfx_pdm_init(&pdm_config, nrfx_pdm_event_handler);						<------AND HERE!!
    void main(void)
    	printk("Starting PDM program!\n");
    	printk("PDM Buffer size: %d\n", (PDM_BUF_SIZE * 4));
    	printk("PDM Starting Address: %x\n", PDM_BUF_ADDRESS);
    	pdm_init();
    once I try to build SES gives me these errors
    despite that my nrfx_pdm_ns.h file includes the prototypes (I believe).
    Did I do something wrong or am I missing something?
    Thanks for your help
    The "undefined reference" error is probably because PDM is disabled in zephyr\ext\hal\nordic\nrfx_config_nrf9160.h. Can set NRFX_PDM_ENABLED to 1 and try again?
  • Hi Einar,
    So I did what you suggested
    but when still when I re-load and try to build the program it still gives me the same error.
    I'm more than a little lost here. Any other help is appreciated.
    Thank you
