We would like the ability to build our application using a version of the nRF Connect SDK that we have in a private repo. This is desirable for both long term maintenance, as well as capturing any changes we make to the SDK (such as the private key used in app signing).
We are able to build the app using the standard build process described in the SDK documentation. However, we are having issues building the same app when using a version of the SDK in our own git repo. The main problem lies with the cmake command to configure Ninja. We get a cmake error trying to resolve the mbedtls project (despite it's presence in the build directory).
Here is the build output:
Loading solution McubootApp.emProject Executing load commands cmake -GNinja -DBOARD=nrf9160_pca10090ns -DBOARD_DIR=C:/ncs/nrf-connect-sdk/zephyr/boards/arm/nrf9160_pca10090 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/gnuarmemb -BC:/software/Embedded/CMD/McubootApp/build_nrf9160_pca10090ns -HC:/software/Embedded/CMD/McubootApp -DDTC_OVERLAY_FILE=C:/software/Embedded/CMD/McubootApp/nrf9160_pca10090ns.overlay -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:/Users/Desktop/arm_segger_embedded_studio_v418_win_x64_nordic/html/configure_nordic_project_menuconfig.py -- Using application from 'C:/software/Embedded/CMD/McubootApp' Zephyr version: 1.14.99 -- git describe failed: fatal: Not a valid object name HEAD; BUILD_VERSION is left undefined -- Selected BOARD nrf9160_pca10090ns -- Found west: C:/Python37/Scripts/west.exe (found suitable version "0.5.8", minimum required is "0.5.6") -- Cache files will be written to: C:\Users\bvajda\AppData\Local/.cache/zephyr -- Loading C:/ncs/nrf-connect-sdk/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090ns.dts as base -- Overlaying C:/ncs/nrf-connect-sdk/zephyr/dts/common/common.dts -- Overlaying C:/software/Embedded/CMD/McubootApp/nrf9160_pca10090ns.overlay Parsing Kconfig tree in C:/ncs/nrf-connect-sdk/zephyr/Kconfig Loading C:/software/Embedded/CMD/McubootApp/build_nrf9160_pca10090ns/zephyr/.config as base Configuration written to 'C:/software/Embedded/CMD/McubootApp/build_nrf9160_pca10090ns/zephyr/.config' Including module: nrf in path: C:\ncs\nrf-connect-sdk\nrf -- Using application from 'C:/ncs/nrf-connect-sdk/nrf/samples/nrf9160/spm' Zephyr version: 1.14.99 Changed board to secure nrf9160_pca10090 (NOT NS) -- Loading C:/ncs/nrf-connect-sdk/zephyr/boards/arm/nrf9160_pca10090/nrf9160_pca10090.dts as base -- Overlaying C:/ncs/nrf-connect-sdk/zephyr/dts/common/common.dts -- Overlaying C:/ncs/nrf-connect-sdk/nrf/samples/nrf9160/spm/nrf9160_pca10090.overlay Parsing Kconfig tree in C:/ncs/nrf-connect-sdk/zephyr/Kconfig Loading C:/software/Embedded/CMD/McubootApp/build_nrf9160_pca10090ns/spm/zephyr/.config as base Configuration written to 'C:/software/Embedded/CMD/McubootApp/build_nrf9160_pca10090ns/spm/zephyr/.config' Including module: nrf in path: C:\ncs\nrf-connect-sdk\nrf Including module: mcuboot in path: C:\ncs\nrf-connect-sdk\mcuboot\zephyr Including module: nrfxlib in path: C:\ncs\nrf-connect-sdk\nrfxlib FATAL ERROR: The following projects are not cloned: mbedtls. Please clone them first with 'west clone'. CMake Error at C:/ncs/nrf-connect-sdk/nrfxlib/nrf_security/CMakeLists.txt:30 (message): Failed to find mbedtls, cannot build security libraries
As a general question, what is the preferred approach to using a private repo for the SDK? The approach I took was admittedly brute force; basically taking the my local copy of the SDK, stripping the .git information, and committing the whole SDK into our repo.
Thanks-
Brian
