[nRF52832 + SDK15.2] NRF_FAULT_ID_SDK_ERROR
Hi, I'm Developing Custom Board with nRF52832.
When I execute my custom code (by referring to ble_app_template example), an error occured.
First, my hardware spec below,
  • MCU : nRF52832QFAA
  • SDK : nRF5_SDK_15.2.0_9412b96
  • SoftDevice : s132_nrf52_6.1.0_softdevice
The error is fault error. so, system processing "app_error_fault_handler".
then I check parameter in "app_error_fault_handler",
  • id : 0x00004001 (NRF_FAULT_ID_SDK_ERROR)
  • pc : 0x00000000
  • info : 0x20007BB8
I found this error is "NRF_FAULT_ID_SDK_ERROR".
but I don't know why this error ouccred, and How to fix it.
Best Regards
  • the fault error occured at peer_manager_init() function.
    static void peer_manager_init(void)
        ret_code_t           err_code;
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
  • I found reason.
    #define SEC_PARAM_BOND 0
    to
    #define SEC_PARAM_BOND 1
    then worked.
