no signal
i'm not getting any signal with a fresh DK and the latest modem driver.
AT+CESQ
+CESQ: 99,99,255,255,255,255
OK
entering AT+COPS=?  will make it unresponsive forever. (nordic LTE Link monitor times out, and no AT commands are possible before hard reset).
does not matter which simcard i use. The one i'm testing right now from telekom works just fine in a simcom lte-m modem.
unfortunately the devzone has no way to attach files, so i uploaded the trace file here:
  • Hi a3p,
    It does look like you are using an older version than NCS v1.0.0?
    Please try to use this precompiled at_client: merged.hex
    You can flash it using the programmer app in nrf connect for desktop or by the command line: nrfjprog --program merged.hex -f nrf91 -r --sectorerase --verify
    Since you are mentioning "same antenna" are you using an external antenna on the nRF91 DK? Please keep this in mind
    Please send a new Log using LTE Link Monitor and just let the application run through the script by sending the AT command: AT+CFUN?
    Are you using the iBasis SIM card provided with the kit?
    Martin L.
  • no, i tried v1.0.0 as well as master
    same issue with the hex you provided.
    same with external or internal antenna.
    same issue with the included iBasis Sim as well as a known working Telekom sim
    AT+CFUN?
    +CFUN: 1
    OK
    AT+CGSN=1
    +CGSN: "352656100049496"
    OK
    AT+CGMI
    Nordic Semiconductor ASA
    OK
    AT+CGMM
    nRF9160-SICA
    OK
    AT+CGMR
    mfw_nrf9160_1.0.0
    OK
    AT+CEMODE?
    +CEMODE: 2
    OK
    AT%XCBAND=?
    %XCBAND: (1,2,3,4,5,8,12,13,14,17,18,19,20,25,26,28,66)
    OK
    AT+CMEE?
    +CMEE: 1
    OK
    AT+CNEC?
    +CNEC: 24
    OK
    AT+CGEREP?
    +CGEREP: 1,0
    OK
    AT+CIND=1,1,1
    OK
    AT+CEREG=2
    OK
    AT+CEREG?
    +CEREG: 2,2,"FFFE","FFFFFFFF",7
    OK
    AT%CESQ=1
    OK
    AT+CESQ
    OK
    AT%XSIM=1
    OK
    AT%XSIM?
    %XSIM: 1
    OK
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    AT+CIMI
    204080813514708
    OK
    ***** Booting Zephyr OS v1.14.99-ncs2 *****
    The AT host sample started
    AT
    OK
    AT+CFUN?
    +CFUN: 4
    OK
    AT+CFUN=1
    OK
    AT+CFUN?
    +CFUN: 1
    OK
    AT+CGSN=1
    OK
    AT+CGMI
    OK
    AT+CGMM
    nRF9160-SICA
    OK
    AT+CGMR
    mfw_nrf9160_1.0.0
    OK
    AT+CEMODE?
    +CEMODE: 2
    OK
    AT%XCBAND=?
    OK
    AT+CMEE?
    +CMEE: 0
    OK
    AT+CMEE=1
    OK
    AT+CNEC?
    +CNEC: 0
    OK
    AT+CNEC=24
    OK
    AT+CGEREP?
    +CGEREP: 0,0
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    OK
    AT+CGEREP=1
    OK
    AT+CIND=1,1,1
    OK
    AT+CEREG=2
    OK
    AT+CEREG?
    +CEREG: 2,4,"FFFE","FFFFFFFF",7
    OK
    AT%CESQ=1
    OK
    AT+CESQ
    OK
    AT%XSIM=1
    OK
    AT%XSIM?
    %XSIM: 1
    OK
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    AT+CIMI
    204080813514708
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
    AT+CESQ
    OK
  • Hi a3p,
    How long do you typically wait for a connection?
    The first time you do this, it can take up to 3-5 minutes. (and the response from CESQ will show 255 until you get a response from the eNB)
    e.g.
    AT+CFUN?
    +CFUN: 4
    OK
    AT+CFUN=1
    OK
    AT+CFUN?
    +CFUN: 1
    OK
    AT+CGSN=1
    +CGSN: "352656100037632"
    OK
    AT+CGMI
    OK
    AT+CGMM
    nRF9160-SICA
    OK
    AT+CGMR
    mfw_nrf9160_1.0.0
    OK
    AT+CEMODE?
    +CEMODE: 2
    OK
    AT%XCBAND=?
    OK
    AT+CMEE?
    +CMEE: 0
    OK
    AT+CMEE=1
    OK
    AT+CNEC?
    +CNEC: 0
    OK
    AT+CNEC=24
    OK
    AT+CGEREP?
    +CGEREP: 0,0
    OK
    AT+CGDCONT?
    OK
    AT+CGACT?
    OK
    AT+CGEREP=1
    OK
    AT+CIND=1,1,1
    OK
    AT+CEREG=2
    OK
    AT+CEREG?
    OK
    AT%CESQ=1
    OK
    AT+CESQ
    OK
    AT%XSIM=1
    OK
    AT%XSIM?
    %XSIM: 1
    OK
    AT+CPIN?
    +CPIN: READY
    OK
    AT+CPINR="SIM PIN"
    +CPINR: "SIM PIN",3
    OK
    AT+CIMI
    204080813512754
    OK
    at+cesq
    OK
    at+cesq
    OK
    at+cesq
    OK
    at+cesq
    OK
    at+cesq
    OK
    at+cesq
    OK
    at+cesq
    OK
    at+cesq
    OK
    at+cesq
    OK
    at+cesq
    OK
    at+cesq
    OK
    at+cesq
    OK
    %CESQ: 51,2
    +CEREG: 2,"76C1","0102DA04",7
    %CESQ: 56,2
    +CGEV: ME PDN ACT 0,0
    AT+CGDCONT?
    +CNEC_ESM: 50,0
    +CEREG: 5,"76C1","0102DA04",7
    +CIND: "service",1
    +CIND: "roam",1
    +CGDCONT: 0,"IP","ibasis.iot","10.160.28.172",0,0
    OK
    AT+CGACT?
    +CGACT: 0,1
    OK
    at+cesq
    +CESQ: 99,99,255,255,255,56
    OK
    after a successful connection you can store the network data to modem flash by turning OFF the modem completely: AT+CFUN=0
    Then if you reboot the kit and turn on the modem you should see that you get a connection much quicker.
  • thanks, thats good to know. i did now test it by waiting 20 minutes with each sim card.
    same result
  • Hi A3p,
    In which country are you located?
    Did you register the ibasis SIM on nrf cloud?
    Could you try to set the command:
    AT%XMODEMTRACE=1,2
    before you turn on the modem.
    Please provide logs and any additional information you could think is important for me to know.
