Is the HFCLK still running? What function are you using to set it in sleep mode, and could you share your project?
regards
Jared
i am just trying to figure out what is happening.
So what i have found out is that i got around 10uA current consumption with next setup:
main.cpp
EventQueue mainEventQueue(64 * EVENTS_EVENT_SIZE);
Thread mainEventQueueThread(osPriorityNormal, OS_STACK_SIZE, NULL, "MAIN.event.queue");
DebounceIn button1(BUTTON1);
DigitalOut led(LED1);
void onButton1Rise() {
led = !led;
int main() {
NRF_POWER->DCDCEN = 0x00000001;
NRF_UICR->NFCPINS = 0x00000000;
mbed_file_handle(STDIN_FILENO)->enable_input(false);
mainEventQueueThread.start(callback(&mainEventQueue, &EventQueue::dispatch_forever));
button1.rise(mainEventQueue.event(onButton1Rise));
mbed_app.json
"target_overrides": {
"platform.stdio-baud-rate": 115200,
"platform.stdio-convert-newlines": true,
"target.console-uart": false,
"target.device_has" : [
"STDIO_MESSAGES"
"target.features_add": ["BLE"],
"platform.cpu-stats-enabled": 1,
"platform.thread-stats-enabled": 1,
"platform.error-filename-capture-enabled": true,
"target.macros_add": [
"DEVICE_SLEEP",
"MBED_TICKLESS",
"DEVICE_LPTICKER",
"MBED_CONF_TARGET_TICKLESS_FROM_US_TICKER=0"
"platform.callback-nontrivial": true
my board:
but after i created BufferedSerial object and delete it i got 600uA.
So i was looking at the registers and found out the next thing:
LOW CURRENT
Registers in UART0: TASKS_STARTRX: (not readable) Start UART receiver TASKS_STOPRX: (not readable) Stop UART receiver TASKS_STARTTX: (not readable) Start UART transmitter TASKS_STOPTX: (not readable) Stop UART transmitter TASKS_SUSPEND: (not readable) Suspend UART EVENTS_CTS: 0 CTS is activated (set low). Clear To Send. EVENTS_NCTS: 0 CTS is deactivated (set high). Not Clear To Send. EVENTS_RXDRDY: 0 Data received in RXD EVENTS_TXDRDY: 0 Data sent from TXD EVENTS_ERROR: 0 Error detected EVENTS_RXTO: 0 Receiver timeout SHORTS: 0 Shortcuts between local events and tasks INTENSET: 0 Enable interrupt INTENCLR: 0 Disable interrupt ERRORSRC: 0 Error source ENABLE: 0 Enable UART PSEL: -1 Unspecified RXD: 0 RXD register TXD: (not readable) TXD register BAUDRATE: 67108864 Baud rate. Accuracy depends on the HFCLK source selected. CONFIG: 0 Configuration of parity and hardware flow control Registers in UARTE0: TASKS_STARTRX: (not readable) Start UART receiver TASKS_STOPRX: (not readable) Stop UART receiver TASKS_STARTTX: (not readable) Start UART transmitter TASKS_STOPTX: (not readable) Stop UART transmitter TASKS_FLUSHRX: (not readable) Flush RX FIFO into RX buffer EVENTS_CTS: 0 CTS is activated (set low). Clear To Send. EVENTS_NCTS: 0 CTS is deactivated (set high). Not Clear To Send. EVENTS_RXDRDY: 0 Data received in RXD (but potentially not yet transferred to Data RAM) EVENTS_ENDRX: 0 Receive buffer is filled up EVENTS_TXDRDY: 0 Data sent from TXD EVENTS_ENDTX: 0 Last TX byte transmitted EVENTS_ERROR: 0 Error detected EVENTS_RXTO: 0 Receiver timeout EVENTS_RXSTARTED: 0 UART receiver has started EVENTS_TXSTARTED: 0 UART transmitter has started EVENTS_TXSTOPPED: 0 Transmitter stopped SHORTS: 0 Shortcuts between local events and tasks INTEN: 0 Enable or disable interrupt INTENSET: 0 Enable interrupt INTENCLR: 0 Disable interrupt ERRORSRC: 0 Error source Note : this register is read / write one to clear. ENABLE: 0 Enable UART PSEL: -1 Unspecified BAUDRATE: 67108864 Baud rate. Accuracy depends on the HFCLK source selected. RXD: 0 RXD EasyDMA channel TXD: 0 TXD EasyDMA channel CONFIG: 0 Configuration of parity and hardware flow control
HI CURRENT
Registers in UART0:
EVENTS_CTS: 1 CTS is activated (set low). Clear To Send.
EVENTS_TXDRDY: 1 Data sent from TXD
SHORTS: 32 Shortcuts between local events and tasks
INTENSET: 524304 Enable interrupt
INTENCLR: 524304 Disable interrupt
ENABLE: 8 Enable UART
RXD: 0 RXD register
BAUDRATE: 2576384 Baud rate. Accuracy depends on the HFCLK source selected.
EVENTS_TXSTARTED: 1 UART transmitter has started
INTEN: 524304 Enable or disable interrupt
RXD: 536877297 RXD EasyDMA channel
TXD: 536877304 TXD EasyDMA channel
So the UART is not deinited for some reason.
After i did:
stdio.enable_input(false); stdio.enable_output(false);
the current dropped again init value.
Could you create a new ticket for your issue?
regards
Jared
