Jump straight out of sleep (sd_app_evt_wait) when fully disable uarte0 and uarte1
I've seen a few post that have similar issues but none that solve my problem.
I have two uarts (uarte0 and uarte1).
I disable them before going to sleep.
I wake with a timer from sd_app_evt_wait() after 30 seconds.
If I fully disable the uarts using code from DevZone then the code bounces straight out of sd_app_evt_wait() and doesn't sleep.
If I don't fully disable them then the power consumption is too high (900uA rather than 20uA) but it does sleep properly.
By "fully" disable what i mean is using the fix I found in DevZone (shown below):
UARTE0
        *(volatile uint32_t *)0x40002FFC = 0;
        *(volatile uint32_t *)0x40002FFC;
        *(volatile uint32_t *)0x40002FFC = 1;
UARTE1
        *(volatile uint32_t *)0x40028FFC = 0;
        *(volatile uint32_t *)0x40028FFC;
        *(volatile uint32_t *)0x40028FFC = 1;
I tried to see if there was a pending IRQ which was waking the system immediately using NVIC_GetPendingIRQ and the following appear set:
Reset_IRQn, HardFault_IRQn, UsageFault_IRQn, SysTick_IRQn
But attempting to clear them with sd_nvic_ClearPendingIRQ made no difference.
If I call sd_app_evt_wait() twice in succession then everything works fine.
Full code below:
	DebugPrintf("Entering sleep\n\n");
	EnterSleep();
	// HACK CODE SHOULDN'T BE REQUIRED
	sd_nvic_ClearPendingIRQ(UARTE1_IRQn);
	sd_nvic_ClearPendingIRQ(UARTE0_UART0_IRQn);
	// HACK CODE TO GET PENDING IRQs
	uint32_t irq_numA[63];
	uint32_t irq_numB[63];
	for(int x = -15; x < 48; x++)
	  irq_numA[x+15] = NVIC_GetPendingIRQ((IRQn_Type)x);
	// HACK CODE TO CLEAR PENDING IRQS - MAKES NO DIFFERENCE
	sd_nvic_ClearPendingIRQ(Reset_IRQn);
	sd_nvic_ClearPendingIRQ(NonMaskableInt_IRQn);
	... etc...
	... etc...
	... etc...
	  irq_numB[x+15] = NVIC_GetPendingIRQ((IRQn_Type)x);
	// SLEEP - BOUNCES STRAIGHT OUT IF UARTEn FULLY DISABLED
	sd_app_evt_wait();
	// SLEEP - WORKS EVERY TIME
	sd_app_evt_wait();
	DebugPrintf("Exiting sleep\n");
	ExitSleep();
void EnterSleep(void)
  DbgUartDeInit();
  RfUartDeInit();
void ExitSleep(void)
  DbgUartInit();
  RfUartInit();
void DbgUartInit(void)
	// CODE FROM DEVZONE TO FULLY DISABLE/ENABLE UARTE0
    NRF_UARTE0->TASKS_STARTTX = 1;
    NRF_UARTE0->TASKS_STARTRX = 1;
    NRF_UARTE0->ENABLE = 1;
    ret_code_t errorCode = nrf_serial_init(&theSerial0.uarte, &theSerial0.drvConfig, &theSerial0.config);
    if(NRF_ERROR_MODULE_ALREADY_INITIALIZED != errorCode)
        APP_ERROR_CHECK(errorCode);
void DbgUartDeInit(void)
    ret_code_t errorCode = nrf_serial_uninit(&theSerial0.uarte);
    if(NRF_ERROR_MODULE_NOT_INITIALIZED != errorCode)
        NRF_UARTE0->TASKS_STOPTX = 1;
        NRF_UARTE0->TASKS_STOPRX = 1;
        NRF_UARTE0->ENABLE = 0;
		// COMMENTING THIS OUT MAKES sd_app_evt_wait() WORK BUT THE CURRENT CONSUMPTION GOES UP
void RfUartInit(void)
	// CODE FROM DEVZONE TO FULLY DISABLE/ENABLE UARTE1
    NRF_UARTE1->TASKS_STARTTX = 1;
    NRF_UARTE1->TASKS_STARTRX = 1;
    NRF_UARTE1->ENABLE = 1;
    ret_code_t errorCode = nrf_serial_init(&theSerial1.uarte, &theSerial1.drvConfig, &theSerial1.config);
void RfUartDeInit(void)
    ret_code_t errorCode = nrf_serial_uninit(&theSerial1.uarte);
        NRF_UARTE1->TASKS_STOPTX = 1;
        NRF_UARTE1->TASKS_STOPRX = 1;
        NRF_UARTE1->ENABLE = 0;
