nRF52840 dongle "drag & drop" programming
Hello again Nordic Pro's,
This is a quick question that I have not been able to find the answer for before buying nRF52840 dongles to replace our nRF51 dongles.  We need several for our project and the pricing for the 52 is much better on the open market.
It is actually a multi-part question:
Does the nRF52840 include the same "drag and drop" programming feature as the 51, and if so, is it directly supported for example apps under the delivered SDK v15.2, specifically, the ble_app_uart_c project using the keil IDE?
Thank you all in advance,
Robin @ TL
  • Nope.  However you can use nRFConnect desktop to flash it.
  • There is support for usb dfu with may help you.
    A interface project can be found here.
    But no out of the box solution to your question like Mojo said.
  • Hello Edvin,
    Seems we may have wasted some money on several of these.  I just read another piece that claims that the USB pins are not used as UART pins.  We were intending to program the as UART central devices.
    Do you know of this is possible by redefining those pins?
    Also, given I do get to a point I can program them, can I program with a  merged hex that includes app and softdevice?  There seems to be some indication that this may not be possible either.
  • No, USB is not part but you can have the CDC firmware that emulate a com port when plugged into the PC.  The is an example code in the SDK for that.  Look for USB CDC example
  • As  says, it is not possible to change the USB pins to UART.
    On the older dongle, which has an On Board Segger (OB Segger) programming chip, the UART is actually translated to USB in this chip. That is the reason why you can read it on your computer. Computer's normally doesn't speak UART.
    In addition, the USB pins are hardcoded/wired. It is not possible to reuse these as other GPIOs.
     Yes. You can program the dongle with .hex files. Also with a merged softdevice + application .hex file, but you can't do it via drag'n'drop. You need to use the nRF Connect for Desktop application, and use the Programmer feature within this.
    If you need to use the dongle, and you imagined using the ble_app_uart, then the example found in:
    SDK15.3.0\examples\peripheral\usbd_ble_uart
    is the closest you get. It uses the BLE service: Nordic UART Service (NUS), just like the ble_app_uart example, but uses the USB instead of the UART to print the data. There is a description of this example here. This is a peripheral. We don't have a central, but if you can change the ble_app_uart_c example from using uart to using the USB, just like it is done in the usbd_ble_uart example, then it is possible.
    Please note that since there is no debugger, it is a bit tricky to develop applications on the dongle. We recommend using an nRF52840 DK to do the development, and then run the application on the dongle when it is done.
    BR,
    Edvin
  • Hello Edvin,
    We are returning these dongles and acquiring DK's for our project.  Thank you for the attempted support.
    I do have a coule last questions though.  Why would Nordic not follow up with the same capabilities as the older dongle on this one?  This was so misleading, and such a burn of time.  They should have at least "advertised" the differences.  I frankly don't see why anyone would want to "upgrade" to a dongle that is harder to program and less usable with Nordic's own example code.  What is the niche for this product?  I can't see  one from where I now sit.
    Sorry to grumble, but... come on gentlemen, keep things simple as possible for your customers!
    Thanks again
    Robin @ TL
    And, yes, you may close this ticket
  • I am sorry you feel that way.
    The dongle is intended as a cheap HW tool for nRF Connect for Desktop, so one wouldn't need two DKs if you want to test either a central or peripheral application. Unfortunately, the lack of programming chip makes it less useful for application development on the nRF52840 in itself. Not impossible, but more complicated.
    Edvin
    Edvin
