I want to interface a 16MB external flash (SPI) with nrf52832 on the development board.Suggest me how should I start with and if there is an example for external flash then let me know.
I am able to see only a high pulse on MISO line on logic analyser. I did try RDID command I am getting correct values but data which I get is always 0XFF.
Hi Torbjorn,
I am able to read the data now.It was due to some hardware issues that I was not able to read on MISO line.But now I am facing issue in erasing the chip.what else do I need to send to erase chip/ sector/block with it's instruction command?
Hi
This should be described in the datasheet of your flash device.
If you can't find it there please share the datasheet with me, and I will have a look.
Best regards
Torbjørn
Ok sharing with you the datasheet and the code which I am using. I added delay after CS_LOW so I am able to get the chip erase done. but still the issue is that after sending chip erase function I am not abl to write it. Also sector earse is not working ,I think I am struggling with the timing issues. I will be grateful if you can help me with these issues and make my flash running propelry.MX25R1635F, Wide Range, 16Mb, v1.6.pdf
and the code as below
// * @file ext_flash.c
// * This source file provides external flash memory related functionalities.
// * @author Glide Embedded Technology <www.glidemtech.com>
// * @date 7, August, 2019
///* Includes ------------------------------------------------------------------*/
#include <stdio.h>
#include <string.h>
#include <stdint.h>
#include "external_flash.h"
#include <hal/nrf_gpio.h>
#include <hal/nrf_spi.h>
#include "nrf_drv_spi.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_delay.h"
uint8_t print = 1;
#define SPI_INSTANCE 0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);
#define WAIT_FOR_PERIPH() do { \
while (!m_finished) {} \
m_finished = false; \
} while (0)
static volatile bool m_finished = false;
static uint8_t m_buffer_tx[256];
static uint8_t m_buffer_rx[256];
//static uint8_t m_data_send[256];
static uint8_t m_data_receive[256];
#define TEST_STRING "Z" //"Nordic"
static uint8_t m_tx_buf[] = TEST_STRING; /**< TX buffer. */
static uint8_t m_rx_buf[sizeof(TEST_STRING) + 1]; /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);
static uint8_t m_data_send[256] = {[0 ... 255] = 0xbb};
uint8_t StatusReg;
uint8_t ConfigReg;
uint8_t SecurityReg;
* @brief SPI user event handler.
* @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
void * p_context)
m_finished = true;
uint16_t i ;
//printf("\n\rTransfer completed.");
if (m_buffer_rx[0] != 0)
// printf(" Received:");
for(i=0;i<8;i++)
// printf("m_buffer_rx[%d] = %x ",i,m_buffer_rx[i]);
NRF_LOG_HEXDUMP_INFO(m_buffer_rx, strlen((const char *)m_buffer_rx));
// nrf_gpio_pin_set(SPI_SS_PIN);
void cs_low(void)
void cs_high(void)
nrf_gpio_pin_clear(SPI_SS_PIN);
* Reset setting Command
* Function: CMD_RSTEN
* Arguments: None.
* Description: Enable RST command
* Return Message: FlashOperationSuccess
ReturnMsg cmd_rsten( void )
// Chip select go low to start a flash command
cs_low();
// Write RSTEN command
uint8_t instruction = FLASH_CMD_RSTEN;
m_buffer_tx[0] = instruction;
nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,1,m_buffer_rx,1);
// Chip select go high to end a flash command
cs_high();
return FlashOperationSuccess;
* Function: CMD_RST
* Arguments: fsptr, pointer of flash status structure
* Description: The RST instruction is used as a system (software) reset that
* puts the device in normal operating Ready mode.
ReturnMsg cmd_rst( void )
cs_low();
// Write RST command = 0x99
uint8_t instruction = FLASH_CMD_RST;
cs_high();
* Function: CMD_WRSR
* Arguments: UpdateValue, 8/16 bit status register value to updata
* Description: The WRSR instruction is for changing the values of
* Status Register Bits (and configuration register)
* Return Message: FlashIsBusy, FlashTimeOut, FlashOperationSuccess
//ReturnMsg cmd_wrsr( uint8_t UpdateValue )
// // Check flash is busy or not
// if( IsFlashBusy() ) return FlashIsBusy;
// // Setting Write Enable Latch bit
// uint8_t err_code;
// err_code = cmd_wren();
// // Chip select go low to start a flash command
//// cs_low();
// // Send command and update value
// uint8_t instruction[9] = {0};
// instruction[0] = FLASH_CMD_WRSR;
// nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction,1,m_buffer_rx,3);
// nrf_delay_ms(2);
// printf("UPDATE VALUE = %d",UpdateValue);
// instruction[1]=UpdateValue;
//// memcpy(instruction[1],UpdateValue,8);
// nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction[1],2,m_buffer_rx,4);
////#ifdef SUPPORT_WRSR_CR
//// SendByte( UpdateValue >> 8, SIO ); // write configuration register
////#endif
// // Chip select go high to end a flash command
// cs_high();
// if( WaitFlashReady( WriteStatusRegCycleTime ) )
// return FlashOperationSuccess;
// else
// return FlashTimeOut;
uint8_t err_code;
uint8_t read_value;
nrf_gpio_pin_clear(SPI_WP_PIN);
// cs_low();
err_code = cmd_rdsr(read_value);
printf("rdsr valu = %d \n",read_value);
if((read_value & 2)== 1)
nrf_delay_ms(2);
if((read_value ^ 1)==1)
printf("wep is zero \n");
// nrf_delay_ms(2);
//#endif
cs_high();
* Function: CMD_RDSCUR
* Arguments: SecurityReg, 8 bit buffer to store security register value
* Description: The RDSCUR instruction is for reading the value of
* Security Register bits.
ReturnMsg cmd_rdscur( uint8_t *SecurityReg )
uint8_t gDataBuffer;
cs_low();
//Send command
uint8_t instruction = FLASH_CMD_RDSCUR;
nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction,1,gDataBuffer,3);
cs_high();
*SecurityReg = gDataBuffer;
* Function: CMD_WRSCUR
* Arguments: None.
* Description: The WRSCUR instruction is for changing the values of
* Security Register Bits.
* Return Message: FlashIsBusy, FlashOperationSuccess, FlashWriteRegFailed,
* FlashTimeOut
ReturnMsg cmd_wrscur( void )
cmd_wren();
cs_low();
// Write WRSCUR command
uint8_t instruction = FLASH_CMD_WRSCUR;
cs_high();
if( WaitFlashReady( WriteSecuRegCycleTime ) ){
cmd_rdscur( &gDataBuffer );
// Check security register LDSO bit
if( (gDataBuffer & FLASH_LDSO_MASK) == FLASH_LDSO_MASK )
return FlashWriteRegFailed;
* Function: CMD_RDID
* Arguments: Identification, 32 bit buffer to store id
* Description: The RDID instruction is to read the manufacturer ID
* of 1-byte and followed by Device ID of 2-byte.
ReturnMsg cmd_rdid( uint32_t *Identification )
uint32_t temp;
uint8_t gDataBuffer[3];
cs_low();
// Send command
// SendByte( FLASH_CMD_RDID, SIO );
uint8_t instruction = FLASH_CMD_RDID;
// Chip select go high to end a command
cs_high();
// Store identification
temp = gDataBuffer[0];
temp = (temp << 8) | gDataBuffer[1];
*Identification = (temp << 8) | gDataBuffer[2];
printf("rdid = %x %x",gDataBuffer [0],gDataBuffer [1]);
* Function: CMD_RES
* Arguments: ElectricIdentification, 8 bit buffer to store electric id
* Description: The RES instruction is to read the Device
* electric identification of 1-byte.
ReturnMsg cmd_res( uint8_t *ElectricIdentification )
printf("cmd_res \n");
cs_low();
// Send flash command and insert dummy cycle
uint8_t instruction[4];
instruction[0]= FLASH_CMD_RES;
instruction[1]= 0;
instruction[2]=0;
instruction[3]=0;
nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction,4,m_buffer_rx,5);
// Get electric identification
*ElectricIdentification = m_buffer_rx[4];
printf(" eid = %x\n",m_buffer_rx[4]);
cs_high();
* Function: CMD_REMS
* Arguments: REMS_Identification, 16 bit buffer to store id
* fsptr, pointer of flash status structure
* Description: The REMS instruction is to read the Device
* manufacturer ID and electric ID of 1-byte.
ReturnMsg cmd_rems( uint16_t *REMS_Identification, FlashStatus *fsptr )
uint8_t gDataBuffer[2];
cs_low();
// Send flash command and insert dummy cycle ( if need )
// ArrangeOpt = 0x00 will output the manufacturer's ID first
// = 0x01 will output electric ID first
// SendByte( FLASH_CMD_REMS, SIO );
// InsertDummyCycle( 16 );
// SendByte( fsptr->ArrangeOpt, SIO );
instruction[0]= FLASH_CMD_REMS;
instruction[1]= 0;
instruction[2]=0;
instruction[3]=0x00;
nrf_drv_spi_transfer(&spi,(uint8_t const *)instruction,4,m_buffer_rx,6);
// Get ID
gDataBuffer[0] = m_buffer_rx[2];//GetByte( SIO );
gDataBuffer[1] = m_buffer_rx[3];//GetByte( SIO );
// Store identification informaion
*REMS_Identification = (gDataBuffer[0] << 8) | gDataBuffer[1];
cs_high();
void cmd_read( uint32_t flash_address, uint8_t *target_address, uint32_t byte_length )
uint32_t index;
uint8_t addr_4byte_mode;
// Check flash address
if( flash_address > FlashSize )
return FlashAddressInvalid;
nrf_delay_ms(5);
cs_low();
// Write READ command and address
uint8_t instruction;
instruction = FLASH_CMD_READ;
m_buffer_tx[0]= instruction;
m_buffer_tx[1] = flash_address >> 16;
m_buffer_tx[2] = flash_address >> 8;
m_buffer_tx[3] = flash_address;
nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,FLASH_CMD_READ_LENGHT,m_data_receive,FLASH_CMD_READ_LENGHT+16);
// for( index=0; index < 4; index++ )
// printf("m_buffer_tx[%d] = %.02x \n",index,m_buffer_tx[index]);
// nrf_delay_ms(10);
// for( index=0; index < 20; index++ )
// printf("m_data_receive[%d] = %.02x \n",index,m_data_receive[index]);
nrf_delay_ms(500);
cs_high();
return true;
* Function: Wait_Flash_WarmUp
* Arguments: None.
* Description: Wait some time until flash read / write enable.
* Return Message: None.
void wait_flash_warm_up()
uint32_t time_cnt = FlashFullAccessTime;
while( time_cnt > 0 )
time_cnt--;
uint8_t flash_ID_test( uint8_t id )
uint8_t instruction[8] = {0};
uint8_t id_read = id;
switch (id_read)
case 1:
instruction[0] = FLASH_CMD_RES ;
instruction[1]= 0x00;
instruction[2] = 0x00;
instruction[3]= 0x00;
cs_low();
nrf_delay_ms(1);
printf("\rValue is 1:");
printf("%02x,%02x,%02x,%02x,%02x,%02x,%02x \n",m_buffer_rx[0],m_buffer_rx[1],m_buffer_rx[2],m_buffer_rx[3],m_buffer_rx[4],m_buffer_rx[5],m_buffer_rx[6]);
cs_high();
case 2:
instruction[0] = FLASH_CMD_REMS ;
instruction[1]= 0x01;
instruction[2] = 0x02;
printf("\rValue is 2:");
nrf_delay_ms(2);
printf("%02x,%02x,%02x,%02x,%02x,%02x\n",m_buffer_rx[0],m_buffer_rx[1],m_buffer_rx[2],m_buffer_rx[3],m_buffer_rx[4],m_buffer_rx[5]);
case 3:
m_buffer_tx[0] = FLASH_CMD_RDID;
cs_low();
// nrf_gpio_pin_clear(SPI_SS_PIN);
nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,1,m_buffer_rx,4);
//nrf_delay_ms(2);
//nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,1,m_buffer_rx,3);
nrf_delay_ms(2);
printf("\rValue is 3:");
printf("%02x,%02x,%02x\n",m_buffer_rx[1],m_buffer_rx[2],m_buffer_rx[3]);
cs_high();
printf("Out of range");
return true;
ReturnMsg cmd_rdsr( uint8_t *StatusReg )
cs_low();
// Send command
nrf_drv_spi_transfer(&spi,FLASH_CMD_RDSR,1,gDataBuffer,1);
cs_high();
*StatusReg = gDataBuffer;
// printf("cmd_rdsr = %d \n",gDataBuffer);
ReturnMsg cmd_rdcr( uint8_t *StatusReg )
cs_low();
// Send command
// SendByte( FLASH_CMD_RDSR, SIO );
// gDataBuffer = GetByte( SIO );
nrf_drv_spi_transfer(&spi,FLASH_CMD_RDCR,1,gDataBuffer,1);
cs_high();
// printf("status register = %x \n",StatusReg);
bool IsFlashBusy( void )
cmd_rdsr( &gDataBuffer );
if( (gDataBuffer & FLASH_WIP_MASK) == FLASH_WIP_MASK )
return true;
return false;
bool WaitFlashReady( uint32_t ExpectTime )
uint32_t temp = 0;
while( IsFlashBusy() )
if( temp > ExpectTime )
return false;
temp = temp + 1;
return true;
ReturnMsg cmd_wren( void )
cs_low();
// Write Enable command = 0x06, Setting Write Enable Latch Bit
uint8_t instruction = FLASH_CMD_WREN;
cs_high();
ReturnMsg cmd_wrdis( void )
cs_low();
uint8_t instruction = FLASH_CMD_WRDI;
cs_high();
ReturnMsg cmd_pp( uint32_t flash_address, uint8_t *source_address, uint32_t byte_length )
uint32_t index;
if( flash_address > FLASH_SIZE ) return FlashAddressInvalid;
cmd_wren();
nrf_delay_ms(5);
cs_low();
nrf_delay_ms(100);
// Write Page Program command
uint8_t len = 4;
m_buffer_tx[0]=FLASH_CMD_PP;
// memcpy(m_buffer_tx,instruction,4);
// nrf_drv_spi_transfer(&spi,instruction,len,m_buffer_rx,len+1);
memcpy(m_buffer_tx[4],flash_address >> 16,1);
for( index=4; index < 20; index++ )
m_buffer_tx[index] = source_address[index];//0xaa;
printf("\r data transmitted: ");
printf(" %.02x ",m_buffer_tx[index]);
nrf_delay_ms(10);
printf("\n");
// nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,20,m_data_receive,40);
nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,20,m_data_receive,0);
cs_high();
if( WaitFlashReady( PageProgramCycleTime ) )
uint8_t cmd_se( uint32_t flash_address )
cmd_wren();
cs_low();
//Write Sector Erase command = 0x20;
m_buffer_tx[0] = FLASH_CMD_SE;
printf(" \r sectore esrase command : %0.2x,%0.2x,%0.2x,%0.2x\n ",m_buffer_tx[0],m_buffer_tx[1],m_buffer_tx[2],m_buffer_tx[3]);
nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,4,m_buffer_rx,4);
cs_high();
// if( WaitFlashReady( SectorEraseCycleTime ) )
if( WaitFlashReady( 240000000 ))
cmd_rdscur(SecurityReg);
printf("SecurityReg %d \n ",SecurityReg);
uint8_t cmd_block_erase( uint32_t flash_address )
// cmd_wren();
cs_low();
instruction= FLASH_CMD_SE;
// instruction[1]= 0;
// instruction[2] =0;
// instruction[3]=0;
// SendByte( FLASH_CMD_SE, SIO );
// SendFlashAddr( flash_address, SIO, addr_4byte_mode );
cs_high();
* Function: CMD_CE
* Arguments: None.
* Description: The CE instruction is for erasing the data
* of the whole chip to be "1".
* Return Message: FlashIsBusy, FlashOperationSuccess, FlashTimeOut
ReturnMsg cmd_ce( void )
cmd_wren();
cs_low();
nrf_delay_ms(100);
//Write Chip Erase command = 0x60;
m_buffer_tx[0] = 0xC7;//FLASH_CMD_CE;
nrf_drv_spi_transfer(&spi,(uint8_t const *)m_buffer_tx,1,m_buffer_rx,0);
cs_high();
// cmd_rdsr(StatusReg);
// printf("StatusReg= %d \n",StatusReg);
//if( WaitFlashReady( 60000 ) )
nrf_delay_ms(60000);
// else
//return FlashOperationSuccess;
* Simple flash read/write test
uint8_t flash_read_write_test( void )
uint8_t message= 0;
FlashStatus flash_state = {0};
uint32_t flash_addr;
uint32_t trans_len = 0;
uint16_t i=0, error_cnt = 0;
uint16_t seed = 0;
uint8_t st_reg = 0;
/* Assign initial condition */
flash_addr = FLASH_TARGET_ADDR;
trans_len = TRANS_LENGTH;
seed = RANDOM_SEED;
/* Erase 4K sector of flash memory
Note: It needs to erase dirty sector before program */
uint8_t err_code;
// err_code = cmd_ce();//cmd_block_erase(flash_addr);//cmd_se( flash_addr );
// printf("error code = %d \n",err_code);
// nrf_delay_ms(300);
// cmd_read( flash_addr, m_data_receive, TRANS_LENGTH );
// printf("\r data after chip erase: ");
// for( i=4; i < 20; i++ )
// printf(" %.02x ",m_data_receive[i]);
// printf("\n");
/* Program data to flash memory */
cmd_pp( flash_addr, m_data_send, TRANS_LENGTH );
nrf_delay_ms(100);
/* Read flash memory data to memory buffer */
nrf_delay_ms(300);
/* Compare original data and flash data */
// for( i=4; i < (trans_len); i=i+1 )
// if( m_data_send[i] != m_data_receive[i] )
// printf("wrong data \n");
// Error_inc( error_cnt );
// else
printf("\r data received: ");
nrf_delay_ms(10);
printf("\n");
/* Erase 4K sector of flash memory */
cmd_ce();//cmd_block_erase(flash_addr); //cmd_se( flash_addr );
nrf_delay_ms(240); //240 60000
if( error_cnt != 0 )
return false;
return true;
uint8_t ext_flash_init(void)
uint8_t retval = false;
/* Configure SPI pins */
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = SPI_SS_PIN;
spi_config.miso_pin = SPI_MISO_PIN;
spi_config.mosi_pin = SPI_MOSI_PIN;
spi_config.sck_pin = SPI_SCK_PIN;
spi_config.mode = NRF_DRV_SPI_MODE_0;
spi_config.frequency= NRF_DRV_SPI_FREQ_125K;
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
nrf_gpio_pin_set(SPI_WP_PIN);
uint8_t err_code;
cmd_rsten();
cmd_rst();
err_code = cmd_wrdis();
/* Set CS pin to High*/
// cs_high();
wait_flash_warm_up();
nrf_delay_ms(100);
flash_ID_test(2);
/* read and verify manufacturer and device id from external flash to ensure external flash is working */
if(flash_ID_test(2) == true)
return true;
return retval;
